[SCM] PostGIS branch master updated. 3.6.0rc2-233-g0673a9acd
Sat Nov 29 12:18:09 PST 2025
the project "PostGIS".
       via  0673a9acd838953bfa17cb571e064c4486242268 (commit)
      from  95e8afa878e77ed4e735fff2367f113a81c19aa9 (commit)
revisions in full, below.
commit 0673a9acd838953bfa17cb571e064c4486242268
Author: Weblate <noreply at weblate.org>
Date:   Sat Nov 29 20:16:12 2025 +0000
    Update translation files
    Updated by "Update PO files to match POT (msgmerge)" hook in Weblate.
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/
diff --git a/doc/po/be/postgis-manual.po b/doc/po/be/postgis-manual.po
index 16d5f5820..6a6d0acbf 100644
--- a/doc/po/be/postgis-manual.po
+++ b/doc/po/be/postgis-manual.po
@@ -6744,9 +6744,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"ImageMagick (<filename>convert</filename>) is required to generate the "
-"images used in the documentation. ImageMagick is available from <link xlink:"
-"href=\"http://www.imagemagick.org/\"> http://www.imagemagick.org/ </link> ."
+"GraphicsMagick (<filename>gm convert</filename>) is required to generate the "
+"images used in the documentation. GraphicsMagick is available from <link "
+"xlink:href=\"http://www.graphicsmagick.org/\"> http://www.graphicsmagick."
+"org/ </link> ."
 msgstr ""
 #. Tag: title
diff --git a/doc/po/da/postgis-manual.po b/doc/po/da/postgis-manual.po
index a0148f11c..40ba3dbf5 100644
--- a/doc/po/da/postgis-manual.po
+++ b/doc/po/da/postgis-manual.po
@@ -6611,9 +6611,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+"org/ </link> ."
 msgstr ""
 #. Tag: title
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index 72e046099..773d2888e 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -8628,14 +8628,11 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+"org/ </link> ."
 msgstr ""
-"ImageMagick (<filename>convert</filename>) wird zur Erzeugung von Bildern "
-"für die Dokumentation benötigt. ImageMagick kann von <link xlink:"
-"href=\"http://www.imagemagick.org/\"> http://www.imagemagick.org/ </link> "
-"bezogen werden."
 #. Tag: title
 #, fuzzy, no-c-format
@@ -52575,6 +52572,18 @@ msgstr "2.5/3D-Unterstützung"
 msgid "Supports geography"
 msgstr "Unterstützt Geographie"
+#, no-c-format
+#~ msgid ""
+#~ "ImageMagick (<filename>convert</filename>) is required to generate the "
+#~ "images used in the documentation. ImageMagick is available from <link "
+#~ "xlink:href=\"http://www.imagemagick.org/\"> http://www.imagemagick.org/ </"
+#~ "link> ."
+#~ msgstr ""
+#~ "ImageMagick (<filename>convert</filename>) wird zur Erzeugung von Bildern "
+#~ "für die Dokumentation benötigt. ImageMagick kann von <link xlink:"
+#~ "href=\"http://www.imagemagick.org/\"> http://www.imagemagick.org/ </link> "
+#~ "bezogen werden."
 #, no-c-format
 #~ msgid ""
 #~ "<link xlink:href=\"http://www.gisgraphy.com/\">GIS Graphy</link> also "
diff --git a/doc/po/es/postgis-manual.po b/doc/po/es/postgis-manual.po
index 878adeece..9edbd124b 100644
--- a/doc/po/es/postgis-manual.po
+++ b/doc/po/es/postgis-manual.po
@@ -7573,14 +7573,11 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+"org/ </link> ."
 msgstr ""
-"ImageMagick (<filename>convert</filename>) es necesario para generar las "
-"imágenes empleadas en la documentación. ImageMagick esta disponible en<link "
-"xlink:href=\"http://www.imagemagick.org/\"> http://www.imagemagick.org/ </"
-"link> ."
 #. Tag: title
@@ -43194,6 +43191,18 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ "link> ."
+#~ msgstr ""
+#~ "ImageMagick (<filename>convert</filename>) es necesario para generar las "
+#~ "imágenes empleadas en la documentación. ImageMagick esta disponible "
+#~ "en<link xlink:href=\"http://www.imagemagick.org/\"> http://www."
+#~ "imagemagick.org/ </link> ."
