[SCM] PostGIS branch master updated. 3.5.0-308-g935e23f3c
Mon May 5 07:46:07 PDT 2025
the project "PostGIS".
       via  935e23f3c42b24ed9074e77e5473ae18ab8eedbe (commit)
       via  67f74870b08ba5e29f07084a0cf976e9ac345d1c (commit)
      from  b999711b28317faf283a4ce77abdd97ea424490e (commit)
revisions in full, below.
commit 935e23f3c42b24ed9074e77e5473ae18ab8eedbe
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon May 5 16:14:06 2025 +0200
    Add topology.TotalTopologySize function
    Includes regress test and documentation
    Closes #5894
diff --git a/NEWS b/NEWS
index 28471efa8..709c09d44 100644
--- a/NEWS
+++ b/NEWS
@@ -16,6 +16,7 @@ PostGIS 3.6.0
 * New Features *
+  - #5894, TotalTopologySize (Sandro Santilli)
   - #5890, ValidateTopologyPrecision, MakeTopologyPrecise (Sandro Santilli)
   - #5861, Add --drop-topology switch to pgtopo_import (Sandro Santilli)
   - #1247, ST_AsRasterAgg (Sandro Santilli)
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 71f4e9cda..9d4b2d01f 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -1208,6 +1208,62 @@ SELECT layer_id(findLayer('features.land_parcels', 'feature'));
 				<para><xref linkend="FindTopology"/></para>
 			</refsection>
 		</refentry>
+		<refentry xml:id="TotalTopologySize">
+			<refnamediv>
+				<refname>TotalTopologySize</refname>
+				<refpurpose>Total disk space used by the specified topology, including all indexes and TOAST data.</refpurpose>
+			</refnamediv>
+			<refsynopsisdiv>
+				<funcsynopsis>
+					<funcprototype>
+					<funcdef>int8 <function>TotalTopologySize</function></funcdef>
+					<paramdef><type>name </type> <parameter>toponame</parameter></paramdef>
+					</funcprototype>
+				</funcsynopsis>
+			</refsynopsisdiv>
+			<refsection>
+                <title>Description</title>
+                <para>
+Takes a topology name and provides the total
+disk space used by all its tables, including indexes and TOAST data.
+                </para>
+                <!-- use this format if new function -->
+                <para role="availability" conformance="3.6.0">Availability: 3.6.0</para>
+			</refsection>
+			<refsection>
+				<title>Examples</title>
+				<programlisting>SELECT topology.topologysummary('city_data');
+                    topologysummary
+ Topology city_data (329), SRID 4326, precision: 0
+ 22 nodes, 24 edges, 10 faces, 29 topogeoms in 5 layers
+ Layer 1, type Polygonal (3), 9 topogeoms
+  Deploy: features.land_parcels.feature
+ Layer 2, type Puntal (1), 8 topogeoms
+  Deploy: features.traffic_signs.feature
+ Layer 3, type Lineal (2), 8 topogeoms
+  Deploy: features.city_streets.feature
+ Layer 4, type Polygonal (3), 3 topogeoms
+  Hierarchy level 1, child layer 1
+  Deploy: features.big_parcels.feature
+ Layer 5, type Puntal (1), 1 topogeoms
+  Hierarchy level 1, child layer 2
+  Deploy: features.big_signs.feature</programlisting>
+			</refsection>
+			<!-- Optionally add a "See Also" section -->
+			<refsection>
+				<title>See Also</title>
+				<para><xref linkend="Topology_Load_Tiger"/></para>
+			</refsection>
+		</refentry>
 	</section>
 	<section xml:id="Topology_StatsManagement" xreflabel="maintaining statistics during topology editing and population">
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 0339a5dee..a728814c6 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -143,6 +143,7 @@ topology.sql: \
 	sql/manage/FindTopology.sql.in \
 	sql/manage/ManageHelper.sql.in \
 	sql/manage/MakeTopologyPrecise.sql.in \
+	sql/manage/TotalTopologySize.sql.in \
 	sql/manage/populate_topology_layer.sql.in \
 	sql/manage/RenameTopology.sql.in \
 	sql/manage/TopologySummary.sql.in \
diff --git a/topology/sql/manage/TotalTopologySize.sql.in b/topology/sql/manage/TotalTopologySize.sql.in
new file mode 100644
index 000000000..d68989c97
--- /dev/null
+++ b/topology/sql/manage/TotalTopologySize.sql.in
@@ -0,0 +1,39 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- Copyright (C) 2025 Sandro Santilli <strk at kbt.io>
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+-- Author: Sandro Santilli <strk at kbt.io>
+-- Availability: 3.6.0
+CREATE OR REPLACE FUNCTION topology.TotalTopologySize(toponame name)
+RETURNS int8
+AS $BODY$
+DECLARE
+  sql TEXT;
+  total_size int8;
+BEGIN
+  sql := format(
+SELECT
+pg_catalog.pg_total_relation_size('%1$I.edge_data') +
+pg_catalog.pg_total_relation_size('%1$I.node') +
