[SCM] PostGIS branch master updated. 3.5.0-322-gcc5ee17a9
Wed May 14 23:59:46 PDT 2025
the project "PostGIS".
       via  cc5ee17a97e79b21ee5eea708127ef76a1173d63 (commit)
       via  f5a77f6ad3490d22e146e69965b6439e9fbfc2ca (commit)
       via  e3ad7eb306dddff0cf7b0c824654ba9dcb90724d (commit)
      from  a783dca52b99ebe976216ed6f37d7992ec300528 (commit)
revisions in full, below.
commit cc5ee17a97e79b21ee5eea708127ef76a1173d63
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Thu May 15 08:44:37 2025 +0200
    docs(NEWS): SFCGAL: Add CG_Simplify
diff --git a/NEWS b/NEWS
index 2f80800e7..59f1f0c57 100644
--- a/NEWS
+++ b/NEWS
@@ -16,6 +16,7 @@ PostGIS 3.6.0
 * New Features *
+  - GH-803, ADD CG_Simplify function (Loïc Bartoletti)
   - GH-805, Add M support for SFCGAL >= 1.5.0 (Loïc Bartoletti)
   - #5894, TotalTopologySize (Sandro Santilli)
   - #5890, ValidateTopologyPrecision, MakeTopologyPrecise (Sandro Santilli)
commit f5a77f6ad3490d22e146e69965b6439e9fbfc2ca
Date:   Wed May 14 07:26:23 2025 +0200
    docs(CG_Simplify): Add CG_Simplify documentation and examples
diff --git a/doc/html/images/Makefile.in b/doc/html/images/Makefile.in
index 1d638b7b0..f97fc278a 100644
--- a/doc/html/images/Makefile.in
+++ b/doc/html/images/Makefile.in
@@ -47,6 +47,9 @@ GENERATED_IMAGES= \
 	cg_ymonotonepartition01.png \
 	cg_ymonotonepartition02.png \
 	cg_straightskeletonpartition01.png \
+	cg_simplify00.png \
+	cg_simplify01.png \
+	cg_simplify02.png \
 	de9im01.png \
 	de9im02.png \
 	st_alphashape01.png \
diff --git a/doc/html/images/wkt/cg_simplify00.wkt b/doc/html/images/wkt/cg_simplify00.wkt
new file mode 100644
index 000000000..8d370893c
--- /dev/null
+++ b/doc/html/images/wkt/cg_simplify00.wkt
@@ -0,0 +1 @@
+ArgA;GEOMETRYCOLLECTION(POLYGON((88.46 158.85,90.77 171.54,147.31 173.85,146.15 145,173.85 119.62,146.15 103.46,112.69 118.46,91.92 93.08,65.38 101.15,34.23 121.92,41.15 142.69,49.23 143.85,88.46 158.85)),POLYGON((112.69 118.46,146.15 103.46,190 60.77,185.38 43.46,126.54 26.15,83.85 28.46,67.69 64.23,43.46 58.46,10 83.85,34.23 121.92,65.38 101.15,91.92 93.08,112.69 118.46)))
diff --git a/doc/html/images/wkt/cg_simplify01.wkt b/doc/html/images/wkt/cg_simplify01.wkt
index 000000000..e4a1d0e79
--- /dev/null
+++ b/doc/html/images/wkt/cg_simplify01.wkt
@@ -0,0 +1,2 @@
+Result;POLYGON((88.46 158.85,147.31 173.85,146.15 103.46,112.69 118.46,34.23 121.92,88.46 158.85))
+Result;POLYGON((112.69 118.46,146.15 103.46,185.38 43.46,10 83.85,34.23 121.92,112.69 118.46))
diff --git a/doc/html/images/wkt/cg_simplify02.wkt b/doc/html/images/wkt/cg_simplify02.wkt
index 000000000..6f1bc7a2c
--- /dev/null
+++ b/doc/html/images/wkt/cg_simplify02.wkt
@@ -0,0 +1,2 @@
+Result;POLYGON((88.46 158.85,173.85 119.62,34.23 121.92,88.46 158.85))
+Result;POLYGON((112.69 118.46,190 60.77,10 83.85,112.69 118.46))
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index 375344fe6..547788885 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -3122,7 +3122,7 @@ ERROR:  straight skeleton of Polygon with point touching rings is not implemente
        <programlisting><![CDATA[SELECT string_agg('<Shape>' || ST_AsX3D(cgbuffer3d_output)  || '<Appearance>
           <Material diffuseColor="0 0.8 0.2" specularColor="0 1 0"/>
