[PostGIS] #5909: Server crashes when ST_ValueCount is called with table and column names but the table is empty
trac at osgeo.org
Tue May 27 20:32:34 PDT 2025
the table is empty
Reporter: dmyzl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.3
Component: postgis | Version: 3.5.x
Keywords: |
The server crashes when executing the following SQL statement
CREATE EXTENSION POSTGIS_RASTER; -- if need
CREATE TABLE dummy_rast(rid integer, rast raster);
select * from st_valuecount('dummy_rast','rast');
postgis_full_version:
POSTGIS="3.5.3 0" [EXTENSION] PGSQL="170" GEOS="3.13.1-CAPI-1.19.2"
SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST 1.74.0" PROJ="9.3.1
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/home/yzl/.local/share/proj
DATABASE_PATH=/home/yzl/project/build_pg_postgis/proj-9.3.1/tmp_install/share/proj/proj.db"
(compiled against PROJ 9.3.1) GDAL="GDAL 3.7.2, released 2023/09/05"
LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
(Internal)" (core procs from "3.5.2 dea6d0a" need upgrade) TOPOLOGY
(topology procs from "3.5.2 dea6d0a" need upgrade) RASTER (raster procs
from "3.5.2 dea6d0a" need upgrade) (sfcgal procs from "3.5.2 dea6d0a" need
upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5909>