 #, no-c-format
 #~ msgid ""
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index 38a0ca9db..d285bb0fb 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -8594,13 +8594,11 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+"org/ </link> ."
 msgstr ""
-"ImageMagick (<filename>convert</filename>) est nécessaire pour générer les "
-"images de la documentation. ImageMagick is available from <link xlink:"
 #. Tag: title
 #, no-c-format
@@ -52590,6 +52588,18 @@ msgstr "Support 2.5/3D"
 msgstr "Prise en charge du type geography"
+#, no-c-format
+#~ msgid ""
+#~ "link> ."
+#~ msgstr ""
+#~ "ImageMagick (<filename>convert</filename>) est nécessaire pour générer "
+#~ "les images de la documentation. ImageMagick is available from <link xlink:"
+#~ "href=\"http://www.imagemagick.org/\"> http://www.imagemagick.org/ </"
+#~ "link> ."
 #, no-c-format
 #~ msgid ""
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index c54c83a8c..c3eded8a9 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -7293,14 +7293,11 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-msgstr ""
-"ImageMagick (<filename>convert</filename>) viene utilizzato per generare le "
-"immagini utilizzate nella documentazione. ImageMagick è disponibile sul sito "
-"<link xlink:href=\"http://www.imagemagick.org/\"> http://www.imagemagick."
 "org/ </link> ."
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -43291,6 +43288,18 @@ msgstr "Supporta il 2.5/3D"
 msgstr "Supporta il tipo geography"
+#, no-c-format
+#~ msgid ""
+#~ "link> ."
+#~ msgstr ""
+#~ "ImageMagick (<filename>convert</filename>) viene utilizzato per generare "
+#~ "le immagini utilizzate nella documentazione. ImageMagick è disponibile "
+#~ "sul sito <link xlink:href=\"http://www.imagemagick.org/\"> http://www."
 #, no-c-format
 #~ msgid ""
 #~ "As of PostGIS 2.1.3, out-of-db rasters and all raster drivers are "
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 68aba062d..92857e0d0 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -12,8 +12,8 @@ msgstr ""
 "POT-Creation-Date: 2025-11-13 16:23+0000\n"
 "PO-Revision-Date: 2025-11-28 08:47+0000\n"
 "Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
-"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
-"postgis-manual/ja/>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
+"manual/ja/>\n"
 "Language: ja\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
@@ -4058,11 +4058,11 @@ msgid ""
 "<varname>abs_next_right_edge</varname> columns exposed by the <varname>edge</"
 "varname> view are convenience projections of these absolute values."
 msgstr ""
-"ゼロは対応する側でエッジがぶら下がっていることを示します ("
-"たとえば接続するフェイスが "
-"<varname>0</varname>のユニバーサルフェイスになっている孤立エッジ)。 <varname>"
-"edge</varname>ビューにある<varname>abs_next_left_edge</varname>カラムと<varna"
-"me>abs_next_right_edge</varname>カラムは絶対値にして扱いすくしたものです。"
+"ゼロは対応する側でエッジがぶら下がっていることを示します (たとえば接続する"
+"フェイスが <varname>0</varname>のユニバーサルフェイスになっている孤立エッ"
+"ジ)。 <varname>edge</varname>ビューにある<varname>abs_next_left_edge</"
+"varname>カラムと<varname>abs_next_right_edge</varname>カラムは絶対値にして扱"
+"いすくしたものです。"
 #. Tag: para
 #, no-c-format
@@ -5605,7 +5605,8 @@ msgstr ""
 msgid ""
 "The returned edge identifiers may be either existing edges or newly created "
 "edges as needed to fully represent the input line as closely as possible."
-msgstr "返されるエッジ識別番号は、入力ラインの表現を可能な限り完全に表現するのに必要"
+msgstr ""
+"返されるエッジ識別番号は、入力ラインの表現を可能な限り完全に表現するのに必要"
 "となるので、既存エッジか新規生成されたエッジかになります。"
 #. Tag: para
@@ -5615,9 +5616,9 @@ msgid ""
 "uncovered or resulting from split of existing edges) may be limited by the "
 "<varname>max_edges</varname> parameter."
 msgstr ""
-"新規生成されたエッジの数 "
-"(覆っていなかった空間を覆うエッジか、既存エッジの分割から得られた結果)は "
-"<varname>max_edges</varname>パラメータで制限されることがあります。"
+"新規生成されたエッジの数 (覆っていなかった空間を覆うエッジか、既存エッジの分"
+"割から得られた結果)は <varname>max_edges</varname>パラメータで制限されること"
+"があります。"
 #. Tag: para
 #, no-c-format
@@ -7237,8 +7238,8 @@ msgid ""
 "the topology precision as tolerance."
