[SCM] PostGIS branch master updated. 3.5.0-337-g48ae03a49
Mon May 19 06:40:49 PDT 2025
the project "PostGIS".
       via  48ae03a49c32d0bccab2d7578dfaef70d22e1f41 (commit)
      from  eb35c954fb90b780b24b4a5776e0cbf73eefa920 (commit)
revisions in full, below.
commit 48ae03a49c32d0bccab2d7578dfaef70d22e1f41
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Fri May 16 09:16:43 2025 +0200
    ci(FreeBSD): Bump PostgreSQL version to 17
diff --git a/.cirrus.yml b/.cirrus.yml
index d6eafbf66..25feb7449 100644
--- a/.cirrus.yml
+++ b/.cirrus.yml
@@ -24,11 +24,11 @@ task:
   pkg_cache:
     folder: /var/cache/pkg
     populate_script:
-      pkg fetch -udy autoconf automake bison cunit docbook gdal geos gmake iconv json-c libtool libxml2 libxslt pcre2 pkgconf postgresql13-contrib postgresql13-server proj protobuf-c sfcgal
+      pkg fetch -udy autoconf automake bison cunit docbook gdal geos gmake iconv json-c libtool libxml2 libxslt pcre2 pkgconf postgresql17-contrib postgresql17-server proj protobuf-c sfcgal
   install_pkgs_script:
       env IGNORE_OSVERSION=yes pkg update -f
-      env IGNORE_OSVERSION=yes pkg install -y autoconf automake bison cunit docbook gdal geos gmake iconv json-c libtool libxml2 libxslt pcre2 pkgconf postgresql13-contrib postgresql13-server proj protobuf-c sfcgal
+      env IGNORE_OSVERSION=yes pkg install -y autoconf automake bison cunit docbook gdal geos gmake iconv json-c libtool libxml2 libxslt pcre2 pkgconf postgresql17-contrib postgresql17-server proj protobuf-c sfcgal
       projsync --system-directory --source-id us_noaa
       projsync --system-directory --source-id ch_swisstopo
   ccache_setup_script:
Summary of changes:
 .cirrus.yml | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
