[SCM] PostGIS branch master updated. 3.6.0rc2-178-g8e7b03874
Fri Nov 7 13:30:35 PST 2025
the project "PostGIS".
       via  8e7b0387401764518cf28b072bb114b19514fa58 (commit)
       via  ac07b86e9d8a2161a1a01544389d33c76051d8be (commit)
      from  c7cd09187e922254625a89f75cd724fa5f3612f5 (commit)
revisions in full, below.
commit 8e7b0387401764518cf28b072bb114b19514fa58
Merge: c7cd09187 ac07b86e9
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Nov 7 13:30:24 2025 -0800
    Merge branch 'master-6012'
commit ac07b86e9d8a2161a1a01544389d33c76051d8be
Date:   Fri Nov 7 13:23:05 2025 -0800
    fix memory leak, references #6012
diff --git a/liblwgeom/lwcircstring.c b/liblwgeom/lwcircstring.c
index 71a1556bf..ec0d05b27 100644
--- a/liblwgeom/lwcircstring.c
+++ b/liblwgeom/lwcircstring.c
@@ -34,14 +34,13 @@
 void printLWCIRCSTRING(LWCIRCSTRING *curve);
 void lwcircstring_release(LWCIRCSTRING *lwcirc);
 char lwcircstring_same(const LWCIRCSTRING *me, const LWCIRCSTRING *you);
-LWCIRCSTRING *lwcircstring_from_lwpointarray(int32_t srid, uint32_t npoints, LWPOINT **points);
+LWCIRCSTRING *lwcircstring_from_lwpointarray(int32_t srid, uint32_t npoints, const LWPOINT **points);
 LWCIRCSTRING *lwcircstring_from_lwmpoint(int32_t srid, LWMPOINT *mpoint);
 LWCIRCSTRING *lwcircstring_addpoint(LWCIRCSTRING *curve, LWPOINT *point, uint32_t where);
 LWCIRCSTRING *lwcircstring_removepoint(LWCIRCSTRING *curve, uint32_t index);
 void lwcircstring_setPoint4d(LWCIRCSTRING *curve, uint32_t index, POINT4D *newpoint);
  * Construct a new LWCIRCSTRING.  points will *NOT* be copied
  * use SRID=SRID_UNKNOWN for unknown SRID (will have 8bit type's S = 0)
@@ -138,49 +137,44 @@ lwcircstring_same(const LWCIRCSTRING *me, const LWCIRCSTRING *you)
  * LWCIRCSTRING dimensions are large enough to host all input dimensions.
 LWCIRCSTRING *
-lwcircstring_from_lwpointarray(int32_t srid, uint32_t npoints, LWPOINT **points)
+lwcircstring_from_lwpointarray(int32_t srid, uint32_t npoints, const LWPOINT **points)
-	int zmflag=0;
 	uint32_t i;
 	POINTARRAY *pa;
-	uint8_t *newpoints, *ptr;
-	size_t ptsize, size;
+	int has_z = 0, has_m = 0;
+	POINT4D pt;
 	 * Find output dimensions, check integrity
 	for (i = 0; i < npoints; i++)
-		if (points[i]->type != POINTTYPE)
+		const LWGEOM *lwg = (LWGEOM*)points[i];
+		if (lwg->type != POINTTYPE)
-			lwerror("lwcurve_from_lwpointarray: invalid input type: %s",
-			        lwtype_name(points[i]->type));
+			lwerror("%s: invalid input type: %s", __func__, lwtype_name(lwg->type));
 			return NULL;
-		if (FLAGS_GET_Z(points[i]->flags)) zmflag |= 2;
-		if (FLAGS_GET_M(points[i]->flags)) zmflag |= 1;
-		if (zmflag == 3) break;
+		has_z |= lwgeom_has_z(lwg);
+		has_m |= lwgeom_has_m(lwg);
+		if (has_z && has_m) break;
-	if (zmflag == 0) ptsize = 2 * sizeof(double);
-	else if (zmflag == 3) ptsize = 4 * sizeof(double);
-	else ptsize = 3 * sizeof(double);
 	 * Allocate output points array
-	size = ptsize * npoints;
-	newpoints = lwalloc(size);
-	memset(newpoints, 0, size);
+	pa = ptarray_construct(has_z, has_m, npoints);
-	ptr = newpoints;
-		size = ptarray_point_size(points[i]->point);
-		memcpy(ptr, getPoint_internal(points[i]->point, 0), size);
-		ptr += ptsize;
+		const LWPOINT *lwpt = points[i];
+		if (!getPoint4d_p(lwpt->point, 0, &pt))
+			lwerror("%s: failed getPoint4d_p", __func__);
+			return NULL;
+		ptarray_set_point4d(pa, i, &pt);
-	pa = ptarray_construct_reference_data(zmflag&2, zmflag&1, npoints, newpoints);
 	return lwcircstring_construct(srid, NULL, pa);
Summary of changes:
 liblwgeom/lwcircstring.c | 42 ++++++++++++++++++------------------------
 1 file changed, 18 insertions(+), 24 deletions(-)
hooks/post-receive
