[PostGIS] #5907: Server crashes when TopoGeo_AddPolygon is called with POLYGON EMPTY
trac at osgeo.org
Tue May 27 19:54:45 PDT 2025
Reporter: dmyzl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.3
Component: postgis | Version: 3.5.x
Keywords: TopoGeo_AddPolygon crash |
Server crashes when executing the second SQL statement below:
select topology.createtopology('example', 4326, 0);
select topology.topogeo_addpolygon('example', ST_geomfromtext('polygon
empty', 4326), 0); -- database interrupted
select topology.topogeo_addpolygon('example', ST_geomfromtext('polygon ((0
0, 0 1, 1 1, 0 0))', 4326), 0); -- success
postgis_full_version:
POSTGIS="3.5.3 0" [EXTENSION] PGSQL="170" GEOS="3.13.1-CAPI-1.19.2"
SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST 1.74.0" PROJ="9.3.1
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/home/yzl/.local/share/proj
DATABASE_PATH=/home/yzl/project/build_pg_postgis/proj-9.3.1/tmp_install/share/proj/proj.db"
(compiled against PROJ 9.3.1) GDAL="GDAL 3.7.2, released 2023/09/05"
LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
(Internal)" (core procs from "3.5.2 dea6d0a" need upgrade) TOPOLOGY
(topology procs from "3.5.2 dea6d0a" need upgrade) RASTER (raster procs
from "3.5.2 dea6d0a" need upgrade) (sfcgal procs from "3.5.2 dea6d0a" need
upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5907>
