[PostGIS] #5985: Can't do configure on trixie for stable-3.3 thru stable-3.5 branches
trac at osgeo.org
Thu Sep 11 18:44:16 PDT 2025
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.3.9
Component: postgis | Version: 3.5.x
Keywords: |
I thought maybe it wasn't because I didn't do a full dist-upgrade, but now
I have I'm still having issue configuring stable-3.3 thru stable-3.5
branches.
3.6 and master are fine.
I wanted to compile 3.3 to confirm I can replicate the behavior BAS was
experiencing with his dataset in #5984
But I presume it must be something we fixed in 3.6, master since those
seem to be fine.
For 3.3 on, I'm getting
branch 'stable-3.5' set up to track 'origin/stable-3.5'.
Switched to a new branch 'stable-3.5'
Already up to date.
autogen.sh: 70: test: Illegal number: Debian-2
* Running /usr/bin/libtoolize (Debian-2.5.4-4)
OPTIONS = --force --copy
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, 'build-aux'.
libtoolize: copying file 'build-aux/ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIRS, 'macros'.
libtoolize: copying file 'macros/libtool.m4'
libtoolize: copying file 'macros/ltoptions.m4'
libtoolize: copying file 'macros/ltsugar.m4'
libtoolize: copying file 'macros/ltversion.m4'
libtoolize: copying file 'macros/lt~obsolete.m4'
libtoolize: Consider adding '-I macros' to ACLOCAL_AMFLAGS in Makefile.am.
* Running /usr/bin/aclocal (1.17)
* Running /usr/bin/autoconf (2.72)
Now you are ready to run './configure'
configure: error: cannot find required auxiliary files: config.guess
config.sub install-sh
You need to run the 'configure' program first. See the file
'README.postgis' for installation instructions
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5985>
