[SCM] PostGIS branch master updated. 3.6.0alpha1-2-g1f6ac5119
Sat May 17 18:44:04 PDT 2025
the project "PostGIS".
       via  1f6ac51198cd6ec5ee48cd657adac94f783dd7e7 (commit)
      from  ad5f672665fe2fdb87fd5c8132f879ec154fd7bc (commit)
revisions in full, below.
commit 1f6ac51198cd6ec5ee48cd657adac94f783dd7e7
Author: Regina Obe <lr at pcorp.us>
Date:   Sat May 17 21:43:09 2025 -0400
    - Second pass trying to fix woodpecker, remove sub events
    - Fix cg_3dalphawrapping images
    - move cg_3dlaphawapping03.png to static folder
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 776cbd619..cc2ff5cad 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -1,17 +1,19 @@
 labels:
   platform: linux/amd64
+when:
+  event: [push, pull_request, tag]
 variables:
   - &test_image 'repo.osgeo.org/postgis/build-test:universal'
   - common_doc_paths: &common_doc_paths
       # related config files
       - ".woodpecker/docs.yml"
       # Makefiles
-      - "doc/Makefile.in"
-      - "doc/html/images/Makefile.in"
+      #- "doc/Makefile.in"
+      #- "doc/html/images/Makefile.in"
       # XML sources
-      - "doc/*.xml"
+      #- "doc/*.xml"
       # Internationalization Makefiles
-      - "doc/po/Makefile.local"
+      #- "doc/po/Makefile.local"
   - &when_path
       include:
         - <<: *common_doc_paths
@@ -19,8 +21,8 @@ variables:
       include:
         # Any localized assets
-        - "doc/po/*/Makefile.in"
-        - "doc/po/*/*.po"
+        #- "doc/po/*/Makefile.in"
+        #- "doc/po/*/*.po"
 steps:
   prepare:
@@ -33,8 +35,7 @@ steps:
       - make postgis_revision.h
       - xmllint --version
     when:
-        - event: [tag, pull_request, push]
-          path: *when_path_full
+      - path: *when_path_full
   check-xml:
     image: *test_image
@@ -44,7 +45,6 @@ steps:
       - make -C build-docs/doc check
     when:
   build-images:
     image: *test_image
     pull: true
@@ -53,7 +53,6 @@ steps:
       - make -C build-docs/doc images
     when:
   build-html:
     image: *test_image
     pull: true
@@ -62,7 +61,6 @@ steps:
       - make -C build-docs/doc html
     when:
       - path: *when_path
   build-cheatsheets:
     image: *test_image
     pull: true
@@ -71,7 +69,6 @@ steps:
       - make -C build-docs/doc/ cheatsheets
     when:
   build-chunked-html:
     image: *test_image
     pull: true
@@ -80,7 +77,6 @@ steps:
     when:
       - path: *when_path
   build-pdf:
     image: *test_image
     pull: true
@@ -89,7 +85,6 @@ steps:
       - make -C build-docs/doc/ pdf
     when:
       - path: *when_path
   # DO NOT EDIT PAST THIS LINE, use update-docs-localized.sh to update #
 ### TARGET check-xml
@@ -100,8 +95,7 @@ steps:
       - make -C build-docs/doc/po/it_IT local-check-xml
     depends_on: prepare
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/it_IT/*.po"
@@ -112,8 +106,7 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-check-xml
     depends_on: prepare
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/pt_BR/*.po"
@@ -124,8 +117,7 @@ steps:
       - make -C build-docs/doc/po/fr local-check-xml
     depends_on: prepare
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/fr/*.po"
@@ -136,8 +128,7 @@ steps:
       - make -C build-docs/doc/po/es local-check-xml
     depends_on: prepare
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/es/*.po"
@@ -148,8 +139,7 @@ steps:
       - make -C build-docs/doc/po/pl local-check-xml
     depends_on: prepare
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/pl/*.po"
@@ -160,8 +150,7 @@ steps:
       - make -C build-docs/doc/po/ka local-check-xml
     depends_on: prepare
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ka/*.po"
@@ -172,8 +161,7 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-check-xml
     depends_on: prepare
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ko_KR/*.po"
@@ -184,8 +172,7 @@ steps:
       - make -C build-docs/doc/po/da local-check-xml
     depends_on: prepare
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/da/*.po"
@@ -196,8 +183,7 @@ steps:
