[PostGIS] #5982: CREATE EXTENSION POSTGIS must be done as SUPERUSER
trac at osgeo.org
Wed Sep 17 12:20:09 PDT 2025
Reporter: bceccarelli | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.1
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by robe):
We require postgis extension to require super user because we haven't
vetted all the pieces and it's too hard to vet. For example postgis
extension relies on other libraries, geos, proj and postgis_raster
extension has even more. So we are not prepared to mark it as trusted if
that is what you are asking for.
As Paul pointed out in the Aurora docs, that should work, and if it
doesn't you should be bugging the Aurora support team about this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5982#comment:2>
