[SCM] PostGIS branch stable-3.5 updated. 3.5.2-42-g5e9bf0a63
git at osgeo.org
git at osgeo.org
Fri May 16 19:38:33 PDT 2025
the project "PostGIS".
The branch, stable-3.5 has been updated
via 5e9bf0a63aa5e8204fbcea959662b6b0dbc8d872 (commit)
from 87a4db64f2c51980dc4e906c68520d26ad473db9 (commit)
revisions in full, below.
commit 5e9bf0a63aa5e8204fbcea959662b6b0dbc8d872
Author: Regina Obe <lr at pcorp.us>
Date: Fri May 16 22:38:25 2025 -0400
Don't use functions deprecated in SFCGAL 2.1 when built against SFCGAL 2.1
diff --git a/NEWS b/NEWS
index e1aacdc22..a97440e59 100644
--- a/NEWS
+++ b/NEWS
@@ -20,6 +20,7 @@ PostgreSQL 12-18 required. GEOS 3.8+ required. Proj 6.1+ required.
- #5829, geometry_columns with non-standard constraints (Paul Ramsey)
- #5818, GT-244 Fix CG_IsSolid function (Loïc Bartoletti)
- #5885, Fix documentation about grid-based overlay operations (Sandro Santilli)
+- For SFCGAL 2.1.0+ prevent using deprecated functions (Regina Obe)
PostGIS 3.5.2
2025/01/18
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index a56cfda34..003fce43d 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -25,6 +25,8 @@
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5829">5829</link>, geometry_columns with non-standard constraints (Paul Ramsey)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5818">5818</link>, <link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/244">GT-244</link> Fix CG_IsSolid function (Loïc Bartoletti)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5885">5885</link>, Fix documentation about grid-based overlay operations (Sandro Santilli)</para>
+ <para>For SFCGAL 2.1.0+ prevent using deprecated functions (Regina Obe)</para>
+ </simplesect>
</simplesect>
</section>
<section>
diff --git a/liblwgeom/lwgeom_sfcgal.c b/liblwgeom/lwgeom_sfcgal.c
index 2e6d11e23..6fe4c8890 100644
--- a/liblwgeom/lwgeom_sfcgal.c
+++ b/liblwgeom/lwgeom_sfcgal.c
@@ -26,12 +26,14 @@
#include <stdio.h>
#if POSTGIS_SFCGAL_VERSION >= 20100
-#define sfcgal_triangulated_surface_num_triangles(g) sfcgal_geometry_num_geometries((g))
-#define sfcgal_triangulated_surface_triangle_n(g,i) sfcgal_geometry_get_geometry_n((g), (i))
-#define sfcgal_polyhedral_surface_num_polygons(g) sfcgal_geometry_num_geometries((g))
-#define sfcgal_polyhedral_surface_polygon_n(g,i) sfcgal_geometry_get_geometry_n((g), (i))
+#define sfcgal_triangulated_surface_num_triangles(g) sfcgal_geometry_num_patches((g))
+#define sfcgal_triangulated_surface_triangle_n(g,i) sfcgal_triangulated_surface_patch_n((g), (i))
+#define sfcgal_triangulated_surface_add_triangle(g, p) sfcgal_triangulated_surface_add_patch((g), (p))
+#define sfcgal_polyhedral_surface_num_polygons(g) sfcgal_polyhedral_surface_num_patches((g))
+#define sfcgal_polyhedral_surface_polygon_n(g,i) sfcgal_polyhedral_surface_patch_n((g), (i))
#define sfcgal_geometry_collection_num_geometries(g) sfcgal_geometry_num_geometries((g))
-#define sfcgal_geometry_collection_geometry_n(g,i) sfcgal_geometry_get_geometry_n((g), (i))
+#define sfcgal_geometry_collection_geometry_n(g,i) sfcgal_geometry_get_geometry_n((g), (i))
+#define sfcgal_polyhedral_surface_add_polygon(g, p) sfcgal_polyhedral_surface_add_patch((g), (p))
#endif
static int SFCGAL_type_to_lwgeom_type(sfcgal_geometry_type_t type);
Summary of changes:
NEWS | 1 +
doc/release_notes.xml | 2 ++
liblwgeom/lwgeom_sfcgal.c | 12 +++++++-----
3 files changed, 10 insertions(+), 5 deletions(-)
hooks/post-receive
