[SCM] PostGIS branch stable-3.6 updated. 3.6.0-32-gf53362350
git at osgeo.org
git at osgeo.org
Thu Nov 13 10:30:02 PST 2025
the project "PostGIS".
The branch, stable-3.6 has been updated
via f533623505f73939a2d25d66ff252fb6619c4ac7 (commit)
from 6a16232cb57a202d0e1407fedb6f59ede0a354ec (commit)
revisions in full, below.
commit f533623505f73939a2d25d66ff252fb6619c4ac7
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Nov 13 10:29:54 2025 -0800
Prepare for 3.6.1 release
diff --git a/.gitignore b/.gitignore
index f9d05e3ca..f8b019f67 100644
--- a/.gitignore
+++ b/.gitignore
@@ -128,6 +128,7 @@ macros/ltversion.m4
*.o
postgis_config.h
postgis/Makefile
+postgis/cunit/Makefile
postgis/geobuf.pb-c.c
postgis/geobuf.pb-c.h
postgis/legacy_gist.sql
diff --git a/NEWS b/NEWS
index 2a2fd08da..76662826a 100644
--- a/NEWS
+++ b/NEWS
@@ -1,6 +1,6 @@
PostGIS 3.6.1
-2025/11/xx
+2025/11/13
This version requires PostgreSQL 12-18, GEOS 3.8 or higher, and Proj 6.1+.
To take advantage of all features, GEOS 3.14+ is needed.
@@ -21,14 +21,15 @@ SELECT topology.FixCorruptTopoGeometryColumn(schema_name, table_name, feature_co
- #5998, ST_Distance error on CurvePolygon (Paul Ramsey)
- #5962, Consistent clipping of MULTI/POINT (Paul Ramsey)
- #5998, [tiger_geocoder] [security] CVE-2022-2625, make sure tables requires
- by extension are owned by extension
- authored: Andrey Borodin (Yandex), reported by Sergey Bobrov (Kaspersky)
+ by extension are owned by extension
+ authored: Andrey Borodin (Yandex), reported by Sergey Bobrov (Kaspersky)
- #5754, ST_ForcePolygonCCW reverses lines (Paul Ramsey)
- - #5959, #5984, Prevent histogram target overflow when analysing massive tables (Darafei Praliaskouski)
+ - #5959, #5984, Prevent histogram target overflow when analysing massive
+ tables (Darafei Praliaskouski)
- #6012, Remove memory leak from lwcircstring_from_lwpointarray (Paul Ramsey)
- #6013, [tiger_geocoder] Load Tiger 2025 data (Regina Obe)
- #5983, [topology] topology.FixCorruptTopoGeometryColumn
- to fix corruption caused by 3.6.0 upgrade (Regina Obe, Francois Bonzon)
+ to fix corruption caused by 3.6.0 upgrade (Regina Obe, Francois Bonzon)
PostGIS 3.6.0
diff --git a/README.postgis b/README.postgis
index 009525190..bdd39454c 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.6.0
-:Date: 2025-09-01
+:Version: 3.6.1
+:Date: 2025-11-13
:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 28fc88d89..e32cb25c4 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=6
-POSTGIS_MICRO_VERSION=1dev
+POSTGIS_MICRO_VERSION=1
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 68fa8bc79..bf8a795de 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,6 +2,30 @@
<appendix xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://docbook.org/ns/docbook" version="5.0" xml:id="release_notes">
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
+ <section>
+ <title>PostGIS 3.6.1</title>
+ <para>2025/11/13</para>
+ <para>If you are upgrading postgis_topology and have topogeometry columns, make sure to run after the upgrade to fix topogeometry corruption: <code>SELECT topology.FixCorruptTopoGeometryColumn(schema_name, table_name, feature_column) FROM topology.layer</code></para>
+ <simplesect>
+ <title>Fixes</title>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5978">#5978</link>, geometry_columns needs to still parse table constraints (Paul Ramsey)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5987">#5987</link>, ST_GeometryN fails for non-collections (Paul Ramsey)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5991">#5991</link>, CircularString distance error (Paul Ramsey)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5994">#5994</link>, Null pointer in ST_AsGeoJsonRow (Alexander Kukushkin)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5998">#5998</link>, ST_Distance error on CurvePolygon (Paul Ramsey)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5962">#5962</link>, Consistent clipping of MULTI/POINT (Paul Ramsey)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5998">#5998</link>, [tiger_geocoder] [security] CVE-2022-2625, make sure tables requires by extension are owned by extension authored: Andrey Borodin (Yandex), reported by Sergey Bobrov (Kaspersky)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5754">#5754</link>, ST_ForcePolygonCCW reverses lines (Paul Ramsey)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5959">#5959</link>, <link xlink:href="https://trac.osgeo.org/postgis/ticket/5984">#5984</link>, Prevent histogram target overflow when analysing massive tables (Darafei Praliaskouski)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6012">#6012</link>, Remove memory leak from lwcircstring_from_lwpointarray (Paul Ramsey)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/6013">#6013</link>, [tiger_geocoder] Load Tiger 2025 data (Regina Obe)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5983">#5983</link>, [topology] topology.FixCorruptTopoGeometryColumn to fix corruption caused by 3.6.0 upgrade (Regina Obe, Francois Bonzon)</para>
+ </simplesect>
+ </section>
<section>
<title>PostGIS 3.6.0</title>
<para>2025/09/01</para>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 044c5ae78..045f94bc0 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -112,4 +112,5 @@ UPGRADEABLE_VERSIONS = \
3.5.1 \
3.5.2 \
3.5.3 \
- 3.6.0
+ 3.6.0 \
+ 3.6.1dev
Summary of changes:
.gitignore | 1 +
NEWS | 11 ++++++-----
README.postgis | 4 ++--
Version.config | 2 +-
doc/release_notes.xml | 24 ++++++++++++++++++++++++
extensions/upgradeable_versions.mk | 3 ++-
6 files changed, 36 insertions(+), 9 deletions(-)
hooks/post-receive