         </Appearance>
-    </Shape>', '');]]></programlisting>
+    </Shape>', '');]]></programlisting>
     <informaltable>
                 <tgroup cols="2">
                 <tbody>
@@ -3568,5 +3568,152 @@ ERROR:  straight skeleton of Polygon with point touching rings is not implemente
    </refsection>
 </refentry>
+<refentry xml:id="CG_Simplify">
+  <refnamediv>
+    <refname>CG_Simplify</refname>
+    <refpurpose>Reduces the complexity of a geometry while preserving essential features and Z/M values.</refpurpose>
+  </refnamediv>
+  <refsynopsisdiv>
+    <funcsynopsis>
+      <funcprototype>
+        <funcdef>geometry <function>CG_Simplify</function></funcdef>
+        <paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
+        <paramdef><type>double precision</type> <parameter>threshold</parameter></paramdef>
+        <paramdef choice="opt"><type>boolean</type> <parameter>preserveTopology = false</parameter></paramdef>
+      </funcprototype>
+    </funcsynopsis>
+  </refsynopsisdiv>
+  <refsection>
+    <title>Description</title>
+    <para>
+      Simplifies a geometry using SFCGAL's simplification algorithm, which reduces the number of points or vertices while preserving the essential features of the geometry. This function preserves Z and M values during simplification.
+    </para>
+    <para>
+      The algorithm is based on constrained triangulation and uses the <link xlink:href="https://doc.cgal.org/latest/Polyline_simplification_2/index.html">CGAL Polyline Simplification 2</link> library with additional handling to preserve Z and M coordinates.
+      When topology is preserved and geometries intersect, Z and M values are interpolated at intersection points.
+    </para>
+    <para>
+      This function works well with 3D terrain-like geometries (2.5D) but is not designed for vertical surfaces like walls.
+    </para>
+    <para role="availability" conformance="3.6.0">Availability: 3.6.0 - requires SFCGAL >= 2.1.0</para>
+    <para>&sfcgal_required;</para>
+    <para>&Z_support;</para>
+    <para>&M_support;</para>
+  </refsection>
+  <refsection>
+    <title>Parameters</title>
+    <variablelist>
+      <varlistentry>
+        <term><parameter>geom</parameter></term>
+        <listitem>
+          <para>Input geometry</para>
+        </listitem>
+      </varlistentry>
+      <varlistentry>
+        <term><parameter>threshold</parameter></term>
+        <listitem>
+          <para>Maximum distance threshold (in geometry unit) for simplification. The higher this value, the more simplified the resulting geometry will be.</para>
+        </listitem>
+      </varlistentry>
+      <varlistentry>
+        <term><parameter>preserveTopology</parameter></term>
+        <listitem>
+          <para>If set to true, the function ensures that the topology of the geometry is preserved. When geometries intersect in this mode, Z and M values at intersection points are interpolated. The default value is false.</para>
+        </listitem>
+      </varlistentry>
+    </variablelist>
+  </refsection>
+  <refsection>
+    <title>Return Value</title>
+    <para>
+      Returns a simplified geometry with preserved Z and M values.
