[SCM] PostGIS branch master updated. 3.6.0rc2-50-g3db3470a8
Wed Sep 17 12:25:14 PDT 2025
the project "PostGIS".
       via  3db3470a87e7b960ca92ba52789e408c835f88d7 (commit)
      from  93113f80702b23e024bb4a729103c46e02d41a84 (commit)
revisions in full, below.
commit 3db3470a87e7b960ca92ba52789e408c835f88d7
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Sep 17 12:25:07 2025 -0700
    Add regression test for #5987
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 65810319b..46490a912 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1606,3 +1606,10 @@ SELECT f_table_schema, f_table_name, f_geometry_column, coord_dimension, srid, t
  FROM geometry_columns WHERE f_table_name IN ('test5829', 'test5978')
  ORDER BY f_table_name, f_geometry_column;
 DROP TABLE IF EXISTS test5829, test5978;
+-- #5987, ST_GeometryN broken on unitary geoms
+CREATE TABLE test5987 (geom geometry(Geometry,4326));
+INSERT INTO test5987 VALUES('LINESTRING(20 20,20.1 20,20.2 19.9)'::geometry);
+SELECT '#5987', ST_AsText(geom), ST_AsText(ST_GeometryN(geom, 1)) FROM test5987;
+DROP TABLE IF EXISTS test5987;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 61127d4da..dd5538e62 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -490,3 +490,4 @@ public.test5978.geometry SRID:4326 TYPE:POINT DIMS:2
 public|test5829|geom|2|4326|GEOMETRY
 public|test5978|geometry|2|4326|POINT
 public|test5978|shape|2|4326|POINT
+#5987|LINESTRING(20 20,20.1 20,20.2 19.9)|LINESTRING(20 20,20.1 20,20.2 19.9)
Summary of changes:
 regress/core/tickets.sql      | 7 +++++++
 regress/core/tickets_expected | 1 +
 2 files changed, 8 insertions(+)
hooks/post-receive
