[SCM] PostGIS branch master updated. 3.5.0-328-g4be6f1b88
Fri May 16 20:56:40 PDT 2025
the project "PostGIS".
       via  4be6f1b88a6fd8e35f9c7081b6a00c44fe964973 (commit)
      from  4dbb16abff83a66f9d24dc76324959320e0842c9 (commit)
revisions in full, below.
commit 4be6f1b88a6fd8e35f9c7081b6a00c44fe964973
Author: Regina Obe <lr at pcorp.us>
Date:   Fri May 16 23:56:34 2025 -0400
    Prepping for 3.6.0alpha1 release
diff --git a/NEWS b/NEWS
index eea4d2d61..3c2d589e9 100644
--- a/NEWS
+++ b/NEWS
@@ -1,10 +1,9 @@
-PostGIS 3.6.0
-2025/xx/xx
+PostGIS 3.6.0alpha1
+2025/05/16
-* Bug fixes *
-  - #5818, GT-244 Fix CG_IsSolid function (Loïc Bartoletti)
-  - #5872, GH-796 Fix tests and results for SK Partition (Loïc Bartoletti)
+This version requires PostgreSQL 12-18beta1, GEOS 3.8 or higher, and Proj 6.1+.
+To take advantage of all features, GEOS 3.12+ is needed.
+To take advantage of all SFCGAL features, SFCGAL 2.1+ is needed.
 * Breaking Changes *
@@ -16,17 +15,17 @@ PostGIS 3.6.0
 * New Features *
-  - GH-803, ADD CG_Simplify function (Loïc Bartoletti)
-  - GH-805, Add M support for SFCGAL >= 1.5.0 (Loïc Bartoletti)
-  - GH-801, ADD CG_3DAlphaWrapping function (Jean Felder)
-  - #5894, TotalTopologySize (Sandro Santilli)
-  - #5890, ValidateTopologyPrecision, MakeTopologyPrecise (Sandro Santilli)
-  - #5861, Add --drop-topology switch to pgtopo_import (Sandro Santilli)
-  - #1247, ST_AsRasterAgg (Sandro Santilli)
+  - GH-803, [sfcgal] ADD CG_Simplify function (Loïc Bartoletti)
+  - GH-805, [sfcgal] Add M support for SFCGAL >= 1.5.0 (Loïc Bartoletti)
+  - GH-801, [sfcgal] ADD CG_3DAlphaWrapping function (Jean Felder)
+  - #5894, [topology] TotalTopologySize (Sandro Santilli)
+  - #5890, [topology] ValidateTopologyPrecision, MakeTopologyPrecise (Sandro Santilli)
+  - #5861, [topology] Add --drop-topology switch to pgtopo_import (Sandro Santilli)
+  - #1247, [raster] ST_AsRasterAgg (Sandro Santilli)
   - #5784, GT-223 Export circ_tree_distance_tree_internal for mobilitydb use
            (Maxime Schoemans)
-  - GT-228 Add new functions (Scale, Translate, Rotate, Buffer 3D and
+  - GT-228 [sfcgal] Add new functions (Scale, Translate, Rotate, Buffer 3D and
            Straight Skeleton Partition) from SFCGAL 2 (Loïc Bartoletti)
-  - New GUC postgis.gdal_cpl_debug, enables GDAL debugging messages
+  - [raster] New GUC postgis.gdal_cpl_debug, enables GDAL debugging messages
     and routes them into the PostgreSQL logging system. (Paul Ramsey)
-  - #5841, Change interrupt handling to remove use of pqsignal (Paul Ramsey)
+  - #5841, Change interrupt handling to remove use of pqsignal to support PG 18 (Paul Ramsey)
\ No newline at end of file
diff --git a/README.postgis b/README.postgis
index 740c19207..135d4768b 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.5.0
-:Date: 2024-09-25
+:Version: 3.6.0alpha1
+:Date: 2025-05-17
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
@@ -104,9 +104,8 @@ For apt-based systems you can run this command to install the below dependencies
   with raster support. To compile without raster support you
   must ``./configure --without-raster``
-* CGAL 4.1+ and SFCGAL 1.3.2+ (Optional) needed for advanced 3D support
-* SFCGAL 1.4.1+ is requires for additional functionality ST_AlphaShape, ST_OptimalAlphaShape,
-  and ST_3DConvexhull
+* CGAL 5+ and SFCGAL 1.4+ (Optional) needed for advanced 3D support
+* SFCGAL 2.1.0 is required for additional functionality.
