[SCM] PostGIS branch master updated. 3.7.0beta1-160-gc1e91f8b1e
git at osgeo.org
git at osgeo.org
Sat Aug 1 11:10:43 PDT 2026
the project "PostGIS".
via c1e91f8b1e5612e8d7ec50b3a7705cab232103db (commit)
via 8c966a0071b95040e96c741e2ee13e977c5d4b40 (commit)
from 1df65a1b92af4bd5162d08c5fbc4fa3133ae46c8 (commit)
revisions in full, below.
commit c1e91f8b1e5612e8d7ec50b3a7705cab232103db
Merge: 1df65a1b92 8c966a0071
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Aug 1 11:10:36 2026 -0700
Merge pull request 'liblwgeom: validate serialized NURBS invariants' (!640) from Komzpa/postgis:oss-fuzz-4885548695879680 into master
Reject malformed GSERIALIZED v2 NURBS payloads before they can reach curve evaluation and bbox calculation. The validator now mirrors the constructor invariants for degree, control-point count, optional weight count, optional knot count, finite positive weights, and finite nondecreasing knots.
This fixes the OSS-Fuzz gserialized_from_bytea_fuzzer testcase that reached lwnurbscurve_evaluate via lwgeom_calculate_gbox_cartesian.
Affected releases: this is on the unreleased 3.7 development line. The maintained stable branches stable-3.2 through stable-3.6 do not contain the NURBS curve code path, and there is currently no stable-3.7 branch to backpatch.
Validation:
- clang ASAN focused build: ./configure CC=clang CXX=clang++ --without-raster --without-topology --without-sfcgal CFLAGS="-g3 -O0 -fno-omit-frame-pointer -fsanitize=address" CXXFLAGS="-g3 -O0 -fno-omit-frame-pointer -fsanitize=address" LDFLAGS="-fsanitize=address"
- ./liblwgeom/cunit/cu_tester "serialization/deserialization v2" — 16 passed, 0 failed, 462 asserts
- ./liblwgeom/cunit/cu_tester test_gserialized2_malformed_nurbs_degree — 9 asserts passed
- tmp-fuzz-out/gserialized_from_bytea_fuzzer clusterfuzz-testcase-minimized-gserialized_from_bytea_fuzzer-4885548695879680 — exit 0
Credit to OSS-Fuzz: https://oss-fuzz.com/testcase?key=4885548695879680
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/640
commit 8c966a0071b95040e96c741e2ee13e977c5d4b40
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Aug 1 22:07:06 2026 +0400
Reject malformed GSERIALIZED v2 NURBS curves before deserialization can hand inconsistent degree, point, weight, or knot counts to curve evaluation and bbox calculation.
diff --git a/NEWS b/NEWS
index 34c494e701..1443dee89a 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,8 @@ These are only changes since 3.7.0beta1.
* Bug Fixes *
+ - [liblwgeom] Reject malformed GSERIALIZED NURBS before curve
+ evaluation (Darafei Praliaskouski)
- Make the computed-columns regression test assert the query plan instead of racing two
stopwatches, so it no longer fails at random under CI load
diff --git a/liblwgeom/cunit/cu_gserialized2.c b/liblwgeom/cunit/cu_gserialized2.c
index 44be675094..c02c5b2f83 100644
--- a/liblwgeom/cunit/cu_gserialized2.c
+++ b/liblwgeom/cunit/cu_gserialized2.c
@@ -527,6 +527,8 @@ gserialized2_from_hexbytes(const char *hex)
return g;
+static void assert_gserialized2_malformed_rejected(GSERIALIZED *g);
static void
test_gserialized2_malformed_collection_count(void)
@@ -545,6 +547,28 @@ test_gserialized2_malformed_collection_count(void)
lwfree(g);
+static void
+test_gserialized2_malformed_nurbs_degree(void)
+ LWGEOM *lwgeom = lwgeom_from_wkt("NURBSCURVE(2, (0 0, 1 1, 2 0))", LW_PARSER_CHECK_NONE);
+ GSERIALIZED *g;
+ uint32_t *payload;
+ CU_ASSERT_PTR_NOT_NULL_FATAL(lwgeom);
+ g = gserialized2_from_lwgeom(lwgeom, NULL);
+ CU_ASSERT_PTR_NOT_NULL_FATAL(g);
+ payload = (uint32_t *)gserialized2_get_geometry_p(g);
+ CU_ASSERT_EQUAL(payload[0], NURBSCURVETYPE);
+ CU_ASSERT_EQUAL(payload[1], 3);
+ payload[2] = 3; /* Three control points cannot support a degree-3 curve. */
+ assert_gserialized2_malformed_rejected(g);
+ lwgeom_free(lwgeom);
+ lwfree(g);
static void
@@ -658,6 +682,7 @@ void gserialized2_suite_setup(void)
PG_ADD_TEST(suite, test_gserialized2_extended_flags);
