[PostGIS] #5920: Different data insertion orders may cause inconsistent ST_Polygonize results
trac at osgeo.org
Thu May 29 01:01:46 PDT 2025
results
Reporter: dmyzl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.4
Component: postgis | Version: 3.5.x
Keywords: ST_Polygonize |
The following two SQL statements differ only in the data insertion order,
but they produce different results from the `ST_Polygonize` function.
DROP TABLE IF EXISTS polyedges;
CREATE TABLE polyedges(id INT,geom Geometry);
INSERT INTO polyedges VALUES
(1, ST_GeomFromText('LINESTRING(0 0,1 0)')),
(2, ST_GeomFromText('LINESTRING(0
999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999,0
0)')),
(3, ST_GeomFromText('LINESTRING(1 0,1 1)')),
(4, ST_GeomFromText('LINESTRING(1 1,0
999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999)'));
COMMIT;
SELECT ST_Polygonize(geom) FROM polyedges;
-- return: null
0)')),
(2, ST_GeomFromText('LINESTRING(0 0,1 0)')),
COMMIT;
-- return: 010700000000000000
While the second SQL statement returns a non-NULL result, the output is
actually incorrect. As shown in the SQL statements, there's a point with
an extremely large Y-coordinate (309 nines). When we reduce this
Y-coordinate value by one digit (to 308 nines), both SQL statements
produce identical results.
postgis_full_version:
POSTGIS="3.5.3 0" [EXTENSION] PGSQL="170" GEOS="3.13.1-CAPI-1.19.2"
SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST 1.74.0" PROJ="9.3.1
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/home/yzl/.local/share/proj
DATABASE_PATH=/home/yzl/project/build_pg_postgis/proj-9.3.1/tmp_install/share/proj/proj.db"
(compiled against PROJ 9.3.1) GDAL="GDAL 3.7.2, released 2023/09/05"
LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
(Internal)" (core procs from "3.5.2 dea6d0a" need upgrade) TOPOLOGY
(topology procs from "3.5.2 dea6d0a" need upgrade) RASTER (raster procs
from "3.5.2 dea6d0a" need upgrade) (sfcgal procs from "3.5.2 dea6d0a" need
upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5920>
