[PostGIS] #5990: Adding 2 lines to Postgis topology takes 2 hours in a production line we have
trac at osgeo.org
Sun Sep 21 01:28:02 PDT 2025
have
Reporter: Lars Aksel Opsahl | Owner: strk
Type: enhancement | Status: reopened
Priority: medium | Milestone: PostGIS 3.6.1
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
If we compare the resulting edge the from select
ST_Snap(line1,line2,1e-07) we also see that it's added many extra points
because I assume that's because snapToGrid is used so all points are moved
in postgis topology.
Could another way off doing when you define a Topology with zero Tolerance
then use only use ST_Snap(line1,line2,1e-07) .
This means that the first line is added with no changes because there are
no lines to snap to. The second line is then added by using
ST_Snap(line1,topology.edge,1e-07) because there is existing edge close by
to snapto when calling addLineString with tolerance 1e-07.
Another thing with is approach is also that we adjust input lines
according already added data in a very clear way and not try change
already added edges.
Is it hard to create branch where we can test this approach ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5990#comment:8>