   https://gitlab.com/sfcgal/SFCGAL
diff --git a/Version.config b/Version.config
index cf6d63e9f..2d5a98a5f 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=6
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0alpha1
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/installation.xml b/doc/installation.xml
index 139a282f9..e690fb2c3 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -246,7 +246,7 @@ sh autogen.sh
 	  <listitem>
 		<para>
-			SFCGAL, 1.4.1 or higher is required and 1.5.0+ is needed to be able to use all functionality. SFCGAL can be used to provide additional 2D and 3D advanced analysis functions to PostGIS cf <xref linkend="reference_sfcgal"/>. And also allow to use SFCGAL rather than GEOS for some 2D functions provided by both backends (like ST_Intersection or ST_Area, for instance). A PostgreSQL configuration variable <code>postgis.backend</code> allow end user to control which backend he want to use if SFCGAL is installed (GEOS by default). Nota: SFCGAL 1.2 require at least CGAL 4.3 and Boost 1.54 (cf: <link xlink:href="https://sfcgal.org">https://sfcgal.org</link>)
+			SFCGAL, 1.4.1 or higher is required and 2.1+ is needed to be able to use all functionality. SFCGAL can be used to provide additional 2D and 3D advanced analysis functions to PostGIS cf <xref linkend="reference_sfcgal"/>. And also allow to use SFCGAL rather than GEOS for some 2D functions provided by both backends (like ST_Intersection or ST_Area, for instance). A PostgreSQL configuration variable <code>postgis.backend</code> allow end user to control which backend he want to use if SFCGAL is installed (GEOS by default). Nota: SFCGAL 1.2 require at least CGAL 4.3 and Boost 1.54 (cf: <link xlink:href="https://sfcgal.org">https://sfcgal.org</link>)
 		  <link xlink:href="https://gitlab.com/sfcgal/SFCGAL/">https://gitlab.com/sfcgal/SFCGAL/</link>.
 		</para>
@@ -254,7 +254,7 @@ sh autogen.sh
 	 <listitem>
 			<para>
-				In order to build the <xref linkend="Address_Standardizer"/> you will also need PCRE <link xlink:href="http://www.pcre.org">http://www.pcre.org</link> (which generally is already installed on nix systems).
+				In order to build the <xref linkend="Address_Standardizer"/> you will also need PCRE 1 or 2 <link xlink:href="http://www.pcre.org">http://www.pcre.org</link> (which generally is already installed on nix systems).
 				<xref linkend="Address_Standardizer"/> will automatically be built if it detects a PCRE library, or you pass in a valid <varname>--with-pcre-dir=/path/to/pcre</varname> during configure.
 			</para>
 		</listitem>
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index e5473ae25..bf9da66bf 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -3,8 +3,32 @@
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
         <section>
-            <title>PostGIS 3.6.0</title>
-            <para>2025/xx/xx</para>
-        </section>
+            <title>PostGIS 3.6.0alpha1</title>
+            <para>2025/05/17</para>
+                        <para>This version requires PostgreSQL 12-18beta1, GEOS 3.8 or higher, and Proj 6.1+.
+            To take advantage of all features, GEOS 3.12+ is needed.
