[PostGIS] #5845: address_standardizer test failing on winnie
PostGIS trac at osgeo.org
Wed Jan 29 17:12:31 PST 2025
 Reporter:  robe                 |      Owner:  robe
     Type:  defect               |     Status:  new
 Priority:  blocker              |  Milestone:  PostGIS 3.6.0
Component:  pagc_address_parser  |    Version:  master
 Keywords:                       |
  -------------- Additional Info -------------
   POSTGIS lib file includes minor:   ENABLED
   Interrupt Tests:   ENABLED
  -------------- Dependencies --------------
   GEOS config:          /projects/geos/rel-3.13.0w64gcc81/bin/geos-config
   GEOS version:         3.13.0 (31300)
   GDAL config:          /projects/gdal/rel-3.9.2w64gcc81/bin/gdal-config
   GDAL version:         3.9.2
   SFCGAL config:        /projects/CGAL/rel-sfcgal-1.5.2w64gcc81/bin
 /sfcgal-config
   SFCGAL version:       1.5.2
   PostgreSQL config:
 /projects/postgresql/rel/pg16w64gcc81/bin/pg_config
   PostgreSQL version:   PostgreSQL 16.4
   PROJ version:         8.2.1 (80201)
   Libxml2 config:       /projects/libxml/rel-
 libxml2-2.12.5w64gcc81/bin/xml2-config
   Libxml2 version:      2.12.5
   JSON-C support:       yes
   protobuf support:     yes
   protobuf-c version:   1002001
   PCRE support:         Version 1
   Perl:                 /usr/bin/perl
 # +++ regress install-check in  +++
 # using postmaster on localhost, port 26016
 ok 1         - test-init-extensions                     1788 ms
 ok 2         - test-parseaddress                        1558 ms
 ok 3         - test-standardize_address_1               3773 ms
 ok 4         - test-standardize_address_2               8702 ms
 ok 5         - test-debug_standardize_address           2819 ms
 1..5
 # All 5 tests passed.
 echo "# +++ regress install-check in  +++" &&
 E:/jenkins/postgresql/rel/pg16w64gcc81/lib/pgxs/src/makefiles/../../src/test/regress/pg_regress
 --inputdir=./ --bindir='E:/jenkins/postgresql/rel/pg16w64gcc81/bin'
 --load-extension=fuzzystrmatch --load-extension=postgis --load-
 extension=postgis_tiger_geocoder --load-extension=address_standardizer
 --dbname=contrib_regression test-normalize_address test-upgrade test-
 pagc_normalize_address
 ok 1         - test-normalize_address                   1100 ms
 ok 2         - test-upgrade                             4564 ms
 not ok 3     - test-pagc_normalize_address              5620 ms
 1..3
 # 1 of 3 tests failed.
 # The differences that caused some tests to fail can be viewed in the file
 "E:/jenkins/postgis/branches/3.6/extensions/postgis_tiger_geocoder/regression.diffs".
 # A copy of the test summary that you see above is saved in the file
 "E:/jenkins/postgis/branches/3.6/extensions/postgis_tiger_geocoder/regression.out".
 make: ***
 [E:/jenkins/postgresql/rel/pg16w64gcc81/lib/pgxs/src/makefiles/pgxs.mk:436:
 installcheck] Error 1
 -#1051d|212||3RD|AVE|N||MINNEAPOLIS|MN|55401|t||212
 +#1051d|212||3RD|AVE|||MINNEAPOLIS|MN|N 55401|t||212
 https://winnie.postgis.net/view/PostGIS/job/PostGIS_EDB_Regress_winnie/19674/consoleFull
 I recall seeing this issue before and had to do with order of tokens in
 gaz.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5845>
