[SCM] PostGIS branch master updated. 3.5.0-330-gab2a9a08d
git at osgeo.org
git at osgeo.org
Sat May 17 17:49:42 PDT 2025
the project "PostGIS".
via ab2a9a08d9865f5eb453acc67314f44e99007883 (commit)
from 1265101c448e5aba7e7a41b13d6677521a4e0ade (commit)
revisions in full, below.
commit ab2a9a08d9865f5eb453acc67314f44e99007883
Author: Regina Obe <lr at pcorp.us>
Date: Sat May 17 20:49:32 2025 -0400
Update pot
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 88c256453..dd6beb79b 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2025-04-28 09:57+0000\n"
+"POT-Creation-Date: 2025-05-18 00:48+0000\n"
"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
"Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -3977,6 +3977,50 @@ msgstr ""
msgid "Availability: 3.2.0"
msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Returns non-precise vertices in the topology."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Returns all vertices that are not rounded to the topology or given "
+"<varname>gridSize</varname> as a puntal geometry, optionally limiting the "
+"check to the area specified by the <varname>bbox</varname> parameter."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.6.0"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Snap topology vertices to precision grid."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Snaps all vertices of a topology to the topology precision grid or to the "
+"grid whose size is specified with the <varname>gridSize</varname> parameter, "
+"optionally limiting the operation to the objects intersecting the area "
+"specified by the <varname>bbox</varname> parameter."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Snapping could make the topology invalid, so it is recommended to check the "
+"outcome of operation with <xref linkend=\"ValidateTopology\"/>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ValidateTopology\"/>"
+msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid "Returns a topology record by different means."
@@ -4001,6 +4045,20 @@ msgid ""
"returns a topology.layer record."
msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Total disk space used by the specified topology, including all indexes and "
+"TOAST data."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Takes a topology name and provides the total disk space used by all its "
+"tables, including indexes and TOAST data."
+msgstr ""
#. Tag: title
#, no-c-format
msgid "Topology Statistics Management"
@@ -6371,13 +6429,13 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"SFCGAL, 1.4.1 or higher is required and 1.5.0+ is needed to be able to use "
-"all functionality. SFCGAL can be used to provide additional 2D and 3D "
-"advanced analysis functions to PostGIS cf <xref linkend=\"reference_sfcgal\"/"
-">. And also allow to use SFCGAL rather than GEOS for some 2D functions "
-"provided by both backends (like ST_Intersection or ST_Area, for instance). A "
-"PostgreSQL configuration variable <code>postgis.backend</code> allow end "
-"user to control which backend he want to use if SFCGAL is installed (GEOS by "
+"SFCGAL, 1.4.1 or higher is required and 2.1+ is needed to be able to use all "
+"functionality. SFCGAL can be used to provide additional 2D and 3D advanced "
+"analysis functions to PostGIS cf <xref linkend=\"reference_sfcgal\"/>. And "
+"also allow to use SFCGAL rather than GEOS for some 2D functions provided by "
+"both backends (like ST_Intersection or ST_Area, for instance). A PostgreSQL "
+"configuration variable <code>postgis.backend</code> allow end user to "
+"control which backend he want to use if SFCGAL is installed (GEOS by "
"default). Nota: SFCGAL 1.2 require at least CGAL 4.3 and Boost 1.54 (cf: "
"<link xlink:href=\"https://sfcgal.org\">https://sfcgal.org</link>) <link "
"xlink:href=\"https://gitlab.com/sfcgal/SFCGAL/\">https://gitlab.com/sfcgal/"
@@ -6388,8 +6446,8 @@ msgstr ""
#, no-c-format
msgid ""
"In order to build the <xref linkend=\"Address_Standardizer\"/> you will also "
-"need PCRE <link xlink:href=\"http://www.pcre.org\">http://www.pcre.org</"
-"link> (which generally is already installed on nix systems). <xref "
+"need PCRE 1 or 2 <link xlink:href=\"http://www.pcre.org\">http://www.pcre."
+"org</link> (which generally is already installed on nix systems). <xref "
"linkend=\"Address_Standardizer\"/> will automatically be built if it detects "
"a PCRE library, or you pass in a valid <varname>--with-pcre-dir=/path/to/"
"pcre</varname> during configure."
@@ -14734,11 +14792,6 @@ msgid ""
"or less of it by altering the <code>client_min_message</code> PostgreSQL GUC."
msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Availability: 3.6.0"
-msgstr ""
#. Tag: title
#, no-c-format
msgid "Geometry Input"
@@ -32716,9 +32769,15 @@ msgid ""
"with a specified <parameter>radius</parameter>. The buffer is constructed in "
"3D space, creating a volumetric representation of the geometry's "
"surroundings. The <parameter>segments</parameter> parameter defines the "
-"number of segments used to approximate the curved sections of the buffer. "
-"The <parameter>buffer_type</parameter> specifies the type of buffer to "
-"create: 0: Rounded buffer (default) 1: Flat buffer 2: Square buffer"
+"number of segments used to approximate the curved sections of the buffer, "
+"with a minimum value of 4 segments required. The <parameter>buffer_type</"
+"parameter> specifies the type of buffer to create: 0: Rounded buffer "
+"(default) 1: Flat buffer 2: Square buffer"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Input geometry must be a Point or LineString."
msgstr ""
#. Tag: para
@@ -32951,6 +33010,163 @@ msgid ""
"coordinates."
msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Reduces the complexity of a geometry while preserving essential features and "
+"Z/M values."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Simplifies a geometry using SFCGAL's simplification algorithm, which reduces "
+"the number of points or vertices while preserving the essential features of "
+"the geometry. This function preserves Z and M values during simplification."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The algorithm is based on constrained triangulation and uses the <link xlink:"
+"href=\"https://doc.cgal.org/latest/Polyline_simplification_2/index."
