[PostGIS] #5895: Distance Calculation Issue with `ST_DistanceSphere`
trac at osgeo.org
Thu May 8 00:50:37 PDT 2025
Reporter: giovannicimolin | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 3.4.x
Keywords: |
I’ve recently came across a weird behavior while doing distance-based
matching in PostGIS.
My stack is Django (and GeoDjango), but I found the issue to be on the
response provided by the DB.
== Problem description
When dealing with some shapes, the distance returned by the
`ST_DistanceSphere`/`ST_Distance` function is zero.
Here’s a minimal reproducible example:
=== Query
SELECT ST_DistanceSphere(
ST_GeomFromGeoJSON('{
"type": "Polygon",
"coordinates": [
[ -93.751932270476971, 32.089230804932349 ],
[ -93.753830066356031, 32.089181143046332 ],
[ -93.753864556452115, 32.090802706180867 ],
[ -93.751940314782857, 32.09084654939128 ],
"type": "Point",
"coordinates": [ 52.41828388240291, 28.68513149020453 ]
) AS distance;
=== Results
With `ST_DistanceSphere`:
distance
0
(1 row)
Same operation with `ST_DistanceSpheroid`: (correct!)
distance
12391246.377484955
(1 row)
=== Notes
Applying `ST_MakeValid` or `ST_Buffer(pol, 0)` does not fix the issue.
However, if I change the polygon winding, the result comes out correct!
"type": "Polygon",
"coordinates": [
"type": "Point",
) AS distance;
Result:
distance
12370146.65163511
(1 row)
But the polygon is incorrectly wound in this case and applying `ST_Buffer`
inverts the coordinates and yields the wrong result:
ST_Buffer(ST_GeomFromGeoJSON('{
"type": "Polygon",
"coordinates": [
}'), 0),
"type": "Point",
) AS distance;
distance
distance
0
(1 row)
Could you help me with this issue?
I'm I doing something wrong with the data or is it really a bug?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5895>
