[PostGIS] #5903: topology/test/regress/topogeo_addlinestring test_224_out: ERROR: index returned tuples in wrong order
PostGIS trac at osgeo.org
Mon May 26 01:44:25 PDT 2025
 Reporter:  myon     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  high     |  Milestone:  PostGIS 3.5.4
Component:  postgis  |    Version:  3.4.x
 Keywords:           |
 On Debian bullseye (11), PostGIS 3.5.3 fails testing with "ERROR:  index
 returned tuples in wrong order". amd64/arm64/ppc64el are all affected,
 other distribution releases do not exhibit the problem.
 00:16:02.441  /<<PKGBUILDDIR>>/topology/test/regress/topogeo_addlinestring
 .. failed (diff expected obtained: /tmp/pgis_reg/test_224_diff)
 00:16:02.441
 00:16:02.441 --- ./topology/test/regress/topogeo_addlinestring_expected
 2025-05-17 23:24:39.000000000 +0000
 00:16:02.441 +++ /tmp/pgis_reg/test_224_out     2025-05-19
 13:43:57.502952188 +0000
 00:16:02.441 @@ -28,18 +28,10 @@
 00:16:02.442  overlap|E|LINESTRING(35 22,45 22)
 00:16:02.442  overlap|E|LINESTRING(45 22,47 22)
 00:16:02.442  overlap|E|LINESTRING(47 22,49 22)
 00:16:02.442 -cross|34
 00:16:02.442 -cross|35
 00:16:02.442 -cross|N||POINT(44 17)
 00:16:02.442 -cross|N||POINT(47 17.6)
 00:16:02.442 -cross|N||POINT(49 18)
 00:16:02.442 -cross|E|LINESTRING(47 14,47 17.6)
 00:16:02.443 -cross|E|LINESTRING(47 17.6,47 22)
 00:16:02.443 -cross|E|LINESTRING(47 17.6,44 17)
 00:16:02.443 -cross|E|LINESTRING(49 18,47 17.6)
 00:16:02.443 +ERROR:  index returned tuples in wrong order
 Full build log: https://jengus.postgresql.org/job/postgis-
 binaries/415/architecture=amd64,distribution=bullseye/consoleFull#console-
 section-18
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5903>
