[PostGIS] #5913: ST_GeomFromGeoJSON leaks memory
PostGIS trac at osgeo.org
Wed May 28 15:26:12 PDT 2025
 Reporter:  komzpa   |      Owner:  Komzpa
     Type:  defect   |     Status:  assigned
 Priority:  medium   |  Milestone:  PostGIS 3.6.0
Component:  postgis  |    Version:  3.4.x
 Keywords:           |
 When restoring a huge dump with generated column that uses
 ST_GeomFromGeoJSON, Postgres runs out of memory.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5913>