 msgstr ""
 "<varname>tolerance</varname>が与えられた場合には、入力ジオメトリを既存のプリ"
-"ミティブにスナップします。特別な値である -1 "
-"(デフォルト)ではトポロジーの精度を許容値として使うことになります。"
+"ミティブにスナップします。特別な値である -1 (デフォルト)ではトポロジーの精度"
+"を許容値として使うことになります。"
 #. Tag: para
 #, no-c-format
@@ -7275,8 +7276,8 @@ msgid ""
 "Changed: 3.7.0 changes meaning of tolerance 0 to really mean 0 and -1 (new "
 "default) to request using the topology precision."
 msgstr ""
-"Changed: 3.7.0 許容値 0を実際の 0として扱い、-1 "
-"(新デフォルト値)をそのトポロジーの精度を使うよう求めるように変更されました。"
+"Changed: 3.7.0 許容値 0を実際の 0として扱い、-1 (新デフォルト値)をそのトポロ"
+"ジーの精度を使うよう求めるように変更されました。"
 #. Tag: para
 #, no-c-format
@@ -8450,13 +8451,11 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+"org/ </link> ."
 msgstr ""
-"ImageMagick (<filename>convert</filename>)。文書で使う画像を生成するのに必要"
-"です。<link xlink:href=\"http://www.imagemagick.org/\">http://www."
-"imagemagick.org/</link>にあります。"
 #. Tag: title
 #, no-c-format
@@ -8777,10 +8776,10 @@ msgid ""
 msgstr ""
 "全ての関数は文書から生成されたコメントを持っています。後でコメントを手持ちの"
 "空間データベースにインストールしたい場合には、docbookが必要なコマンドを実行し"
-"ます。postgis_comments.sqlと他のパッケージのコメントファイルはtar."
-"gzディストリビューションのdocフォルダ内に同梱されています。この "
-"tarボールからインストールする場合にはコメントを生成する必要がありません。"
-"コメントはCREATE EXTENSIONインストールにも含まれています。"
+"ます。postgis_comments.sqlと他のパッケージのコメントファイルはtar.gzディスト"
+"リビューションのdocフォルダ内に同梱されています。この tarボールからインストー"
+"ルする場合にはコメントを生成する必要がありません。コメントはCREATE EXTENSION"
+"インストールにも含まれています。"
 #. Tag: para
 #, no-c-format
@@ -36910,7 +36909,8 @@ msgstr ""
 msgid ""
 "Changed 3.7.0, the polygonization honours PostgreSQL interrupts so "
 "cancellations and statement timeouts halt processing promptly."
-msgstr "Changed 3.7.0, PostgreSQLの処理中断を尊重して、キャンセルや手続時間切れによる"
+msgstr ""
+"Changed 3.7.0, PostgreSQLの処理中断を尊重して、キャンセルや手続時間切れによる"
 "処理の停止を即座に行うようになりました。"
 #. Tag: para
@@ -43413,8 +43413,8 @@ msgid ""
 "The \"keepcollapsed\" key is only valid for the \"structure\" algorithm, and "
 "takes a value of \"true\" or \"false\"."
 msgstr ""
-"\"keepcollapsed\"キーは\"structure\"アルゴリズムの時だけ見られて、\"true"
-"\"または\"false\"を取ります。"
+"\"keepcollapsed\"キーは\"structure\"アルゴリズムの時だけ見られて、\"true\"ま"
+"たは\"false\"を取ります。"
 #. Tag: para
 #, no-c-format
@@ -43431,8 +43431,9 @@ msgstr ""
 msgid ""
 "Keep collapsed of \"true\" means geometry components that collapse to a "
 "lower dimensionality will be retained."
-msgstr "\"keepcollapsed\"が\"true\"の場合には"
-"、低い空間次元に崩壊するジオメトリー要素も保持されます。"
+msgstr ""
+"\"keepcollapsed\"が\"true\"の場合には、低い空間次元に崩壊するジオメトリー要素"
+"も保持されます。"
 #. Tag: para
 #, no-c-format
@@ -47669,15 +47670,14 @@ msgid ""
 "manual</link>."
