[PostGIS] #5989: ST_Distance error on curvepolgyon
PostGIS trac at osgeo.org
Thu Sep 18 11:37:16 PDT 2025
  Reporter:  pramsey  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 3.5.4
 Component:  postgis  |    Version:  3.2.x
Resolution:           |   Keywords:
Comment (by pramsey):
 Note that testing the lines the curve distance calculation works and the
 distance between lines is 0.199. So the problem is probably in the
 containment test, and the polygon is erroneously being considered to be
 contained in the curvepolygon.
 SELECT ST_Distance(
   'MULTICURVE(
         CIRCULARSTRING(25498687.296406467
 6679794.584487298,25498670.728066746 6679772.920079741,25498652.7219
 6679752.4351),
         CIRCULARSTRING(25498584.874 6679680.3574,25498575.9211
 6679678.4791,25498571.0593 6679686.228),
         CIRCULARSTRING(25498572.6156 6679718.3893,25498575.9546
 6679753.1238,25498582.4167 6679787.4148,25498582.6547
 6679788.418,25498582.8953 6679789.4206)
   'POLYGON((25498577.925067347 6679764.376426865,25498577.31346041
 6679760.722689815,25498576.736966014 6679757.06324837,25498576.19563731
 6679753.398439955,25498575.68952422 6679749.72860249,25498575.218673404
 6679746.054074359,25498574.783128276 6679742.375194377,25498574.382929
 6679738.692301761,25498574.01811248 6679735.005736099,25498573.68871235
 6679731.315837314, 25498573.394758984 6679727.622945643,
 25498615.249195762 6679712.917382107,25498649.317714863
 6679749.110582217,25498629.859234665 6679763.425791496,25498626.597285368
 6679765.4664939325,25498616.53215853 6679754.940559511,25498616.475998268
 6679754.899373339,25498616.40912013 6679754.879941631,25498616.33963356
 6679754.884620618,25498577.925067347 6679764.376426865))'::geometry
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5989#comment:5>
