[PostGIS] #5990: Adding 2 lines to Postgis topology takes 2 hours in a production line we have
trac at osgeo.org
Mon Sep 22 08:32:14 PDT 2025
have
Reporter: Lars Aksel Opsahl | Owner: strk
Type: enhancement | Status: reopened
Priority: medium | Milestone: PostGIS 3.6.1
Component: topology | Version: 3.6.x
Resolution: | Keywords: performance
Comment (by strk):
Replying to [comment:9 Lars Aksel Opsahl]:
> With no snapping (zero Tolerance in the Topology)
Just a note: right now there is NO WAY to request no snapping (see #5688),
so what where you referring to here ? Is it 0 precision in the topology
record ? In that case a snapping tolerance is computed based on the input
line distance from origin.
I agree on a max_edges parameter, will work on a pull request for that.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5990#comment:13>
