[PostGIS] #5990: Adding 2 lines to Postgis topology takes a more hours in a production line
PostGIS trac at osgeo.org
Fri Sep 19 04:42:43 PDT 2025
 Reporter:  Lars Aksel Opsahl  |      Owner:  strk
     Type:  defect             |     Status:  new
 Priority:  medium             |  Milestone:  PostGIS 3.6.1
Component:  topology           |    Version:  3.6.x
 Keywords:                     |
 Too a empty topology we first add the long thin lines and that is done in
 17 milli. secs. (picture)
 Then we add the second line which partly overlaps and have distance in
 around 2 millimeters from the first line and that takes almost 2 hours
 when running on a database with many threads and heavy on the system
 below.
 POSTGIS="3.6.0beta1 3.6.0beta1-10-ge0e19372b" [EXTENSION] PGSQL="160"
 GEOS="3.14.0beta3-CAPI-1.20.2" (compiled against GEOS 3.13.1) PROJ="9.3.0
 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ 9.3.0)
 LIBXML="2.9.13" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
 (Internal)" TOPOLOGY
 I have attached a file with the two lines and running that on my local mac
 and that takes almost 40 minuttes and ends with (3772 rows)
 On my local mac I run
 POSTGIS="3.5.0dev 3.4.0rc1-1310-g8349e1670" [EXTENSION] PGSQL="160"
 GEOS="3.13.0-CAPI-1.19.0" PROJ="9.5.1 NETWORK_ENABLED=OFF
 USER_WRITABLE_DIRECTORY=/Users/lop/Library/Application Support/proj
 DATABASE_PATH=/opt/homebrew/Cellar/proj/9.5.1/share/proj/proj.db"
 (compiled against PROJ 9.13.0) LIBXML="2.13.0" LIBJSON="0.18" TOPOLOGY
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5990>
