[SCM] PostGIS branch master updated. 3.6.0rc2-53-g4ffe3ec21
Tue Sep 23 09:10:30 PDT 2025
the project "PostGIS".
       via  4ffe3ec21aaf13ce6cd059a9e7a7d3083c08c85f (commit)
      from  96ad06150ab2b19c367dc1ac625a8f35cd26d204 (commit)
revisions in full, below.
commit 4ffe3ec21aaf13ce6cd059a9e7a7d3083c08c85f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Sep 23 09:09:52 2025 -0700
    Ensure DISTPTS gets updated correctly in arc distance cases, references #5991
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index f41d760d8..bc240eb45 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -77,6 +77,18 @@ lw_dist2d_distpts_init(DISTPTS *dl, int mode)
 		dl->distance = -1 * FLT_MAX;
+static void
+lw_dist2d_distpts_set(DISTPTS *dl, double distance, const POINT2D *p1, const POINT2D *p2)
+	int update = (dl->mode == DIST_MIN) ? (distance < dl->distance) : (distance > dl->distance);
+	if (update)
+		dl->distance = distance;
+		dl->p1 = *p1;
+		dl->p2 = *p2;
 Function initializing shortestline and longestline calculations.
@@ -620,9 +632,7 @@ lw_dist2d_point_tri(LWPOINT *point, LWTRIANGLE *tri, DISTPTS *dl)
 	/* Is point inside triangle? */
 	if (dl->mode == DIST_MIN && ptarray_contains_point(tri->points, pt) != LW_OUTSIDE)
-		dl->distance = 0.0;
-		dl->p1.x = dl->p2.x = pt->x;
-		dl->p1.y = dl->p2.y = pt->y;
+		lw_dist2d_distpts_set(dl, 0.0, pt, pt);
 		return LW_TRUE;
@@ -666,9 +676,7 @@ lw_dist2d_point_poly(LWPOINT *point, LWPOLY *poly, DISTPTS *dl)
 			return lw_dist2d_pt_ptarray(p, poly->rings[i], dl);
 	/* Is inside the polygon */
-	dl->p1.x = dl->p2.x = p->x;
-	dl->p1.y = dl->p2.y = p->y;
+	lw_dist2d_distpts_set(dl, 0.0, p, p);
 	return LW_TRUE;
@@ -693,9 +701,7 @@ lw_dist2d_point_curvepoly(LWPOINT *point, LWCURVEPOLY *poly, DISTPTS *dl)
 			return lw_dist2d_recursive((LWGEOM *)point, poly->rings[i], dl);
 	return LW_TRUE;
@@ -714,9 +720,7 @@ lw_dist2d_line_tri(LWLINE *line, LWTRIANGLE *tri, DISTPTS *dl)
 	/* Is there a point inside triangle? */
 		return LW_TRUE;
@@ -768,9 +772,7 @@ lw_dist2d_line_poly(LWLINE *line, LWPOLY *poly, DISTPTS *dl)
 	/* Not in hole, so inside polygon */
 	if (dl->mode == DIST_MIN)
 	return LW_TRUE;
@@ -802,9 +804,7 @@ lw_dist2d_line_curvepoly(LWLINE *line, LWCURVEPOLY *poly, DISTPTS *dl)
 	return LW_TRUE;
@@ -817,18 +817,14 @@ lw_dist2d_tri_tri(LWTRIANGLE *tri1, LWTRIANGLE *tri2, DISTPTS *dl)
 	const POINT2D *pt = getPoint2d_cp(pa2, 0);
 	if (dl->mode == DIST_MIN && ptarray_contains_point(pa1, pt) != LW_OUTSIDE)
 		return LW_TRUE;
 	pt = getPoint2d_cp(pa1, 0);
 	if (dl->mode == DIST_MIN && ptarray_contains_point(pa2, pt) != LW_OUTSIDE)
 		return LW_TRUE;
@@ -859,9 +855,7 @@ lw_dist2d_tri_poly(LWTRIANGLE *tri, LWPOLY *poly, DISTPTS *dl)
 		const POINT2D *pt2 = getPoint2d_cp(poly->rings[0], 0);
 		if (ptarray_contains_point(pa, pt2) != LW_OUTSIDE)
-			dl->p1.x = dl->p2.x = pt2->x;
-			dl->p1.y = dl->p2.y = pt2->y;
+			lw_dist2d_distpts_set(dl, 0.0, pt2, pt2);