 msgstr ""
 "BRINは\"Block Range Index\"の意味です。PostgreSQLが提供する汎用インデックスで"
-"す。BRINは<emphasis>不可逆</emphasis>インデックスですので、"
-"レコードが検索条件に合致するか確認する二次チェックが必要です (これは提供され"
-"ているすべての空間インデックスと同じです)。BRINは、インデックス生成が非常に高"
-"速で、インデックスサイズが非常に小さく、読込み効率がそこそこ良いものです。こ"
-"れの主目的は、巨大テーブルに対してテーブル内の物理位置と相関するカラムの上に"
-"インデックスを生成することです。BRINは各種属性データ構造 "
-"(整数、配列など)の高速検索が可能です。詳細情報については<link xlink:href="
-"\"https://www.postgresql.org/docs/current/brin.html\">PostgreSQL "
-"manual</link>を参照してください。"
+"す。BRINは<emphasis>不可逆</emphasis>インデックスですので、レコードが検索条件"
+"に合致するか確認する二次チェックが必要です (これは提供されているすべての空間"
+"インデックスと同じです)。BRINは、インデックス生成が非常に高速で、インデックス"
+"サイズが非常に小さく、読込み効率がそこそこ良いものです。これの主目的は、巨大"
+"テーブルに対してテーブル内の物理位置と相関するカラムの上にインデックスを生成"
+"することです。BRINは各種属性データ構造 (整数、配列など)の高速検索が可能です。"
+"詳細情報については<link xlink:href=\"https://www.postgresql.org/docs/current/"
+"brin.html\">PostgreSQL manual</link>を参照してください。"
 #. Tag: para
 #, no-c-format
@@ -50341,6 +50341,17 @@ msgstr "2.5次元/3次元対応"
 msgstr "ジオグラフィ対応"
+#, no-c-format
+#~ msgid ""
+#~ "link> ."
+#~ msgstr ""
+#~ "ImageMagick (<filename>convert</filename>)。文書で使う画像を生成するのに必"
+#~ "要です。<link xlink:href=\"http://www.imagemagick.org/\">http://www."
+#~ "imagemagick.org/</link>にあります。"
 #, no-c-format
 #~ msgid ""
diff --git a/doc/po/ka/postgis-manual.po b/doc/po/ka/postgis-manual.po
index cd4cfa9ba..d55f504b4 100644
--- a/doc/po/ka/postgis-manual.po
+++ b/doc/po/ka/postgis-manual.po
@@ -6601,9 +6601,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+"org/ </link> ."
 msgstr ""
 #. Tag: title
diff --git a/doc/po/ko_KR/postgis-manual.po b/doc/po/ko_KR/postgis-manual.po
index 61b0aebc4..9c21046cf 100644
--- a/doc/po/ko_KR/postgis-manual.po
+++ b/doc/po/ko_KR/postgis-manual.po
@@ -7672,13 +7672,11 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+"org/ </link> ."
 msgstr ""
-"ImageMagick(<filename>convert</filename>)은 문서에 사용되는 이미지를 생성하"
-"는 데 필요합니다. ImageMagick은 <link xlink:href=\"http://www.imagemagick."
-"org/\"> http://www.imagemagick.org/ </link>에서 다운로드할 수 있습니다."
 #. Tag: title
@@ -45433,6 +45431,18 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ "link> ."
+#~ msgstr ""
+#~ "ImageMagick(<filename>convert</filename>)은 문서에 사용되는 이미지를 생성"
+#~ "하는 데 필요합니다. ImageMagick은 <link xlink:href=\"http://www."
+#~ "imagemagick.org/\"> http://www.imagemagick.org/ </link>에서 다운로드할 수 "
+#~ "있습니다."
 #, no-c-format
 #~ msgid ""
diff --git a/doc/po/pl/postgis-manual.po b/doc/po/pl/postgis-manual.po
index cffd5de0a..65c98678a 100644
--- a/doc/po/pl/postgis-manual.po
+++ b/doc/po/pl/postgis-manual.po
@@ -6626,9 +6626,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+"org/ </link> ."
 msgstr ""
 #. Tag: title
diff --git a/doc/po/pt_BR/postgis-manual.po b/doc/po/pt_BR/postgis-manual.po
index b2570e0bd..52c4c30d9 100644
--- a/doc/po/pt_BR/postgis-manual.po
+++ b/doc/po/pt_BR/postgis-manual.po
@@ -7740,13 +7740,11 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+"org/ </link> ."
 msgstr ""
-"ImageMagick (<filename>convert</filename>) é necessário para gerar as "
-"imagens usadas na documentação. ImageMagick está disponível em <link xlink:"
 #. Tag: title
@@ -45822,6 +45820,18 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ "link> ."
+#~ msgstr ""
+#~ "ImageMagick (<filename>convert</filename>) é necessário para gerar as "
+#~ "imagens usadas na documentação. ImageMagick está disponível em <link "
+#~ "link> ."
