[PostGIS] #5912: ST_GeomFromGML crashes when parsing GML with xlink attributes
PostGIS trac at osgeo.org
Wed May 28 02:21:52 PDT 2025
 Reporter:  dmyzl           |      Owner:  pramsey
     Type:  defect          |     Status:  new
 Priority:  blocker         |  Milestone:  PostGIS 3.5.4
Component:  postgis         |    Version:  3.5.x
 Keywords:  ST_GeomFromGML  |
 The `ST_GeomFromGML` function crashes when parsing GML that contains
 `xlink` attributes. For example, the following SQL causes the server to
 crash:
 select st_geomfromgml('<gml:Tin xmlns:xlink="http://www.w3.org/1999/xlink"
 xlink:type="simple" xlink:href="#gml"></gml:Tin>');
 postgis_full_version:
 POSTGIS="3.5.3 0" [EXTENSION] PGSQL="170" GEOS="3.13.1-CAPI-1.19.2"
 SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST 1.74.0" PROJ="9.3.1
 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/home/yzl/.local/share/proj
 DATABASE_PATH=/home/yzl/project/build_pg_postgis/proj-9.3.1/tmp_install/share/proj/proj.db"
 (compiled against PROJ 9.3.1) GDAL="GDAL 3.7.2, released 2023/09/05"
 LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
 (Internal)" (core procs from "3.5.2 dea6d0a" need upgrade) TOPOLOGY
 (topology procs from "3.5.2 dea6d0a" need upgrade) RASTER (raster procs
 from "3.5.2 dea6d0a" need upgrade) (sfcgal procs from "3.5.2 dea6d0a" need
 upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5912>