+    </para>
+  </refsection>
+  <refsection>
+    <title>Examples</title>
+    <para>
+      <programlisting>
+-- Simplify a polygon with a threshold of 0.5
+SELECT ST_AsText(CG_Simplify(ST_GeomFromText('POLYGON((0 0, 0 1, 0.1 1, 0.2 1, 0.3 1, 0.4 1, 0.5 1, 1 1, 1 0, 0 0))'), 0.5));
+-- Simplify a 3D terrain geometry while preserving topology and Z values
+SELECT ST_AsText(CG_Simplify(ST_GeomFromText('LINESTRING Z(0 0 0, 0 1 1, 0.1 1 1, 0.2 1 1, 0.3 1 1, 1 1 2)'), 0.2, true));
+-- Simplify a geometry with both Z and M values
+SELECT ST_AsText(CG_Simplify(ST_GeomFromText('LINESTRING ZM(0 0 0 1, 0 1 1 2, 0.1 1 1 3, 0.2 1 1 4, 0.3 1 1 5, 1 1 2 6)'), 0.2));
+-- Simplify two geometry together preserving Z and M values, without topology
+SELECT ST_AsText(CG_Simplify('GEOMETRYCOLLECTION ZM(LINESTRING ZM(-1 -1 3 4, 0 0 10 100, 1 1 20 200, 0 2 15 150, 0 5 30 300, 2 19 25 250, -4 20 15 150), POLYGON ZM((0 0 10 100, 1 1 20 200, 0 2 15 150, 0 5 30 300, 2 19 25 250, -4 20 15 150, 0 0 10 100)))', 2, false));
+-- Simplify two geometry together preserving Z and M values, with topology
+SELECT ST_AsText(CG_Simplify('GEOMETRYCOLLECTION ZM(LINESTRING ZM(-1 -1 3 4, 0 0 10 100, 1 1 20 200, 0 2 15 150, 0 5 30 300, 2 19 25 250, -4 20 15 150), POLYGON ZM((0 0 10 100, 1 1 20 200, 0 2 15 150, 0 5 30 300, 2 19 25 250, -4 20 15 150, 0 0 10 100)))', 2, true));
+      </programlisting>
+    </para>
+    <para>
+        <programlisting>
+WITH depts_pds as (SELECT ST_GeomFromText('GEOMETRYCOLLECTION(
+POLYGON((88.46 158.85,90.77 171.54,147.31 173.85,146.15 145,173.85 119.62,146.15 103.46,112.69 118.46,91.92 93.08,65.38 101.15,34.23 121.92,41.15 142.69,49.23 143.85,88.46 158.85)),
+POLYGON((112.69 118.46,146.15 103.46,190 60.77,185.38 43.46,126.54 26.15,83.85 28.46,67.69 64.23,43.46 58.46,10 83.85,34.23 121.92,65.38 101.15,91.92 93.08,112.69 118.46)))
+') as geom)
+SELECT geom FROM depts_pds;
+        </programlisting>
+        <informalfigure>
+            <mediaobject>
+                <imageobject>
+                    <imagedata fileref="images/cg_simplify00.png"/>
+                </imageobject>
+                <caption><para>Originals geometries</para></caption>
+            </mediaobject>
+        </informalfigure>
+    </para>
+    <para>
+        <programlisting>
+') as geom)
+SELECT (ST_Dump(CG_Simplify(geom, 0.5, true))).geom FROM depts_pds;
+        </programlisting>
+        <informalfigure>
+            <mediaobject>
+                <imageobject>
+                    <imagedata fileref="images/cg_simplify01.png"/>
+                </imageobject>
+                <caption><para>Simplification with 0.5 and topology preserved</para></caption>
+            </mediaobject>
+        </informalfigure>
+    </para>
+    <para>
+      <programlisting>
