[PostGIS] #5917: ST_Relate becomes unresponsive when the third parameter is too long
PostGIS trac at osgeo.org
Wed May 28 19:57:02 PDT 2025
 Reporter:  dmyzl      |      Owner:  pramsey
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 3.5.4
Component:  postgis    |    Version:  3.5.x
 Keywords:  ST_Relate  |
 The third parameter of `ST_Relate` should only be valid when it contains
 exactly 9 characters. However, if a much longer string is passed, the
 function becomes unresponsive for a long time. For example, the following
 SQL:
 do $$
 declare
 s text;
 BEGIN
     s :='TTTTTTTTT';
     for i in 1..20 LOOP
         s :=  s || s;
     end LOOP;
     perform st_relate(
         st_geomfromtext('point(43 43)', 4326),
         s
 END;
 $$ language plpgsql;
 It might be better to validate the third parameter at the beginning of
 this function overload.
 postgis_full_version:
 POSTGIS="3.5.3 0" [EXTENSION] PGSQL="170" GEOS="3.13.1-CAPI-1.19.2"
 SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST 1.74.0" PROJ="9.3.1
 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/home/yzl/.local/share/proj
 DATABASE_PATH=/home/yzl/project/build_pg_postgis/proj-9.3.1/tmp_install/share/proj/proj.db"
 (compiled against PROJ 9.3.1) GDAL="GDAL 3.7.2, released 2023/09/05"
 LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
 (Internal)" (core procs from "3.5.2 dea6d0a" need upgrade) TOPOLOGY
 (topology procs from "3.5.2 dea6d0a" need upgrade) RASTER (raster procs
 from "3.5.2 dea6d0a" need upgrade) (sfcgal procs from "3.5.2 dea6d0a" need
 upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5917>
