[PostGIS] #5901: raster2pgsql does not work with gdal 3.7+ due to new int8 datatype
    trac at osgeo.org
    Thu May 22 06:11:43 PDT 2025
  Reporter:  lstolcman  |      Owner:  pramsey
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS 3.5.4
 Component:  postgis    |    Version:
Resolution:             |   Keywords:
Description changed by lstolcman:
Old description:
> raster2pgsql (python version and compiled version) is failing with gdal
> 3.7 and newer
> I rounded down the issue, it is due to new datatype added in gdal 3.7:
> https://gdal.org/en/stable/development/rfc/rfc87_signed_int8.html
> python version of raster2pgsql does not support GDT_Int8, e.g.:
> https://git.osgeo.org/gitea/postgis/postgis/src/commit/d027c5f62ab4f63ca1618d27edc1c01ac70c9264/raster/scripts/python/raster2pgsql.py#L213
> compiled version seems to not support it either (logs below)
> Issue can be reproduced using docker container of gdal and the python
> version of raster2pgsql.
> Working raster2pgsql.py example:
> 1. download docker image: `docker pull ghcr.io/osgeo/gdal:ubuntu-
> small-3.6.4`
> 2. put example.tif into current directory
> 3. run docker container from current dir (with tif file): `docker run -it
> -v .:/mnt/aaa ghcr.io/osgeo/gdal:ubuntu-small-3.6.4 /bin/bash`
> 4. install postgis in container and enter python console:
> apt update -y
> apt install python3-pip postgis -y --no-install-recommends
> pip install ipython
> cd /mnt/aaa
> ipython --no-autoindent
> 5. paste the code to test the issue:
> from osgeo import gdal
> print(f"{gdal.__version__}")
> org = gdal.Open("example.tif")
> org_band = org.GetRasterBand(1)
> print(f"{org_band.DataType=}")
> output - supported datatype
> In [1]: from osgeo import gdal
>    ...: print(f"{gdal.__version__}")
>    ...: org = gdal.Open("example.tif")
>    ...: org_band = org.GetRasterBand(1)
>    ...: print(f"{org_band.DataType=}")
> 3.6.4
> org_band.DataType=1
> GDAL 3.7 - raster2pgsql.py failing:
> 1. download docker image: `docker run -it -v .:/mnt/aaa
> ghcr.io/osgeo/gdal:ubuntu-small-3.7.0 /bin/bash`
> 2,3,4,5 - as previously
> output - different (new) datatype (int8):
> 3.7.0
> org_band.DataType=14
> the issue in compiled version of raster2pgsql (raster2pgsql.c) can be
> tested using docker (entering into container as above) -
> - `ghcr.io/osgeo/gdal:ubuntu-small-3.8.5` - contains raster2pgsql with
> gdal 3.4
> - `ghcr.io/osgeo/gdal:ubuntu-small-3.9.3` - contains raster2pgsql with
> gdal 3.8
> output from raster2pgsql with gdal 3.4 works fine (converts tif to sql)
> output of raster2pgsql from gdal 3.9.5 docker image fails with a message:
> root at 04421679a038:/mnt/aaa# raster2pgsql example.tif > example.sql
> Processing 1/1: example.tif
> ERROR: rt_pixtype_size: Unknown pixeltype
> 13####################################
> ERROR: rt_raster_from_gdal_dataset: Unknown pixel type for GDAL band
> ERROR: convert_raster: Could not convert VRT dataset to PostGIS
> raster##########
> ERROR: process_rasters: Could not process raster: example.tif
> ERROR: Unable to process rasters
New description:
 3.7 and newer
 small-3.6.4`
 apt update -y
 pip install ipython
 cd /mnt/aaa
 3.6.4
 org_band.DataType=1
 1. download docker image: `docker run -it -v .:/mnt/aaa ghcr.io/osgeo/gdal
 3.7.0
 gdal 3.4
 gdal 3.8
 raster##########
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5901#comment:1>