+"html\">CGAL Polyline Simplification 2</link> library with additional "
+"handling to preserve Z and M coordinates. When topology is preserved and "
+"geometries intersect, Z and M values are interpolated at intersection points."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This function works well with 3D terrain-like geometries (2.5D) but is not "
+"designed for vertical surfaces like walls."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.6.0 - requires SFCGAL >= 2.1.0"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Parameters"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Input geometry"
+msgstr ""
+#. Tag: parameter
+#, no-c-format
+msgid "threshold"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Maximum distance threshold (in geometry unit) for simplification. The higher "
+"this value, the more simplified the resulting geometry will be."
+msgstr ""
+#. Tag: parameter
+#, no-c-format
+msgid "preserveTopology"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If set to true, the function ensures that the topology of the geometry is "
+"preserved. When geometries intersect in this mode, Z and M values at "
+"intersection points are interpolated. The default value is false."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Return Value"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Returns a simplified geometry with preserved Z and M values."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Originals geometries"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Simplification with 0.5 and topology preserved"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Simplification with 0.5 without topology preservation"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_SimplifyPreserveTopology\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Computes a 3D Alpha-wrapping strictly enclosing a geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Computes the <link xlink:href=\"https://doc.cgal.org/latest/Alpha_wrap_3/"
+"index.html\">3D Alpha Wrapping</link> of the points in a geometry. An alpha "
+"wrapping is a watertight and orientable surface mesh that strictly encloses "
+"the input. It can be seen as an extension or refinement of an <link "
+"linkend=\"CG_AlphaShape\">alpha-shape</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The <varname>relative_alpha</varname> parameter controls which features will "
+"appear in the output. It can can have values from 0 to infinity. Smaller "
+"relative_alpha values result in simpler outputs, but they are less accurate "
+"representations of the original input."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The <varname>relative_offset</varname> parameter controls the tightness of "
+"the result. It can can have values from 0 to infinity. If this parameter is "
+"set to 0, its value is automatically determined based on the relative_alpha "
+"parameter."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Alpha wrapping of a MultiPoint (same example As <xref "
+"linkend=\"CG_OptimalAlphaShape\"/>)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Alpha wrapping of a MultiPoint (same example as <xref "
+"linkend=\"ST_ConcaveHull\"/>)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Effect of the <varname>relative_alpha</varname> parameter with values 5, 10 "
+"and 20. A value of 5 results in a coarse output. Increasing the parameter up "
+"to 20 significantly improves the precision and granularity of the result."
+msgstr ""
#. Tag: title
#, no-c-format
msgid "Spatial Reference System Functions"
@@ -34737,12 +34953,128 @@ msgstr ""
#. Tag: title
#, no-c-format
-msgid "PostGIS 3.6.0"
+msgid "PostGIS 3.6.0alpha1"
msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/05/17"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This version requires PostgreSQL 12-18beta1, GEOS 3.8 or higher, and Proj "
+"6.1+. To take advantage of all features, GEOS 3.12+ is needed. To take "
+"advantage of all SFCGAL features, SFCGAL 2.1+ is needed."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Breaking Changes"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5799\">#5799</"
+"link>, make ST_TileEnvelope clips envelopes to tile plane extent (Paul "
+"Ramsey)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5829\">#5829</"
+"link>, remove constraint checking from geometry_columns view (Paul Ramsey)"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "New Features"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/803\">GH-803</"
+"link>, [sfcgal] ADD CG_Simplify function (Loïc Bartoletti)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/805\">GH-805</"
+"link>, [sfcgal] Add M support for SFCGAL >= 1.5.0 (Loïc Bartoletti)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/801\">GH-801</"
+"link>, [sfcgal] ADD CG_3DAlphaWrapping function (Jean Felder)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5894\">#5894</"
+"link>, [topology] TotalTopologySize (Sandro Santilli)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5890\">#5890</"
+"link>, [topology] ValidateTopologyPrecision, MakeTopologyPrecise (Sandro "
+"Santilli)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5861\">#5861</"
+"link>, [topology] Add --drop-topology switch to pgtopo_import (Sandro "
+"Santilli)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/1247\">#1247</"
+"link>, [raster] ST_AsRasterAgg (Sandro Santilli)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5784\">#5784</"
+"link>, GT-223 Export circ_tree_distance_tree_internal for mobilitydb use "
+"(Maxime Schoemans)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://git.osgeo.org/gitea/postgis/postgis/"
+"pulls/228\">GT-228</link> [sfcgal] Add new functions (Scale, Translate, "
+"Rotate, Buffer 3D and Straight Skeleton Partition) from SFCGAL 2 (Loïc "
+"Bartoletti)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"[raster] New GUC postgis.gdal_cpl_debug, enables GDAL debugging messages and "
+"routes them into the PostgreSQL logging system. (Paul Ramsey)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5841\">#5841</"
+"link>, Change interrupt handling to remove use of pqsignal to support PG 18 "
+"(Paul Ramsey)"
msgstr ""
#. Tag: title
Summary of changes:
doc/po/templates/postgis-manual.pot | 372 ++++++++++++++++++++++++++++++++++--
1 file changed, 352 insertions(+), 20 deletions(-)
hooks/post-receive