 			return LW_TRUE;
@@ -882,9 +876,7 @@ lw_dist2d_tri_poly(LWTRIANGLE *tri, LWPOLY *poly, DISTPTS *dl)
 			return LW_TRUE;
 	return LW_TRUE;
 static const POINT2D *
@@ -925,9 +917,7 @@ lw_dist2d_tri_curvepoly(LWTRIANGLE *tri, LWCURVEPOLY *poly, DISTPTS *dl)
 		/* Maybe poly is inside triangle? */
 		if (lwgeom_contains_point((LWGEOM *)tri, lw_curvering_getfirstpoint2d_cp(poly->rings[0])) != LW_OUTSIDE)
 			return LW_TRUE;
@@ -948,9 +938,7 @@ lw_dist2d_tri_curvepoly(LWTRIANGLE *tri, LWCURVEPOLY *poly, DISTPTS *dl)
 			return LW_TRUE;
 	return LW_TRUE;
@@ -960,9 +948,7 @@ lw_dist2d_tri_circstring(LWTRIANGLE *tri, LWCIRCSTRING *line, DISTPTS *dl)
 	const POINT2D *pt = lw_curvering_getfirstpoint2d_cp((LWGEOM *)line);
 	if (ptarray_contains_point(tri->points, pt) != LW_OUTSIDE && dl->mode == DIST_MIN)
 		return LW_TRUE;
@@ -1019,18 +1005,14 @@ lw_dist2d_poly_poly(LWPOLY *poly1, LWPOLY *poly2, DISTPTS *dl)
 	pt = getPoint2d_cp(poly1->rings[0], 0);
 	if (ptarray_contains_point(poly2->rings[0], pt) != LW_OUTSIDE)
 		return LW_TRUE;
 	pt = getPoint2d_cp(poly2->rings[0], 0);
 	if (ptarray_contains_point(poly1->rings[0], pt) != LW_OUTSIDE)
 		return LW_TRUE;
@@ -1107,18 +1089,14 @@ lw_dist2d_curvepoly_curvepoly(LWCURVEPOLY *poly1, LWCURVEPOLY *poly2, DISTPTS *d
 	pt = lw_curvering_getfirstpoint2d_cp(poly1->rings[0]);
 	if (lwgeom_contains_point(poly2->rings[0], pt) != LW_OUTSIDE)
 		return LW_TRUE;
 	pt = lw_curvering_getfirstpoint2d_cp(poly2->rings[0]);
 	if (lwgeom_contains_point(poly1->rings[0], pt) != LW_OUTSIDE)
 		return LW_TRUE;
@@ -1432,9 +1410,7 @@ lw_dist2d_seg_arc(const POINT2D *A1,
 		if (pt_in_arc && pt_in_seg)
-			dl->p1 = E;
-			dl->p2 = E;
+			lw_dist2d_distpts_set(dl, 0.0, &E, &E);
 			return LW_TRUE;
@@ -1444,9 +1420,7 @@ lw_dist2d_seg_arc(const POINT2D *A1,
-			dl->p1 = F;
-			dl->p2 = F;
+			lw_dist2d_distpts_set(dl, 0.0, &F, &F);
 			return LW_TRUE;
@@ -1463,9 +1437,7 @@ lw_dist2d_seg_arc(const POINT2D *A1,
 		/* Is D contained in both A and B? */
-			dl->p1 = D;
-			dl->p2 = D;
+			lw_dist2d_distpts_set(dl, 0.0, &D, &D);
 			return LW_TRUE;
@@ -1546,9 +1518,7 @@ lw_dist2d_pt_arc(const POINT2D *P, const POINT2D *A1, const POINT2D *A2, const P
 	/* P is the center of the circle */
 	if (FP_EQUALS(d, 0.0))
-		dl->distance = radius_A;
-		dl->p1 = *A1;
-		dl->p2 = *P;
+		lw_dist2d_distpts_set(dl, radius_A, A1, P);
 		return LW_TRUE;
@@ -1667,9 +1637,7 @@ lw_dist2d_arc_arc(const POINT2D *A1,
 		/* Arcs do touch at D, return it */
 		if (pt_in_arc_A && pt_in_arc_B)
-			dl->p1 = D;
-			dl->p2 = D;
 			return LW_TRUE;
@@ -1721,8 +1689,7 @@ lw_dist2d_arc_arc(const POINT2D *A1,
-			dl->p1 = dl->p2 = E;
 			return LW_TRUE;
@@ -1736,8 +1703,7 @@ lw_dist2d_arc_arc(const POINT2D *A1,
-			dl->p1 = dl->p2 = F;
 			return LW_TRUE;
@@ -1800,32 +1766,24 @@ lw_dist2d_arc_arc_concentric(const POINT2D *A1,
 		seg_size = lw_segment_side(A1, A3, A2);
 		if (seg_size == lw_segment_side(A1, A3, B1))