+') as geom)
+SELECT (ST_Dump(CG_Simplify(geom, 0.5, false))).geom FROM depts_pds;
+      </programlisting>
+      <informalfigure>
+        <mediaobject>
+          <imageobject>
+            <imagedata fileref="images/cg_simplify02.png"/>
+          </imageobject>
+          <caption><para>Simplification with 0.5 without topology preservation</para></caption>
+        </mediaobject>
+      </informalfigure>
+    </para>
+  </refsection>
+  <refsection>
+    <title>See Also</title>
+    <para>
+      <xref linkend="ST_Simplify"/>, <xref linkend="ST_SimplifyPreserveTopology"/>
+    </para>
+  </refsection>
+</refentry>
     </section>
 </chapter>
commit e3ad7eb306dddff0cf7b0c824654ba9dcb90724d
Date:   Thu Mar 20 06:58:57 2025 +0100
    feat(SFCGAL): Add CG_Simplify function
diff --git a/sfcgal/lwgeom_sfcgal.c b/sfcgal/lwgeom_sfcgal.c
index a73834701..2885d6995 100644
--- a/sfcgal/lwgeom_sfcgal.c
+++ b/sfcgal/lwgeom_sfcgal.c
@@ -77,6 +77,7 @@ Datum postgis_sfcgal_noop(PG_FUNCTION_ARGS);
 Datum sfcgal_convexhull3D(PG_FUNCTION_ARGS);
 Datum sfcgal_alphashape(PG_FUNCTION_ARGS);
 Datum sfcgal_optimalalphashape(PG_FUNCTION_ARGS);
+Datum sfcgal_simplify(PG_FUNCTION_ARGS);
 GSERIALIZED *geometry_serialize(LWGEOM *lwgeom);
 char *text_to_cstring(const text *textptr);
@@ -1727,3 +1728,41 @@ sfcgal_buffer3d(PG_FUNCTION_ARGS)
 	PG_RETURN_POINTER(output);
 #endif
+PG_FUNCTION_INFO_V1(sfcgal_simplify);
+Datum
+sfcgal_simplify(PG_FUNCTION_ARGS)
+#if POSTGIS_SFCGAL_VERSION < 20100
+	lwpgerror(
+	    "The SFCGAL version this PostGIS binary was compiled against (%d) doesn't support "
+	    "'sfcgal_geometry_simplify' function (requires SFCGAL 2.1.0+)",
+	    POSTGIS_SFCGAL_VERSION);
+	PG_RETURN_NULL();
+#else /* POSTGIS_SFCGAL_VERSION >= 20100 */
+	GSERIALIZED *input, *output;
+	sfcgal_geometry_t *geom, *result;
+	double threshold;
+	bool preserveTopology;
+	srid_t srid;
+	sfcgal_postgis_init();
+	input = PG_GETARG_GSERIALIZED_P(0);
+	threshold = PG_GETARG_FLOAT8(1);
+	preserveTopology = PG_GETARG_BOOL(2);
+	srid = gserialized_get_srid(input);
+	geom = POSTGIS2SFCGALGeometry(input);
+	PG_FREE_IF_COPY(input, 0);
+	result = sfcgal_geometry_simplify(geom, threshold, preserveTopology);
+	sfcgal_geometry_delete(geom);
+	output = SFCGALGeometry2POSTGIS(result, 0, srid);
+	sfcgal_geometry_delete(result);
+	PG_RETURN_POINTER(output);
+#endif
diff --git a/sfcgal/regress/simplify.sql b/sfcgal/regress/simplify.sql
index 000000000..8763e8524
--- /dev/null
+++ b/sfcgal/regress/simplify.sql
@@ -0,0 +1,2 @@
+SELECT 'CG_Simplify', ST_AsText(CG_Simplify('GEOMETRYCOLLECTION ZM(LINESTRING ZM(-1 -1 3 4, 0 0 10 100, 1 1 20 200, 0 2 15 150, 0 5 30 300, 2 19 25 250, -4 20 15 150), POLYGON ZM((0 0 10 100, 1 1 20 200, 0 2 15 150, 0 5 30 300, 2 19 25 250, -4 20 15 150, 0 0 10 100)))', 2, false));