+            To take advantage of all SFCGAL features, SFCGAL 2.1+ is needed.</para>
+            <simplesect><title>Breaking Changes</title>
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5799">#5799</link>, make ST_TileEnvelope clips envelopes to tile plane extent (Paul Ramsey)</para>
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5829">#5829</link>, remove constraint checking from geometry_columns view (Paul Ramsey)</para>
+            </simplesect>
+            <simplesect><title>New Features</title>
+                <para><link xlink:href="https://github.com/postgis/postgis/pull/803">GH-803</link>, [sfcgal] ADD CG_Simplify function (Loïc Bartoletti)</para>
+                <para><link xlink:href="https://github.com/postgis/postgis/pull/805">GH-805</link>, [sfcgal] Add M support for SFCGAL >= 1.5.0 (Loïc Bartoletti)</para>
+                <para><link xlink:href="https://github.com/postgis/postgis/pull/801">GH-801</link>, [sfcgal] ADD CG_3DAlphaWrapping function (Jean Felder)</para>
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5894">#5894</link>, [topology] TotalTopologySize (Sandro Santilli)</para>
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5890">#5890</link>, [topology] ValidateTopologyPrecision, MakeTopologyPrecise (Sandro Santilli)</para>
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5861">#5861</link>, [topology] Add --drop-topology switch to pgtopo_import (Sandro Santilli)</para>
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/1247">#1247</link>, [raster] ST_AsRasterAgg (Sandro Santilli)</para>
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5784">#5784</link>, GT-223 Export circ_tree_distance_tree_internal for mobilitydb use
+                        (Maxime Schoemans)</para>
+                <para><link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/228">GT-228</link> [sfcgal] Add new functions (Scale, Translate, Rotate, Buffer 3D and
+                        Straight Skeleton Partition) from SFCGAL 2 (Loïc Bartoletti)</para>
+                <para>[raster] New GUC postgis.gdal_cpl_debug, enables GDAL debugging messages
+                    and routes them into the PostgreSQL logging system. (Paul Ramsey)</para>
+                <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5841">#5841</link>, Change interrupt handling to remove use of pqsignal to support PG 18 (Paul Ramsey)</para>
+            </simplesect>
+        </section>
 </appendix>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 8223e1631..2063c74a9 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -73,7 +73,7 @@ UPGRADEABLE_VERSIONS = \
 	3.0.11 \
 	3.1.0 \
 	3.1.1 \
-	3.1.2	\
+	3.1.2 \
 	3.1.3 \
 	3.1.4 \
 	3.1.5 \
@@ -84,6 +84,7 @@ UPGRADEABLE_VERSIONS = \
 	3.1.9 \
 	3.1.10 \
 	3.1.11 \
+	3.1.12 \
 	3.2.0 \
 	3.2.1 \
 	3.2.2 \
@@ -92,6 +93,7 @@ UPGRADEABLE_VERSIONS = \
 	3.2.5 \
 	3.2.6 \
 	3.2.7 \
+	3.2.8 \
 	3.3.0 \
 	3.3.1 \
 	3.3.2 \
@@ -100,9 +102,14 @@ UPGRADEABLE_VERSIONS = \
 	3.3.5 \
 	3.3.6 \
 	3.3.7 \
+	3.3.8 \
 	3.4.0 \
 	3.4.1 \
 	3.4.2 \
 	3.4.3 \
-	3.4.4dev \
-	3.5.0
+	3.4.4 \
+	3.5.0 \
+	3.5.1 \
+	3.5.2 \
+	3.5.3 \
+	3.6.0dev
Summary of changes:
 NEWS                               | 31 +++++++++++++++----------------
 README.postgis                     |  9 ++++-----
 Version.config                     |  2 +-
 doc/installation.xml               |  4 ++--
 doc/release_notes.xml              | 30 +++++++++++++++++++++++++++---
 extensions/upgradeable_versions.mk | 13 ++++++++++---
 6 files changed, 59 insertions(+), 30 deletions(-)
hooks/post-receive