       - make -C build-docs/doc/po/de local-check-xml
     depends_on: prepare
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/de/*.po"
@@ -208,8 +194,7 @@ steps:
       - make -C build-docs/doc/po/ja local-check-xml
     depends_on: prepare
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ja/*.po"
@@ -220,8 +205,7 @@ steps:
       - make -C build-docs/doc/po/ru local-check-xml
     depends_on: prepare
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ru/*.po"
@@ -232,8 +216,7 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-check-xml
     depends_on: prepare
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/zh_Hans/*.po"
@@ -244,8 +227,7 @@ steps:
       - make -C build-docs/doc/po/ro local-check-xml
     depends_on: prepare
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ro/*.po"
@@ -256,8 +238,7 @@ steps:
       - make -C build-docs/doc/po/uk local-check-xml
     depends_on: prepare
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/uk/*.po"
@@ -269,8 +250,7 @@ steps:
       - make -C build-docs/doc/po/it_IT local-html
     depends_on: check-xml-it_IT
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -281,8 +261,7 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-html
     depends_on: check-xml-pt_BR
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -293,8 +272,7 @@ steps:
       - make -C build-docs/doc/po/fr local-html
     depends_on: check-xml-fr
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/fr/*.po"
@@ -305,8 +283,7 @@ steps:
       - make -C build-docs/doc/po/es local-html
     depends_on: check-xml-es
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/es/*.po"
@@ -317,8 +294,7 @@ steps:
       - make -C build-docs/doc/po/pl local-html
     depends_on: check-xml-pl
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/pl/*.po"
@@ -329,8 +305,7 @@ steps:
       - make -C build-docs/doc/po/ka local-html
     depends_on: check-xml-ka
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ka/*.po"
@@ -341,8 +316,7 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-html
     depends_on: check-xml-ko_KR
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -353,8 +327,7 @@ steps:
       - make -C build-docs/doc/po/da local-html
     depends_on: check-xml-da
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/da/*.po"
@@ -365,8 +338,7 @@ steps:
       - make -C build-docs/doc/po/de local-html
     depends_on: check-xml-de
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/de/*.po"
@@ -377,8 +349,7 @@ steps:
       - make -C build-docs/doc/po/ja local-html
     depends_on: check-xml-ja
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ja/*.po"
@@ -389,8 +360,7 @@ steps:
       - make -C build-docs/doc/po/ru local-html
     depends_on: check-xml-ru
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ru/*.po"
@@ -401,8 +371,7 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-html
     depends_on: check-xml-zh_Hans
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -413,8 +382,7 @@ steps:
       - make -C build-docs/doc/po/ro local-html
     depends_on: check-xml-ro
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ro/*.po"
@@ -425,8 +393,7 @@ steps:
       - make -C build-docs/doc/po/uk local-html
     depends_on: check-xml-uk
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/uk/*.po"
@@ -438,8 +405,7 @@ steps:
       - make -C build-docs/doc/po/it_IT local-cheatsheets
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -450,8 +416,7 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-cheatsheets
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -462,8 +427,7 @@ steps:
       - make -C build-docs/doc/po/fr local-cheatsheets
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/fr/*.po"
@@ -474,8 +438,7 @@ steps:
       - make -C build-docs/doc/po/es local-cheatsheets
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/es/*.po"
@@ -486,8 +449,7 @@ steps:
       - make -C build-docs/doc/po/pl local-cheatsheets
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/pl/*.po"
@@ -498,8 +460,7 @@ steps:
