[PostGIS] #5908: Server crashes when GetFaceContainingPoint is called with NULL arguments
trac at osgeo.org
Thu May 29 00:49:30 PDT 2025
Reporter: dmyzl | Owner: strk
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.2.9
Component: topology | Version: 3.2.x
Resolution: | Keywords:
Comment (by Sandro Santilli <strk@…>):
In [changeset:"6fe2403898f71c5a9a0a6de66f73c1faa7dd0ea7/git" 6fe2403/git]:
{{{#!CommitTicketReference repository="git"
revision="6fe2403898f71c5a9a0a6de66f73c1faa7dd0ea7"
Make GetFaceContainingPoint survive to NULL arguments and EMPTY points
References #5908 in 3.4 branch (3.4.5dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5908#comment:6>
