[SCM] PostGIS branch master updated. 3.6.0rc2-66-gecfb41a80
git at osgeo.org
git at osgeo.org
Tue Sep 30 06:22:43 PDT 2025
the project "PostGIS".
via ecfb41a80c3c01e67a76ff264aba9a89bb0a03c3 (commit)
from b1d3d414588470fbadbb19d97b9fa4f5166b56fc (commit)
revisions in full, below.
commit ecfb41a80c3c01e67a76ff264aba9a89bb0a03c3
Author: Regina Obe <lr at pcorp.us>
Date: Tue Sep 30 09:21:05 2025 -0400
CI reorg
- Remove dronie
- Remove PG12 testing
- Add PG13, PG14, PG15
- But only test upgrade check on 13 and 17 to not make times ridiculous
diff --git a/.drone-1.0.yml b/.drone-1.0.yml
deleted file mode 100644
index 1d26bed26..000000000
--- a/.drone-1.0.yml
+++ /dev/null
@@ -1,38 +0,0 @@
-# This is for the drone 1.0 agent
-# https://docs.drone.io/user-guide/pipeline/steps/
-# https://dronie.osgeo.org #1.0 server
-# See https://git.osgeo.org/gitea/postgis/postgis-docker
-# todo: add docker images from https://hub.docker.com/r/postgis/postgis-build-env/tags/
-test-image: &test-image docker.osgeo.org/postgis/build-test:trisquel11
-clone: &clone
- image: plugins/git
- depth: 50
- recursive: false
-kind: pipeline
-name: build
-clone: *clone
-steps:
- - name: autogen
- image: *test-image
- pull: always
- commands:
- - ./autogen.sh
- depends_on: [ clone ]
- - name: build-13
- pull: never
- commands:
- - PGVER=13 sh ci/dronie/postgis_regress.sh
- depends_on: [ autogen ]
- - name: build-14
- pull: never
- commands:
- - PGVER=14 sh ci/dronie/postgis_regress.sh
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index cbf30231d..87c1b47f7 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -59,11 +59,29 @@ steps:
commands:
- ./autogen.sh
- build-pg12:
+ build-pg13:
image: *test-image
depends_on: autogen
environment:
- PGVER: 12
+ PGVER: 13
+ commands:
+ - <<: *steps-env
+ - <<: *steps-pg-build
+ build-pg14:
+ image: *test-image
+ depends_on: autogen
+ environment:
+ PGVER: 14
+ commands:
+ - <<: *steps-env
+ build-pg15:
+ environment:
+ PGVER: 15
commands:
- <<: *steps-env
@@ -77,11 +95,31 @@ steps:
- <<: *steps-env
- check-pg12:
+ check-pg13:
image: *test-image
- depends_on: build-pg12
+ depends_on: build-pg13
environment:
- PGVER: 12
+ PGVER: 13
+ commands:
+ - <<: *steps-env
+ - <<: *steps-start-postgresql
+ - <<: *steps-pg-test-preinstall
+ check-pg14:
+ depends_on: build-pg14
+ environment:
+ PGVER: 14
+ commands:
+ - <<: *steps-env
+ check-pg15:
+ depends_on: build-pg15
+ environment:
+ PGVER: 15
commands:
- <<: *steps-env
@@ -97,11 +135,33 @@ steps:
- installcheck-pg12:
+ installcheck-pg13:
image: *test-image
environment:
- PGVER: 12
+ PGVER: 13
+ commands:
+ - <<: *steps-env
+ - <<: *steps-pg-install
+ - <<: *steps-pg-test-install
+ installcheck-pg14:
+ environment:
+ PGVER: 14
+ commands:
+ - <<: *steps-env
+ installcheck-pg15:
+ environment:
+ PGVER: 15
commands:
- <<: *steps-env
@@ -119,11 +179,11 @@ steps:
- upgradecheck-pg12:
+ upgradecheck-pg13:
image: *test-image
- depends_on: installcheck-pg12
+ depends_on: installcheck-pg13
environment:
- PGVER: 12
+ PGVER: 13
commands:
- <<: *steps-env
Summary of changes:
.drone-1.0.yml | 38 -----------------------
.woodpecker/regress.yml | 82 ++++++++++++++++++++++++++++++++++++++++++-------
2 files changed, 71 insertions(+), 49 deletions(-)
delete mode 100644 .drone-1.0.yml
hooks/post-receive