       - make -C build-docs/doc/po/ka local-cheatsheets
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ka/*.po"
@@ -510,8 +471,7 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-cheatsheets
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -522,8 +482,7 @@ steps:
       - make -C build-docs/doc/po/da local-cheatsheets
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/da/*.po"
@@ -534,8 +493,7 @@ steps:
       - make -C build-docs/doc/po/de local-cheatsheets
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/de/*.po"
@@ -546,8 +504,7 @@ steps:
       - make -C build-docs/doc/po/ja local-cheatsheets
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ja/*.po"
@@ -558,8 +515,7 @@ steps:
       - make -C build-docs/doc/po/ru local-cheatsheets
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ru/*.po"
@@ -570,8 +526,7 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-cheatsheets
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -582,8 +537,7 @@ steps:
       - make -C build-docs/doc/po/ro local-cheatsheets
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ro/*.po"
@@ -594,8 +548,7 @@ steps:
       - make -C build-docs/doc/po/uk local-cheatsheets
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/uk/*.po"
@@ -607,8 +560,7 @@ steps:
       - make -C build-docs/doc/po/it_IT local-check-cheatsheets
     depends_on: [ cheatsheets-it_IT, build-cheatsheets ]
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -619,8 +571,7 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-check-cheatsheets
     depends_on: [ cheatsheets-pt_BR, build-cheatsheets ]
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -631,8 +582,7 @@ steps:
       - make -C build-docs/doc/po/fr local-check-cheatsheets
     depends_on: [ cheatsheets-fr, build-cheatsheets ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/fr/*.po"
@@ -643,8 +593,7 @@ steps:
       - make -C build-docs/doc/po/es local-check-cheatsheets
     depends_on: [ cheatsheets-es, build-cheatsheets ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/es/*.po"
@@ -655,8 +604,7 @@ steps:
       - make -C build-docs/doc/po/pl local-check-cheatsheets
     depends_on: [ cheatsheets-pl, build-cheatsheets ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/pl/*.po"
@@ -667,8 +615,7 @@ steps:
       - make -C build-docs/doc/po/ka local-check-cheatsheets
     depends_on: [ cheatsheets-ka, build-cheatsheets ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ka/*.po"
@@ -679,8 +626,7 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-check-cheatsheets
     depends_on: [ cheatsheets-ko_KR, build-cheatsheets ]
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -691,8 +637,7 @@ steps:
       - make -C build-docs/doc/po/da local-check-cheatsheets
     depends_on: [ cheatsheets-da, build-cheatsheets ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/da/*.po"
@@ -703,8 +648,7 @@ steps:
       - make -C build-docs/doc/po/de local-check-cheatsheets
     depends_on: [ cheatsheets-de, build-cheatsheets ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/de/*.po"
@@ -715,8 +659,7 @@ steps:
       - make -C build-docs/doc/po/ja local-check-cheatsheets
     depends_on: [ cheatsheets-ja, build-cheatsheets ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ja/*.po"
@@ -727,8 +670,7 @@ steps:
       - make -C build-docs/doc/po/ru local-check-cheatsheets
     depends_on: [ cheatsheets-ru, build-cheatsheets ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ru/*.po"
@@ -739,8 +681,7 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-check-cheatsheets
     depends_on: [ cheatsheets-zh_Hans, build-cheatsheets ]
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -751,8 +692,7 @@ steps:
       - make -C build-docs/doc/po/ro local-check-cheatsheets
     depends_on: [ cheatsheets-ro, build-cheatsheets ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ro/*.po"
@@ -763,8 +703,7 @@ steps:
       - make -C build-docs/doc/po/uk local-check-cheatsheets
