[SCM] PostGIS branch stable-3.0 updated. 3.0.11-15-gd40d7a739
Thu May 29 01:12:22 PDT 2025
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  d40d7a73958fbbbc2819737ce1f846f8fb7122c2 (commit)
      from  2144eca7715285d524ae0e912d350e9be895f594 (commit)
revisions in full, below.
commit d40d7a73958fbbbc2819737ce1f846f8fb7122c2
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu May 29 10:03:10 2025 +0200
    Fix crash in TopoGeo_AddPolygon
    Closes #5907 in 3.0 branch (3.0.12dev)
diff --git a/NEWS b/NEWS
index b414ed847..293ba710b 100644
--- a/NEWS
+++ b/NEWS
@@ -2,8 +2,10 @@ PostGIS 3.0.12dev
 xxxx/xx/xx
 PostgreSQL 9.5-13 required. GEOS 3.6+ required but GEOS 3.9+ to take advantage of all features.
 Proj 4.9+ required.
 * Bug Fixes *
+ - #5907, [topology] Fix crash in TopoGeo_AddPolygon with EMPTY input (Sandro Santilli)
  - #5795, [topology] Fix ST_NewEdgesSplit can cause invalid topology (Björn Harrtell)
  - Handle null returns from wkb parser, Paul Ramsey
  - #5818, GT-244 Fix CG_IsSolid function (Loïc Bartoletti)
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 5de283c38..1a5e594eb 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -5876,6 +5876,13 @@ lwt_AddPolygon(LWT_TOPOLOGY* topo, LWPOLY* poly, double tol, int* nfaces)
   const GEOSPreparedGeometry *ppoly;
   GEOSGeometry *polyg;
+  /* Nothing to add, in an empty polygon */
+  if ( lwpoly_is_empty(poly) )
+    *nfaces = 0;
+    return NULL;
   /* Get tolerance, if 0 was given */
   if ( ! tol ) tol = _LWT_MINTOLERANCE( topo, (LWGEOM*)poly );
   LWDEBUGF(1, "Working tolerance:%.15g", tol);
diff --git a/topology/test/regress/topogeo_addpolygon.sql b/topology/test/regress/topogeo_addpolygon.sql
index 68863b0b5..0cd58caad 100644
--- a/topology/test/regress/topogeo_addpolygon.sql
+++ b/topology/test/regress/topogeo_addpolygon.sql
@@ -19,7 +19,7 @@ DECLARE
   sql text;
 BEGIN
   -- Check effect on nodes
-  sql :=  'SELECT $1 || ''|N|'' ' || CASE WHEN add_id THEN ' || n.node_id || ''|'' ' ELSE '' END || ' ||
+  sql :=  'SELECT $1 || ''|N|'' ' || CASE WHEN add_id THEN ' || n.node_id || ''|'' ' ELSE '' END || ' ||
         COALESCE(n.containing_face::text,'''') || ''|'' ||
         ST_AsText(ST_SnapToGrid(n.geom, 0.2))::text as xx
   	FROM city_data.node n WHERE n.node_id > (
@@ -35,7 +35,7 @@ BEGIN
   -- Check effect on edges (there should be one split)
   sql := 'WITH node_limits AS ( SELECT max FROM city_data.limits WHERE what = ''node''::text ),
        edge_limits AS ( SELECT max FROM city_data.limits WHERE what = ''edge''::text )
-  SELECT $1 || ''|E|'' ' || CASE WHEN add_id THEN ' || e.edge_id || ''|sn'' || e.start_node || ''|en'' || e.end_node::text ' ELSE '' END || ' AS xx ' ||
+  SELECT $1 || ''|E|'' ' || CASE WHEN add_id THEN ' || e.edge_id || ''|sn'' || e.start_node || ''|en'' || e.end_node::text ' ELSE '' END || ' AS xx ' ||
    ' FROM city_data.edge e, node_limits nl, edge_limits el
    WHERE e.start_node > nl.max
       OR e.end_node > nl.max
@@ -72,6 +72,7 @@ $$ LANGUAGE 'plpgsql';
 SELECT 'invalid', TopoGeo_addPolygon('city_data', 'MULTILINESTRING((36 26, 38 30))');
 SELECT 'invalid', TopoGeo_addPolygon('city_data', 'POINT(36 26)');
 SELECT 'invalid', TopoGeo_addPolygon('invalid', 'POLYGON((36 26, 40 24, 40 30, 36 26))');
+SELECT 'empty', TopoGeo_addPolygon('city_data', 'POLYGON EMPTY');
 -- Isolated face in universal face
 SELECT 'iso_uni', TopoGeo_addPolygon('city_data', 'POLYGON((36 26, 38 30, 43 26, 36 26))');
@@ -145,11 +146,11 @@ SELECT 't1946.1', topology.topogeo_AddPolygon('bug1946',
           76.68727 30.74249,76.67933 30.75,
           76.69223 30.74157,76.68728 30.74248))'
 ::geometry);  **/
-SELECT 't1946.2', COUNT(*)
+SELECT 't1946.2', COUNT(*)
   FROM topology.topogeo_AddPolygon('bug1946',
 'POLYGON((76.68728 30.74248,76.68727 30.74248,
-::geometry);
+::geometry);
 SELECT 't1946.end', topology.DropTopology('bug1946');
Summary of changes:
 NEWS                                         | 2 ++
 liblwgeom/lwgeom_topo.c                      | 7 +++++++
 topology/test/regress/topogeo_addpolygon.sql | 9 +++++----
 3 files changed, 14 insertions(+), 4 deletions(-)
hooks/post-receive
