[SCM] PostGIS branch master updated. 3.6.0rc2-224-gfeb3413c0
Thu Nov 27 17:47:57 PST 2025
the project "PostGIS".
       via  feb3413c042bcb6891ce3a9ce62471071d02f0e0 (commit)
      from  c86bd9f8d8b2ddaedffabf11c8bddd3488c15722 (commit)
revisions in full, below.
commit feb3413c042bcb6891ce3a9ce62471071d02f0e0
Author: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>
Date:   Fri Nov 28 00:08:16 2025 +0000
    Translated PostGIS Manual using Weblate (Japanese)
    Currently translated at 98.5% (5807 of 5893 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 3af525ef4..87191ae60 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2025-11-13 16:23+0000\n"
-"PO-Revision-Date: 2025-11-26 08:47+0000\n"
+"PO-Revision-Date: 2025-11-28 01:47+0000\n"
 "Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/ja/>\n"
@@ -43385,6 +43385,9 @@ msgid ""
 "output from the linework. The requirement that no vertices are lost can "
 "generate complex collections as outputs."
 msgstr ""
+"\"linework\"はデフォルトのアルゴリズムで、最初に全てのラインを抽出して、その"
+"ラインを繋ぎ合わせ、最後に繋いだラインから値を出力します。頂点の欠落が無いこ"
+"とを求めているので、複雑なコレクションを出力として生成できます。"
 #. Tag: para
 #, no-c-format
@@ -43394,6 +43397,9 @@ msgid ""
 "differencing all interior rings. The results tend to be more intuitive, "
 "where collapsed lines are discarded in the output."
 msgstr ""
+"\"structure\"は内側リングと外側リングを区別します。外側リングを結合してジオメ"
+"トリーを新規生成してから、全ての内側リングの領域を差し引きます。次元崩壊した"
+"ラインは破棄されて結果が出力されるので、より直感的と言えるでしょう。"
 #. Tag: para
 #, no-c-format
@@ -43401,6 +43407,8 @@ msgid ""
 "The \"keepcollapsed\" key is only valid for the \"structure\" algorithm, and "
 "takes a value of \"true\" or \"false\"."
 msgstr ""
+"\"keepcollapsed\"キーは\"structure\"アルゴリズムの時だけ見られて、\"true"
+"\"または\"false\"を取ります。"
 #. Tag: para
 #, no-c-format
@@ -43409,13 +43417,16 @@ msgid ""
 "components that collapse to a lower dimensionality, for example a one-point "
 "linestring will be dropped."
 msgstr ""
+"\"keepcollapsed\"のデフォルト値は\"false\"です。頂点が1個のラインストリングな"
+"どの低い空間次元に崩壊するジオメトリーは削除されます。"
 #. Tag: para
 #, no-c-format
 msgid ""
 "Keep collapsed of \"true\" means geometry components that collapse to a "
 "lower dimensionality will be retained."
-msgstr ""
+msgstr "\"keepcollapsed\"が\"true\"の場合には"
+"、低い空間次元に崩壊するジオメトリー要素も保持されます。"
 #. Tag: para
 #, no-c-format
@@ -45438,6 +45449,11 @@ msgid ""
 "custom geodetic spatial reference system as described in <xref "
 "linkend=\"user-spatial-ref-sys\"/>."
 msgstr ""
+"ジオメトリー型のように、ジオグラフィデータは空間参照系識別子 (Spatial "
+"Reference System Identifier, SRID)を持っています。 <varname>spatial_ref_sys</"
+"varname>で定義されている地理座標系 (経度/緯度)の空間参照系で利用できます。独"
+"自の地理座標系の空間参照系を追加することもできます。<xref linkend=\"user-"
+"spatial-ref-sys\"/>を参照してください。"
 #. Tag: para
 #, no-c-format
@@ -47646,6 +47662,16 @@ msgid ""
 "href=\"https://www.postgresql.org/docs/current/brin.html\">PostgreSQL "
 "manual</link>."
 msgstr ""
+"BRINは\"Block Range Index\"の意味です。PostgreSQLが提供する汎用インデックスで"
+"す。BRINは<emphasis>不可逆</emphasis>インデックスですので、"
+"レコードが検索条件に合致するか確認する二次チェックが必要です (これは提供され"
+"ているすべての空間インデックスと同じです)。BRINは、インデックス生成が非常に高"
+"速で、インデックスサイズが非常に小さく、読込み効率がそこそこ良いものです。こ"
+"れの主目的は、巨大テーブルに対してテーブル内の物理位置と相関するカラムの上に"
+"インデックスを生成することです。BRINは各種属性データ構造 "
+"(整数、配列など)の高速検索が可能です。詳細情報については<link xlink:href="
+"\"https://www.postgresql.org/docs/current/brin.html\">PostgreSQL "
+"manual</link>を参照してください。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/ja/postgis-manual.po | 30 ++++++++++++++++++++++++++++--
 1 file changed, 28 insertions(+), 2 deletions(-)
hooks/post-receive
