[SCM] PostGIS branch master updated. 3.5.0-343-g81e2bc783
git at osgeo.org
git at osgeo.org
Wed May 21 00:47:42 PDT 2025
the project "PostGIS".
via 81e2bc783b77cc740291445e992658e1db7179e0 (commit)
from 06211ed384feb2ba7c158a299c7aceaa372a4961 (commit)
revisions in full, below.
commit 81e2bc783b77cc740291445e992658e1db7179e0
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Wed May 21 05:55:24 2025 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 100.0% (5807 of 5807 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 643b52a91..7a9a80305 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-05-18 00:48+0000\n"
-"PO-Revision-Date: 2025-05-21 05:47+0000\n"
+"PO-Revision-Date: 2025-05-21 07:47+0000\n"
"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/ja/>\n"
@@ -40822,7 +40822,7 @@ msgid "Computes a 3D buffer around a geometry."
msgstr "ジオメトリの周りの3次元バッファを計算します。"
#. Tag: para
-#, fuzzy, no-c-format
+#, no-c-format
msgid ""
"Generates a 3D buffer around the input geometry <parameter>geom</parameter> "
"with a specified <parameter>radius</parameter>. The buffer is constructed in "
@@ -41117,7 +41117,7 @@ msgid ""
msgstr "主要な地物とZ/M値を維持しつつジオメトリの複雑さを減らします。"
#. Tag: para
+#, no-c-format
msgid ""
"Simplifies a geometry using SFCGAL's simplification algorithm, which reduces "
"the number of points or vertices while preserving the essential features of "
@@ -41128,7 +41128,7 @@ msgstr ""
"します。"
#. Tag: para
+#, no-c-format
msgid ""
"The algorithm is based on constrained triangulation and uses the <link xlink:"
"href=\"https://doc.cgal.org/latest/Polyline_simplification_2/index."
@@ -41138,16 +41138,17 @@ msgid ""
msgstr ""
"アルゴリズムは制約付き三角分割を基にしていて、"
"Z値とM値の保存のための追加操作を持つ<link xlink:href=\"https://doc.cgal.org/"
-"latest/Polyline_simplification_2/index.html\">CGAL Polyline Simplification "
-"2</link>ライブラリを使っています。"
+"latest/Polyline_simplification_2/index.html\">CGAL Polyline Simplification 2<"
+"/link>ライブラリを使っています。トポロジが保存され、ジオメトリどうしがインタ"
+"セクトしているとき、Z値とM値はインタセクトしているポイントで補間されます。"
#. Tag: para
+#, no-c-format
msgid ""
"This function works well with 3D terrain-like geometries (2.5D) but is not "
"designed for vertical surfaces like walls."
-msgstr "この関数は3次元地形のようなジオメトリ (2.5次元)で動作しますが、壁のような垂直"
-"なサーフェス用にはデザインされていません。"
+msgstr "この関数は3次元地形のようなジオメトリ (2."
+"5次元)で動作しますが、壁のような垂直なサーフェス向けには作られていません。"
#. Tag: para
#, no-c-format
@@ -41256,7 +41257,7 @@ msgstr ""
"、元の入力より精度の低い表現になります。"
#. Tag: para
+#, no-c-format
msgid ""
"The <varname>relative_offset</varname> parameter controls the tightness of "
"the result. It can can have values from 0 to infinity. If this parameter is "
@@ -43505,6 +43506,10 @@ msgid ""
"link>, make ST_TileEnvelope clips envelopes to tile plane extent (Paul "
"Ramsey)"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5799\">#5799</"
+"link>, "
+"ST_TileEnvelopeがエンベロープをタイル平面範囲にクリップするようにしました ("
+"Paul Ramseyさん)"
#. Tag: para
#, no-c-format
@@ -43596,6 +43601,10 @@ msgid ""
"link>, GT-223 Export circ_tree_distance_tree_internal for mobilitydb use "
"(Maxime Schoemans)"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5784\">#5784</"
+"link>, GT-223 "
+"MobilityDB利用のためのcirc_tree_distance_tree_internalのエクスポート (Maxime "
+"Schoemansさん)"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 29 +++++++++++++++++++----------
1 file changed, 19 insertions(+), 10 deletions(-)
hooks/post-receive