-			dl->p1 = *B1;
-			dl->p2 = *B1;
-			dl->distance = 0;
+			lw_dist2d_distpts_set(dl, 0.0, B1, B1);
 			return LW_TRUE;
 		if (seg_size == lw_segment_side(A1, A3, B3))
-			dl->p1 = *B3;
-			dl->p2 = *B3;
-			dl->distance = 0;
+			lw_dist2d_distpts_set(dl, 0.0, B3, B3);
 			return LW_TRUE;
 		/* Check if A1 or A3 are in the same side as B2 in the B1-B3 arc */
 		seg_size = lw_segment_side(B1, B3, B2);
 		if (seg_size == lw_segment_side(B1, B3, A1))
-			dl->p1 = *A1;
-			dl->p2 = *A1;
-			dl->distance = 0;
+			lw_dist2d_distpts_set(dl, 0.0, A1, A1);
 			return LW_TRUE;
 		if (seg_size == lw_segment_side(B1, B3, A3))
-			dl->p1 = *A3;
-			dl->p2 = *A3;
-			dl->distance = 0;
+			lw_dist2d_distpts_set(dl, 0.0, A3, A3);
 			return LW_TRUE;
@@ -1840,9 +1798,7 @@ lw_dist2d_arc_arc_concentric(const POINT2D *A1,
 		if (seg_size == lw_segment_side(A1, A3, &proj))
-			dl->p1 = proj;
-			dl->p2 = *B1;
-			dl->distance = fabs(radius_A - radius_B);
+			lw_dist2d_distpts_set(dl, fabs(radius_A - radius_B), &proj, B1);
 			return LW_TRUE;
 		/* B3 */
@@ -1850,9 +1806,7 @@ lw_dist2d_arc_arc_concentric(const POINT2D *A1,
 		proj.y = CENTER->y + (B3->y - CENTER->y) * radius_A / radius_B;
-			dl->p1 = proj;
-			dl->p2 = *B3;
+			lw_dist2d_distpts_set(dl, fabs(radius_A - radius_B), &proj, B3);
 			return LW_TRUE;
@@ -1864,9 +1818,7 @@ lw_dist2d_arc_arc_concentric(const POINT2D *A1,
 		proj.y = CENTER->y + (A1->y - CENTER->y) * radius_B / radius_A;
 		if (seg_size == lw_segment_side(B1, B3, &proj))
-			dl->p1 = proj;
-			dl->p2 = *A1;
+			lw_dist2d_distpts_set(dl, fabs(radius_A - radius_B), &proj, A1);
 			return LW_TRUE;
@@ -1875,9 +1827,7 @@ lw_dist2d_arc_arc_concentric(const POINT2D *A1,
 		proj.y = CENTER->y + (A3->y - CENTER->y) * radius_B / radius_A;
-			dl->p1 = proj;
-			dl->p2 = *A3;
+			lw_dist2d_distpts_set(dl, fabs(radius_A - radius_B), &proj, A3);
 			return LW_TRUE;
@@ -1911,10 +1861,7 @@ lw_dist2d_arc_arc_concentric(const POINT2D *A1,
 		P2 = B3;
-	dl->p1 = *P1;
-	dl->p2 = *P2;
-	dl->distance = sqrt(shortest_sqr);
+	lw_dist2d_distpts_set(dl, sqrt(shortest_sqr), P1, P2);
 	return LW_TRUE;
@@ -2019,9 +1966,7 @@ lw_dist2d_seg_seg(const POINT2D *A, const POINT2D *B, const POINT2D *C, const PO
 				theP.x = A->x + r * (B->x - A->x);
 				theP.y = A->y + r * (B->y - A->y);
-			dl->p1 = theP;
-			dl->p2 = theP;
+			lw_dist2d_distpts_set(dl, 0, &theP, &theP);
 		return LW_TRUE;
@@ -2365,9 +2310,7 @@ lw_dist2d_pt_seg(const POINT2D *p, const POINT2D *A, const POINT2D *B, DISTPTS *
 	/*If the point p is on the segment this is a more robust way to find out that*/
 	if ((((A->y - p->y) * (B->x - A->x) == (A->x - p->x) * (B->y - A->y))) && (dl->mode == DIST_MIN))
-		dl->p1 = *p;
-		dl->p2 = *p;
+		lw_dist2d_distpts_set(dl, 0, p, p);
Summary of changes:
 liblwgeom/measures.c | 151 ++++++++++++++++-----------------------------------
 1 file changed, 47 insertions(+), 104 deletions(-)
hooks/post-receive