     depends_on: [ cheatsheets-uk, build-cheatsheets ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/uk/*.po"
@@ -776,8 +715,7 @@ steps:
       - make -C build-docs/doc/po/it_IT local-pdf
     depends_on: [ build-images, check-xml-it_IT ]
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -788,8 +726,7 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-pdf
     depends_on: [ build-images, check-xml-pt_BR ]
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -800,8 +737,7 @@ steps:
       - make -C build-docs/doc/po/fr local-pdf
     depends_on: [ build-images, check-xml-fr ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/fr/*.po"
@@ -812,8 +748,7 @@ steps:
       - make -C build-docs/doc/po/es local-pdf
     depends_on: [ build-images, check-xml-es ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/es/*.po"
@@ -824,8 +759,7 @@ steps:
       - make -C build-docs/doc/po/pl local-pdf
     depends_on: [ build-images, check-xml-pl ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/pl/*.po"
@@ -836,8 +770,7 @@ steps:
       - make -C build-docs/doc/po/ka local-pdf
     depends_on: [ build-images, check-xml-ka ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ka/*.po"
@@ -848,8 +781,7 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-pdf
     depends_on: [ build-images, check-xml-ko_KR ]
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -860,8 +792,7 @@ steps:
       - make -C build-docs/doc/po/da local-pdf
     depends_on: [ build-images, check-xml-da ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/da/*.po"
@@ -872,8 +803,7 @@ steps:
       - make -C build-docs/doc/po/de local-pdf
     depends_on: [ build-images, check-xml-de ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/de/*.po"
@@ -884,8 +814,7 @@ steps:
       - make -C build-docs/doc/po/ja local-pdf
     depends_on: [ build-images, check-xml-ja ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ja/*.po"
@@ -896,8 +825,7 @@ steps:
       - make -C build-docs/doc/po/ru local-pdf
     depends_on: [ build-images, check-xml-ru ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ru/*.po"
@@ -908,8 +836,7 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-pdf
     depends_on: [ build-images, check-xml-zh_Hans ]
     when:
-      - event: push
-        path:
+       - path:
           include:
@@ -920,8 +847,7 @@ steps:
       - make -C build-docs/doc/po/ro local-pdf
     depends_on: [ build-images, check-xml-ro ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/ro/*.po"
@@ -932,8 +858,7 @@ steps:
       - make -C build-docs/doc/po/uk local-pdf
     depends_on: [ build-images, check-xml-uk ]
     when:
-      - event: push
-        path:
+       - path:
           include:
             - "doc/po/uk/*.po"
diff --git a/doc/html/images/Makefile.in b/doc/html/images/Makefile.in
index 6781621dd..a0cb8de14 100644
--- a/doc/html/images/Makefile.in
+++ b/doc/html/images/Makefile.in
@@ -38,12 +38,12 @@ STATIC_IMAGES_SRC = $(wildcard $(srcdir)/static/*.png $(srcdir)/static/*.gif)
 STATIC_IMAGES = $(subst $(srcdir)/static/,,$(STATIC_IMAGES_SRC))
 GENERATED_IMAGES= \
-	cg_3dalphawrapping01.wkt \
-	cg_3dalphawrapping02.wkt \
-  cg_approxconvexpartition01.png \
+	cg_3dalphawrapping01.png \
+	cg_3dalphawrapping02.png \
+    cg_approxconvexpartition01.png \
 	cg_greeneapproxconvexpartition01.png \
 	cg_optimalconvexpartition01.png \
-  cg_visibility01.png \
+    cg_visibility01.png \
 	cg_visibility02.png \
 	cg_visibility03.png \
 	cg_ymonotonepartition01.png \
diff --git a/doc/html/images/cg_3dalphawrapping03.png b/doc/html/images/static/cg_3dalphawrapping03.png
similarity index 100%
rename from doc/html/images/cg_3dalphawrapping03.png
rename to doc/html/images/static/cg_3dalphawrapping03.png
Summary of changes:
 .woodpecker/docs.yml                               | 233 +++++++--------------
 doc/html/images/Makefile.in                        |   8 +-
 .../images/{ => static}/cg_3dalphawrapping03.png   | Bin
 3 files changed, 83 insertions(+), 158 deletions(-)
 rename doc/html/images/{ => static}/cg_3dalphawrapping03.png (100%)
hooks/post-receive
