[SCM] PostGIS branch stable-3.3 updated. 3.3.7-33-g2fad4ecd4
git at osgeo.org
git at osgeo.org
Thu May 29 01:11:25 PDT 2025
the project "PostGIS".
The branch, stable-3.3 has been updated
via 2fad4ecd45f71171fe6e68e2685917041af1121d (commit)
from 3d38a0063823215b0e9821848f90834326361c3f (commit)
revisions in full, below.
commit 2fad4ecd45f71171fe6e68e2685917041af1121d
Author: Sandro Santilli <strk at kbt.io>
Date: Thu May 29 10:03:10 2025 +0200
Fix crash in TopoGeo_AddPolygon with EMPTY input
References #5907 in 3.3 branch (3.3.9dev)
diff --git a/NEWS b/NEWS
index c46705a13..e816a2cbf 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ Proj 4.9+ required.
* Bug Fixes and Enhancements *
- #5908, [topology] Fix crash in GetFaceContainingPoint (Sandro Santilli)
+ - #5907, [topology] Fix crash in TopoGeo_AddPolygon with EMPTY input (Sandro Santilli)
- #5876, Fix ST_AddPoint with empty point argument (Paul Ramsey)
- #5829, geometry_columns with non-standard constraints (Paul Ramsey)
- #5818, GT-244 Fix CG_IsSolid function (Loïc Bartoletti)
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 3f953c9c4..7e9d46bad 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -6136,6 +6136,13 @@ lwt_AddPolygon(LWT_TOPOLOGY* topo, LWPOLY* poly, double tol, int* nfaces)
const GEOSPreparedGeometry *ppoly;
GEOSGeometry *polyg;
+ /* Nothing to add, in an empty polygon */
+ if ( lwpoly_is_empty(poly) )
+ *nfaces = 0;
+ return NULL;
/* Get tolerance, if 0 was given */
if ( ! tol ) tol = _LWT_MINTOLERANCE( topo, (LWGEOM*)poly );
LWDEBUGF(1, "Working tolerance:%.15g", tol);
diff --git a/topology/test/regress/topogeo_addpolygon.sql b/topology/test/regress/topogeo_addpolygon.sql
index f7ace00a1..44b788a42 100644
--- a/topology/test/regress/topogeo_addpolygon.sql
+++ b/topology/test/regress/topogeo_addpolygon.sql
@@ -19,7 +19,7 @@ DECLARE
sql text;
BEGIN
-- Check effect on nodes
- sql := 'SELECT $1 || ''|N|'' ' || CASE WHEN add_id THEN ' || n.node_id || ''|'' ' ELSE '' END || ' ||
+ sql := 'SELECT $1 || ''|N|'' ' || CASE WHEN add_id THEN ' || n.node_id || ''|'' ' ELSE '' END || ' ||
COALESCE(n.containing_face::text,'''') || ''|'' ||
ST_AsText(ST_SnapToGrid(n.geom, 0.2))::text as xx
FROM city_data.node n WHERE n.node_id > (
@@ -35,7 +35,7 @@ BEGIN
-- Check effect on edges (there should be one split)
sql := 'WITH node_limits AS ( SELECT max FROM city_data.limits WHERE what = ''node''::text ),
edge_limits AS ( SELECT max FROM city_data.limits WHERE what = ''edge''::text )
- SELECT $1 || ''|E|'' ' || CASE WHEN add_id THEN ' || e.edge_id || ''|sn'' || e.start_node || ''|en'' || e.end_node::text ' ELSE '' END || ' AS xx ' ||
+ SELECT $1 || ''|E|'' ' || CASE WHEN add_id THEN ' || e.edge_id || ''|sn'' || e.start_node || ''|en'' || e.end_node::text ' ELSE '' END || ' AS xx ' ||
' FROM city_data.edge e, node_limits nl, edge_limits el
WHERE e.start_node > nl.max
OR e.end_node > nl.max
@@ -72,6 +72,7 @@ $$ LANGUAGE 'plpgsql';
SELECT 'invalid', TopoGeo_addPolygon('city_data', 'MULTILINESTRING((36 26, 38 30))');
SELECT 'invalid', TopoGeo_addPolygon('city_data', 'POINT(36 26)');
SELECT 'invalid', TopoGeo_addPolygon('invalid', 'POLYGON((36 26, 40 24, 40 30, 36 26))');
+SELECT 'empty', TopoGeo_addPolygon('city_data', 'POLYGON EMPTY');
-- Isolated face in universal face
SELECT 'iso_uni', TopoGeo_addPolygon('city_data', 'POLYGON((36 26, 38 30, 43 26, 36 26))');
@@ -145,11 +146,11 @@ SELECT 't1946.1', topology.topogeo_AddPolygon('bug1946',
76.68727 30.74249,76.67933 30.75,
76.69223 30.74157,76.68728 30.74248))'
::geometry); **/
-SELECT 't1946.2', COUNT(*)
+SELECT 't1946.2', COUNT(*)
FROM topology.topogeo_AddPolygon('bug1946',
'POLYGON((76.68728 30.74248,76.68727 30.74248,
-::geometry);
+::geometry);
SELECT 't1946.end', topology.DropTopology('bug1946');
Summary of changes:
NEWS | 1 +
liblwgeom/lwgeom_topo.c | 7 +++++++
topology/test/regress/topogeo_addpolygon.sql | 9 +++++----
3 files changed, 13 insertions(+), 4 deletions(-)
hooks/post-receive