PG_ADD_TEST(suite, test_gserialized2_peek_first_point);
PG_ADD_TEST(suite, test_gserialized2_malformed_collection_count);
+ PG_ADD_TEST(suite, test_gserialized2_malformed_nurbs_degree);
PG_ADD_TEST(suite, test_gserialized2_malformed_declared_size);
PG_ADD_TEST(suite, test_gserialized2_malformed_short_allocation);
PG_ADD_TEST(suite, test_gserialized2_wkb_roundtrip_float_rounded_box);
diff --git a/liblwgeom/gserialized2.c b/liblwgeom/gserialized2.c
index 813098c77a..7a89593c6d 100644
--- a/liblwgeom/gserialized2.c
+++ b/liblwgeom/gserialized2.c
@@ -68,6 +68,77 @@ static int gserialized2_read_gbox_p(const GSERIALIZED *g, GBOX *gbox);
static int gserialized2_payload_bounds(const GSERIALIZED *g, uint8_t **start, uint8_t **end);
static int gserialized2_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size);
+static int
+gserialized2_validate_nurbs(uint32_t npoints,
+ uint32_t degree,
+ uint32_t nweights,
+ uint32_t nknots,
+ const double *weights,
+ const double *knots)
+ uint32_t i;
+ size_t expected_nknots;
+ if (degree < 1 || degree > 10)
+ lwerror("NURBS: degree %u outside valid range [1,10]", degree);
+ return LW_FAILURE;
+ if (npoints == 0)
+ if (nweights != 0 || nknots != 0)
+ lwerror("NURBS: empty curve cannot declare weights or knots");
+ return LW_SUCCESS;
+ if (npoints < degree + 1)
+ lwerror("NURBS: npoints (%u) must be at least degree + 1 (%u)", npoints, degree + 1);
+ if (nweights > 0 && nweights != npoints)
+ lwerror("NURBS: nweights (%u) must equal number of control points (%u)", nweights, npoints);
+ expected_nknots = (size_t)npoints + degree + 1;
+ if (nknots > 0 && nknots != expected_nknots)
+ lwerror("NURBS: nknots (%u) must equal npoints + degree + 1 (%zu)", nknots, expected_nknots);
+ for (i = 0; i < nweights; i++)
+ if (!isfinite(weights[i]) || weights[i] <= 0.0)
+ lwerror("NURBS: weight[%u] = %g must be finite and > 0", i, weights[i]);
+ for (i = 1; i < nknots; i++)
+ if (!isfinite(knots[i]) || knots[i] < knots[i - 1])
+ lwerror("NURBS: knot[%u] = %g must be finite and >= knot[%u] = %g",
+ i,
+ knots[i],
+ i - 1,
+ knots[i - 1]);
static size_t
gserialized2_buffer_size(const GSERIALIZED *g)
@@ -441,14 +512,16 @@ gserialized2_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwfl
case NURBSCURVETYPE: {
- uint32_t nweights, nknots;
+ uint32_t degree, nweights, nknots;
size_t weight_bytes, knot_bytes, point_bytes;
+ const uint8_t *weights_ptr, *knots_ptr;
consumed = 6 * sizeof(uint32_t);
if (!gserialized2_range_available(data_ptr, data_end, consumed))
lwerror("%s: GSERIALIZED NURBS header exceeds payload size", __func__);
return LW_FAILURE;
+ degree = gserialized2_read_uint32_checked(data_ptr + 2 * sizeof(uint32_t), data_end, "NURBS degree");
nweights =
gserialized2_read_uint32_checked(data_ptr + 3 * sizeof(uint32_t), data_end, "NURBS weight count");
nknots =
@@ -468,6 +541,12 @@ gserialized2_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwfl
lwerror("%s: GSERIALIZED NURBS size overflows", __func__);
return LW_FAILURE;
+ weights_ptr = data_ptr + 6 * sizeof(uint32_t);
+ knots_ptr = weights_ptr + weight_bytes;
+ if (gserialized2_validate_nurbs(
+ count, degree, nweights, nknots, (const double *)weights_ptr, (const double *)knots_ptr) ==
+ LW_FAILURE)
break;
@@ -2219,6 +2298,17 @@ lwnurbscurve_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size
/* Skip 4-byte pad to align following doubles (weights/knots/coords) */
data_ptr += sizeof(uint32_t);
+ if (gserialized2_validate_nurbs(npoints,
+ degree,
+ nweights,
+ nknots,
+ (const double *)data_ptr,
+ (const double *)(data_ptr + sizeof(double) * nweights)) == LW_FAILURE)
+ lwfree(curve);
+ return NULL;
* VARIABLE SECTION 1: Read weight values (if any)
Summary of changes:
NEWS | 2 +
liblwgeom/cunit/cu_gserialized2.c | 25 +++++++++++
liblwgeom/gserialized2.c | 92 ++++++++++++++++++++++++++++++++++++++-
3 files changed, 118 insertions(+), 1 deletion(-)
hooks/post-receive
