[PostGIS] #5988: ST_ConcaveHull makes pg crash
PostGIS trac at osgeo.org
Mon Sep 15 10:58:31 PDT 2025
  Reporter:  severingeo  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.6.1
 Component:  postgis     |    Version:  3.5.x
Resolution:              |   Keywords:  ST_ConcaveHull
Description changed by severingeo:
Old description:
> I ran ST_ConcaveHull on OSM data in Senegal using PostGIS 3.3 (on PG 15),
> and it worked perfectly. However, when I tried with a different dataset
> (OSM data over the state of Bahia, Brazil), it caused PostgreSQL to crash
> with the following message: "server closed the connection unexpectedly
>         This probably means the server terminated abnormally
>         before or while processing the request."
> I updated PostGIS to version 3.61 this morning (still on pg 15), and now
> even Senegal crashes.
> Are there any plans in place to prevent these crashes, or at least to
> identify the objects that cause them?
New description:
 Or are these crashes related to PG15, and will a more recent version avoid
 them?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5988#comment:1>