+SELECT 'CG_Simplify With Topology', ST_AsText(CG_Simplify('GEOMETRYCOLLECTION ZM(LINESTRING ZM(-1 -1 3 4, 0 0 10 100, 1 1 20 200, 0 2 15 150, 0 5 30 300, 2 19 25 250, -4 20 15 150), POLYGON ZM((0 0 10 100, 1 1 20 200, 0 2 15 150, 0 5 30 300, 2 19 25 250, -4 20 15 150, 0 0 10 100)))', 2, true));
diff --git a/sfcgal/regress/simplify_expected b/sfcgal/regress/simplify_expected
index 000000000..b5f119f0c
--- /dev/null
+++ b/sfcgal/regress/simplify_expected
@@ -0,0 +1,2 @@
+CG_Simplify|GEOMETRYCOLLECTION ZM (LINESTRING ZM (-1 -1 3 4,2 19 25 250,-4 20 15 150),POLYGON ZM ((0 0 10 100,2 19 25 250,-4 20 15 150,0 0 10 100)))
+CG_Simplify With Topology|GEOMETRYCOLLECTION ZM (LINESTRING ZM (-1 -1 3 4,0 0 10 100,2 19 25 250,-4 20 15 150),POLYGON ZM ((0 0 10 100,2 19 25 250,-4 20 15 150,0 0 10 100)))
diff --git a/sfcgal/regress/tests.mk.in b/sfcgal/regress/tests.mk.in
index d160823d3..241d274f2 100644
--- a/sfcgal/regress/tests.mk.in
+++ b/sfcgal/regress/tests.mk.in
@@ -37,3 +37,8 @@ ifeq ($(shell expr "$(POSTGIS_SFCGAL_VERSION)" ">=" 20000),1)
 	TESTS += \
 		$(top_srcdir)/sfcgal/regress/sfcgal_v2.sql
 endif
+ifeq ($(shell expr "$(POSTGIS_SFCGAL_VERSION)" ">=" 20100),1)
+	TESTS += \
+		$(top_srcdir)/sfcgal/regress/simplify.sql
+endif
diff --git a/sfcgal/sfcgal.sql.in b/sfcgal/sfcgal.sql.in
index 2cee2c9fa..6764b2f18 100644
--- a/sfcgal/sfcgal.sql.in
+++ b/sfcgal/sfcgal.sql.in
@@ -595,4 +595,10 @@ AS 'MODULE_PATHNAME', 'sfcgal_translate_3d'
 LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 _COST_LOW;
+-- Availability 3.6.0
+CREATE OR REPLACE FUNCTION CG_Simplify(geom geometry, threshold float8, preserveTopology boolean DEFAULT false )
+RETURNS geometry
+AS 'MODULE_PATHNAME', 'sfcgal_simplify'
+LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+_COST_LOW;
 COMMIT;
Summary of changes:
 NEWS                                  |   1 +
 doc/html/images/Makefile.in           |   3 +
 doc/html/images/wkt/cg_simplify00.wkt |   1 +
 doc/html/images/wkt/cg_simplify01.wkt |   2 +
 doc/html/images/wkt/cg_simplify02.wkt |   2 +
 doc/reference_sfcgal.xml              | 149 +++++++++++++++++++++++++++++++++-
 sfcgal/lwgeom_sfcgal.c                |  39 +++++++++
 sfcgal/regress/simplify.sql           |   2 +
 sfcgal/regress/simplify_expected      |   2 +
 sfcgal/regress/tests.mk.in            |   5 ++
 sfcgal/sfcgal.sql.in                  |   6 ++
 11 files changed, 211 insertions(+), 1 deletion(-)
 create mode 100644 doc/html/images/wkt/cg_simplify00.wkt
 create mode 100644 doc/html/images/wkt/cg_simplify01.wkt
 create mode 100644 doc/html/images/wkt/cg_simplify02.wkt
 create mode 100644 sfcgal/regress/simplify.sql
 create mode 100644 sfcgal/regress/simplify_expected
hooks/post-receive