+pg_catalog.pg_total_relation_size('%1$I.face') +
+pg_catalog.pg_total_relation_size('%1$I.relation')
+    toponame
+  EXECUTE sql INTO total_size;
+  RETURN total_size;
+END;
+$BODY$ LANGUAGE 'plpgsql' STABLE;
diff --git a/topology/test/regress/totaltopologysize.sql b/topology/test/regress/totaltopologysize.sql
index 000000000..cda203c5a
--- /dev/null
+++ b/topology/test/regress/totaltopologysize.sql
@@ -0,0 +1,19 @@
+\set VERBOSITY terse
+set client_min_messages to ERROR;
+BEGIN;
+SELECT NULL FROM topology.CreateTopology('t0');
+SELECT NULL FROM topology.CreateTopology('t1');
+SELECT 't0', topology.TotalTopologySize('t0') = topology.TotalTopologySize('t1');
+SELECT NULL FROM topology.TopoGeo_addPoint('t0', 'POINT(0 0)');
+SELECT 't1', topology.TotalTopologySize('t0') > topology.TotalTopologySize('t1');
+SELECT NULL FROM topology.TopoGeo_addLineString('t1', 'LINESTRING(0 0, 5 6)');
+SELECT 't2', topology.TotalTopologySize('t0') < topology.TotalTopologySize('t1');
+ROLLBACK;
diff --git a/topology/test/regress/totaltopologysize_expected b/topology/test/regress/totaltopologysize_expected
index 000000000..f1b8b1333
--- /dev/null
+++ b/topology/test/regress/totaltopologysize_expected
@@ -0,0 +1,3 @@
+t0|t
+t1|t
+t2|t
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 3776692c1..024823110 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -87,6 +87,7 @@ TESTS += \
 	$(top_srcdir)/topology/test/regress/topogeometry_type.sql \
 	$(top_srcdir)/topology/test/regress/topojson.sql \
 	$(top_srcdir)/topology/test/regress/topologysummary.sql \
+	$(top_srcdir)/topology/test/regress/totaltopologysize.sql \
 	$(top_srcdir)/topology/test/regress/totopogeom.sql \
 	$(top_srcdir)/topology/test/regress/validatetopologyprecision.sql \
 	$(top_srcdir)/topology/test/regress/validatetopologyrelation.sql \
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index c2ba6f303..91d603ea6 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1403,6 +1403,7 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 #include "sql/manage/ValidateTopologyRelation.sql.in"
 #include "sql/manage/ValidateTopologyPrecision.sql.in"
 #include "sql/manage/MakeTopologyPrecise.sql.in"
+#include "sql/manage/TotalTopologySize.sql.in"
 -- Cleanup functions
 #include "sql/cleanup/RemoveUnusedPrimitives.sql.in"
commit 67f74870b08ba5e29f07084a0cf976e9ac345d1c
Date:   Mon May 5 16:13:32 2025 +0200
    Encode availability of MakeTopologyPrecise/ValidateTopologyPrecision
diff --git a/topology/sql/manage/MakeTopologyPrecise.sql.in b/topology/sql/manage/MakeTopologyPrecise.sql.in
index 24cf395ac..e66eea2fb 100644
--- a/topology/sql/manage/MakeTopologyPrecise.sql.in
+++ b/topology/sql/manage/MakeTopologyPrecise.sql.in
@@ -17,6 +17,7 @@
 -- Invalidities are represented by any vertex that does not fall on
 -- the topology precision grid.
 CREATE OR REPLACE FUNCTION topology.MakeTopologyPrecise(toponame name, bbox GEOMETRY DEFAULT NULL, gridSize float8 DEFAULT NULL)
 RETURNS void AS
 $BODY$
diff --git a/topology/sql/manage/ValidateTopologyPrecision.sql.in b/topology/sql/manage/ValidateTopologyPrecision.sql.in
index 0119bc401..bdb5fb386 100644
--- a/topology/sql/manage/ValidateTopologyPrecision.sql.in
+++ b/topology/sql/manage/ValidateTopologyPrecision.sql.in
@@ -17,6 +17,7 @@
 CREATE OR REPLACE FUNCTION topology.ValidateTopologyPrecision(toponame name, bbox geometry DEFAULT NULL, gridSize float8 DEFAULT NULL)
 RETURNS geometry AS
 $BODY$
Summary of changes:
 NEWS                                               |  1 +
 doc/extras_topology.xml                            | 56 ++++++++++++++++++++++
 topology/Makefile.in                               |  1 +
 topology/sql/manage/MakeTopologyPrecise.sql.in     |  1 +
 topology/sql/manage/TotalTopologySize.sql.in       | 39 +++++++++++++++
 .../sql/manage/ValidateTopologyPrecision.sql.in    |  1 +
 topology/test/regress/totaltopologysize.sql        | 19 ++++++++
 topology/test/regress/totaltopologysize_expected   |  3 ++
 topology/test/tests.mk                             |  1 +
 topology/topology.sql.in                           |  1 +
 10 files changed, 123 insertions(+)
 create mode 100644 topology/sql/manage/TotalTopologySize.sql.in
 create mode 100644 topology/test/regress/totaltopologysize.sql
 create mode 100644 topology/test/regress/totaltopologysize_expected
hooks/post-receive
