[PostGIS] #5903: topology/test/regress/topogeo_addlinestring test_224_out: ERROR: index returned tuples in wrong order
trac at osgeo.org
Mon May 26 08:26:37 PDT 2025
Reporter: myon | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.5.4
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by robe):
@myon,
Is it an issue with 3.6.0alpha1 as well or you haven't tested that?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5903#comment:5>
