[PostGIS] #5715: A new flag --without-comments
trac at osgeo.org
Fri May 9 06:17:01 PDT 2025
Reporter: Lars Aksel Opsahl | Owner: strk
Type: enhancement | Status: new
Priority: low | Milestone: PostGIS 3.6.0
Component: postgis | Version: 3.4.x
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
I test now to avoid doc to build and this error
grep -v '\&postgis_special;' postgis.xml > postgis-nospecial.xml.in
/usr/local/bin/xmllint --path
.:/Users/lop/dev/pg_build_from_source/gitlab_com_larsop/postgis/doc
--noent -o postgis-nospecial.xml postgis-nospecial.xml.in
dyld[96203]: Symbol not found: _xmlCtxtSetMaxAmplification
Referenced from: <67ABBA84-EFD3-3806-86AE-9975D0EC3811>
Expected in: <236C8BF2-0800-396C-AF03-B5328CAD1FD6>
/usr/lib/libxml2.2.dylib
make[1]: *** [postgis-nospecial.xml] Abort trap: 6
make: *** [all] Error 1
I had to do this on my mac
diff --git a/configure.ac b/configure.ac
index ed5d17255..a6dbd35e3 100644
--- a/configure.ac
+++ b/configure.ac
@@ -199,7 +199,7 @@ dnl
dnl Search for xsltproc which is required for building documentation
dnl
-CAN_BUILD_COMMENTS=yes
+CAN_BUILD_COMMENTS=no
AC_PATH_PROG([XSLTPROC], [xsltproc], [])
if test "x$XSLTPROC" = "x"; then
So it's seems like by default doc is still i built.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5715#comment:5>
