[SCM] PostGIS branch master updated. 3.5.0-339-geb3e529da
git at osgeo.org
git at osgeo.org
Mon May 19 20:47:55 PDT 2025
the project "PostGIS".
via eb3e529da7cb94f265da953a94c1348955950e2e (commit)
from 5c0f689b30e0606377b3e1da0759b987c85107d5 (commit)
revisions in full, below.
commit eb3e529da7cb94f265da953a94c1348955950e2e
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Tue May 20 02:36:27 2025 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 99.5% (5778 of 5807 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 7765c21d3..9b9a966c3 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-05-18 00:48+0000\n"
-"PO-Revision-Date: 2025-05-20 01:47+0000\n"
+"PO-Revision-Date: 2025-05-20 03:47+0000\n"
"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/ja/>\n"
@@ -41167,19 +41167,20 @@ msgstr "入力ジオメトリ"
#. Tag: parameter
#, no-c-format
msgid "threshold"
-msgstr ""
+msgstr "threshold"
#. Tag: para
#, no-c-format
msgid ""
"Maximum distance threshold (in geometry unit) for simplification. The higher "
"this value, the more simplified the resulting geometry will be."
-msgstr ""
+msgstr "単純化に関する最大距離のしきい値 "
+"(ジオメトリの単位)。この値が大きいほど結果ジオメトリが単純になります。"
#. Tag: parameter
#, no-c-format
msgid "preserveTopology"
-msgstr ""
+msgstr "preserveTopology"
#. Tag: para
#, no-c-format
@@ -41188,31 +41189,34 @@ msgid ""
"preserved. When geometries intersect in this mode, Z and M values at "
"intersection points are interpolated. The default value is false."
msgstr ""
+"TRUEに設定すると、この関数はジオメトリのトポロジを確実に保存します。このモー"
+"ドでジオメトリがインタセクとするとき、インタセクとするポイントにおけるZ値とM"
+"値は補完値になります。デフォルト値はFALSEです。"
#. Tag: title
#, no-c-format
msgid "Return Value"
-msgstr ""
+msgstr "返り値"
#. Tag: para
#, no-c-format
msgid "Returns a simplified geometry with preserved Z and M values."
-msgstr ""
+msgstr "Z値とM値を保存した単純化されたジオメトリが返ります。"
#. Tag: para
#, no-c-format
msgid "Originals geometries"
-msgstr ""
+msgstr "元のジオメトリ"
#. Tag: para
#, no-c-format
msgid "Simplification with 0.5 and topology preserved"
-msgstr ""
+msgstr "0.5かつトポロジ保存を指定して単純化したもの"
#. Tag: para
#, no-c-format
msgid "Simplification with 0.5 without topology preservation"
-msgstr ""
+msgstr "0.5だがトポロジ保存なしで単純化したもの"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 22 +++++++++++++---------
1 file changed, 13 insertions(+), 9 deletions(-)
hooks/post-receive