 #, no-c-format
 #~ msgid ""
diff --git a/doc/po/ro/postgis-manual.po b/doc/po/ro/postgis-manual.po
index 28dc76561..3fadea308 100644
--- a/doc/po/ro/postgis-manual.po
+++ b/doc/po/ro/postgis-manual.po
@@ -6620,9 +6620,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+"org/ </link> ."
 msgstr ""
 #. Tag: title
diff --git a/doc/po/ru/postgis-manual.po b/doc/po/ru/postgis-manual.po
index 869a594e0..2823bc8c6 100644
--- a/doc/po/ru/postgis-manual.po
+++ b/doc/po/ru/postgis-manual.po
@@ -6618,9 +6618,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+"org/ </link> ."
 msgstr ""
 #. Tag: title
diff --git a/doc/po/sv/postgis-manual.po b/doc/po/sv/postgis-manual.po
index e053bc343..ec9932982 100644
--- a/doc/po/sv/postgis-manual.po
+++ b/doc/po/sv/postgis-manual.po
@@ -8442,13 +8442,11 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+"org/ </link> ."
 msgstr ""
-"ImageMagick<filename>(convert)</filename> krävs för att generera de bilder "
-"som används i dokumentationen. ImageMagick är tillgängligt från <link xlink:"
 #. Tag: title
 #, no-c-format
@@ -51527,6 +51525,18 @@ msgstr "2.5/3D-stöd"
 msgstr "Stödjer geografi"
+#, no-c-format
+#~ msgid ""
+#~ "link> ."
+#~ msgstr ""
+#~ "ImageMagick<filename>(convert)</filename> krävs för att generera de "
+#~ "bilder som används i dokumentationen. ImageMagick är tillgängligt från "
+#~ "<link xlink:href=\"http://www.imagemagick.org/\"> http://www.imagemagick."
+#~ "org/ </link> ."
 #, no-c-format
 #~ msgid ""
diff --git a/doc/po/uk/postgis-manual.po b/doc/po/uk/postgis-manual.po
index 59d3fdc84..ee07a2171 100644
--- a/doc/po/uk/postgis-manual.po
+++ b/doc/po/uk/postgis-manual.po
@@ -8450,14 +8450,11 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+"org/ </link> ."
 msgstr ""
-"Для створення зображень, що використовуються в документації, необхідна "
-"програма ImageMagick (<filename>convert</filename>). ImageMagick доступна за "
-"адресою <link xlink:href=\"http://www.imagemagick.org/\"> http://www."
-"imagemagick.org/ </link> ."
 #. Tag: title
 #, no-c-format
@@ -49309,6 +49306,18 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ "link> ."
+#~ msgstr ""
+#~ "Для створення зображень, що використовуються в документації, необхідна "
+#~ "програма ImageMagick (<filename>convert</filename>). ImageMagick доступна "
+#~ "за адресою <link xlink:href=\"http://www.imagemagick.org/\"> http://www."
 #, no-c-format
 #~ msgid ""
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index a4e4198e9..bd88e2564 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -7744,13 +7744,11 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+"org/ </link> ."
 msgstr ""
-"ImageMagick (<filename>convert</filename>)生成文档中使用的图像。它位于<link "
-"link>。"
 #. Tag: title
 #, no-c-format
@@ -47391,6 +47389,17 @@ msgstr "2.5/3D 支持"
 msgstr "支持地理"
+#, no-c-format
+#~ msgid ""
+#~ "link> ."
+#~ msgstr ""
+#~ "ImageMagick (<filename>convert</filename>)生成文档中使用的图像。它位于"
+#~ "org/ </link>。"
 #, no-c-format
 #~ msgid ""
Summary of changes:
 doc/po/be/postgis-manual.po      |  7 ++--
 doc/po/da/postgis-manual.po      |  7 ++--
 doc/po/de/postgis-manual.po      | 23 +++++++----
 doc/po/es/postgis-manual.po      | 23 +++++++----
 doc/po/fr/postgis-manual.po      | 22 +++++++---
 doc/po/it_IT/postgis-manual.po   | 23 +++++++----
 doc/po/ja/postgis-manual.po      | 89 ++++++++++++++++++++++------------------
 doc/po/ka/postgis-manual.po      |  7 ++--
 doc/po/ko_KR/postgis-manual.po   | 22 +++++++---
 doc/po/pl/postgis-manual.po      |  7 ++--
 doc/po/pt_BR/postgis-manual.po   | 22 +++++++---
 doc/po/ro/postgis-manual.po      |  7 ++--
 doc/po/ru/postgis-manual.po      |  7 ++--
 doc/po/sv/postgis-manual.po      | 22 +++++++---
 doc/po/uk/postgis-manual.po      | 23 +++++++----
 doc/po/zh_Hans/postgis-manual.po | 21 +++++++---
 16 files changed, 217 insertions(+), 115 deletions(-)
hooks/post-receive
