[SCM] PostGIS branch master updated. 3.5.0-336-geb35c954f
git at osgeo.org
git at osgeo.org
Sun May 18 19:47:56 PDT 2025
the project "PostGIS".
via eb35c954fb90b780b24b4a5776e0cbf73eefa920 (commit)
via cb4c12fad196821480f900fe900487cf3709e1cf (commit)
from 0b083e0866a0663f11e76a24f1b59f08b37b9533 (commit)
revisions in full, below.
commit eb35c954fb90b780b24b4a5776e0cbf73eefa920
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Mon May 19 01:27:46 2025 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 99.1% (5757 of 5807 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 8c093806c..4426ce1bd 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-05-18 00:48+0000\n"
"PO-Revision-Date: 2025-05-19 02:47+0000\n"
-"Last-Translator: Weblate <noreply-mt-weblate at weblate.org>\n"
+"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/ja/>\n"
"Language: ja\n"
@@ -5078,7 +5078,7 @@ msgstr "Availability: 3.2.0"
#. Tag: refpurpose
#, no-c-format
msgid "Returns non-precise vertices in the topology."
-msgstr ""
+msgstr "トポロジ内の低精度の頂点を返します。"
#. Tag: para
#, no-c-format
@@ -5087,6 +5087,9 @@ msgid ""
"<varname>gridSize</varname> as a puntal geometry, optionally limiting the "
"check to the area specified by the <varname>bbox</varname> parameter."
msgstr ""
+"トポロジまたは与えられた<varname>gridSize</varname>に丸められた頂点のすべてを"
+"点じおめとりで返します。任意で、確認範囲を<varname>bbox</varname>パラメータで"
+"指定される範囲に制限できます。"
#. Tag: para
#, no-c-format
commit cb4c12fad196821480f900fe900487cf3709e1cf
Author: Weblate <noreply-mt-weblate at weblate.org>
Date: Mon May 19 01:22:36 2025 +0000
index 740abaef4..8c093806c 100644
@@ -3,15 +3,16 @@
# Teramoto Ikuhiro <yellow at affrc.go.jp>, 2023, 2024, 2025.
# Yoichi Kayama <yoichi.kayama at gmail.com>, 2024.
+# Weblate <noreply-mt-weblate at weblate.org>, 2025.
msgid ""
msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2025-05-12 01:47+0000\n"
-"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
-"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
-"manual/ja/>\n"
+"PO-Revision-Date: 2025-05-19 02:47+0000\n"
+"Last-Translator: Weblate <noreply-mt-weblate at weblate.org>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/ja/>\n"
"Language: ja\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
@@ -41112,7 +41113,7 @@ msgstr ""
#. Tag: title
#, no-c-format
msgid "Parameters"
-msgstr ""
+msgstr "パラメータ"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 14 +++++++++-----
1 file changed, 9 insertions(+), 5 deletions(-)
hooks/post-receive
