[PostGIS] #5808: Weird constant ram increase using topology
PostGIS trac at osgeo.org
Mon May 12 19:06:17 PDT 2025
  Reporter:  latot     |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.5.4
 Component:  topology  |    Version:  3.5.x
Resolution:            |   Keywords:
Comment (by Lars Aksel Opsahl):
 Replying to [comment:24 robe]:
 > is this still an issue -- seems like some changes were made but only
 3.5.0 and 3.6.0 were tested.  have you tested with 3.5.2?
 I have only tested 3.6.0 and have not seen that error after this fix any
 more. We have running many jobs involving millions of edges.
 The reason way I only run on 3.6 is that switch between 3.5 and 3.6 is
 complicated since we have so much date in this databases.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5808#comment:26>
