[PostGIS] #6009: Error of ST_Polygon(raster) function in PostGIS 3.4.3 and 3.5.4
trac at osgeo.org
Sun Nov 9 18:41:39 PST 2025
Reporter: | Owner: robe
GISuser5432 |
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.5.5
Component: raster | Version: 3.5.x
Resolution: | Keywords: PostGIS_Raster; Raster;
| ST_Polygon(Raster)
Comment (by robe):
You said in 3.6 the issue was fixed? You mind spitting out the
SELECT postgis_full_version();
Of your 3.6 install. I suspect the issue might be changes in GEOS or
GDAL. Cause I don't think we've touched the behavior of ST_Polygon in
PostGIS raster for quite some time.
Also I tested your above in PostGIS 3.4.2 that has a much newer GEOS and
GDAL than yours:
POSTGIS="3.4.2 c19ce56" [EXTENSION] PGSQL="160" GEOS="3.15.0dev-
CAPI-1.21.0" (compiled against GEOS 3.12.1) PROJ="9.6.0
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
GDAL="GDAL 3.8.4, released 2024/02/08" LIBXML="2.9.14" LIBJSON="0.18"
LIBPROTOBUF="1.5.1" WAGYU="0.5.0 (Internal)" RASTER
and it gave no error and returned 3 rows of polygons. Although the result
just looked like a square and checking the no data values, they don't seem
to be in the range of the polygons as you can see from this query:
SELECT s.*, ST_BandNoDataValue(raster)
FROM error_sounding_2m, ST_SummaryStats(raster) AS s;
So I'm surprised you are getting an error at all unless I'm missing a step
in your processing
count | sum | mean | stddev |
min | max | st_bandnodatavalue
2073 | -12315.960650817047 | -5.9411291127916295 | 1.1713853383330117 |
-9.63054806077984 | -3.606000026067098 | 1.7976931348623157e+308
2073 | -12082.059349060059 | -5.828296839874606 | 1.1384145955840472 |
-9.571334838867188 | -3.5280160903930664 | 3.4028234663852886e+38
2073 | 2164263.2647475842 | 1044.0247297383426 | 491.1311932725887 |
2 | 2947 | 1.7976931348623157e+308
(3 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6009#comment:2>
