[PostGIS] #5908: Server crashes when GetFaceContainingPoint is called with NULL arguments
PostGIS trac at osgeo.org
Thu May 29 00:51:01 PDT 2025
  Reporter:  dmyzl     |      Owner:  strk
      Type:  defect    |     Status:  closed
  Priority:  blocker   |  Milestone:  PostGIS 3.2.9
 Component:  topology  |    Version:  3.2.x
Resolution:  fixed     |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * resolution:   => fixed
 * status:  assigned => closed
Comment:
 In [changeset:"9f73023a13df8f7fa84ad9774db0967a6f134be5/git" 9f73023/git]:
 {{{#!CommitTicketReference repository="git"
 revision="9f73023a13df8f7fa84ad9774db0967a6f134be5"
 Make GetFaceContainingPoint survive to NULL arguments and EMPTY points
 Closes #5908 in 3.2 branch (3.2.9dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5908#comment:8>
