[SCM] PostGIS branch master updated. 3.7.0beta1-166-g28528f2b7a
Sat Aug 1 22:33:28 PDT 2026
the project "PostGIS".
       via  28528f2b7a1cbb6e9b06be3c6422b00db0722b46 (commit)
      from  263a3dbf965755f09b4f0a3aecc367b131641240 (commit)
revisions in full, below.
commit 28528f2b7a1cbb6e9b06be3c6422b00db0722b46
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Aug 2 01:31:59 2026 -0400
    Add regress tests and news for geometry_columns speed issue
    References #6110 for PostGIS 3.7.0
diff --git a/NEWS b/NEWS
index 2269a09052..08d1623765 100644
--- a/NEWS
+++ b/NEWS
@@ -35,6 +35,7 @@ These are only changes since 3.7.0beta1.
           geometry data (Darafei Praliaskouski)
  - GT-564, Avoid ST_MakePolygon failures with NULL hole array entries
+ - #6110, regression in speed with geometry_columns
 * Enhancements *
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index fd03131cee..84525a6f9e 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1813,3 +1813,56 @@ SELECT '#5357', ST_AsText(ST_LineFromEncodedPolyline('__nphBgcoeiA?@', 6), 6);
 SELECT 'makepolygon-null-holes', ST_NPoints(ST_MakePolygon(
 	'LINESTRING ZM (0 0 0 0,0 1 0 0,1 1 0 0,0 0 0 0)'::geometry,
 	ARRAY[NULL::geometry]));
+-- #6110, geometry_columns view should be fast even with many spatial tables
+CREATE SCHEMA test6110;
+CREATE FUNCTION test6110_check() RETURNS text AS $$
+DECLARE
+    t0 timestamptz;
+    t1 timestamptz;
+    elapsed interval;
+    n bigint;
+    tolerance interval;
+BEGIN
+    tolerance := interval '2 seconds' * COALESCE(
+        NULLIF(current_setting('test.executor_slow_factor', true), ''), '1'
+    )::double precision;
+    SELECT count(*) INTO n FROM geometry_columns
+      WHERE f_table_schema = 'test6110';
+    IF n <> 1000 THEN
+        RETURN 'FAIL: count=' || n || ' (expected 1000)';
+    END IF;
+    t0 := clock_timestamp();
+    t1 := clock_timestamp();
+    elapsed := t1 - t0;
+    RAISE LOG 'geometry_columns count of test6110 took % (rows=%)', elapsed, n;
+    IF elapsed > tolerance THEN
+        RETURN 'FAIL: count took ' || elapsed || ' > ' || tolerance;
+    END IF;
+    RETURN 'PASS';
+END;
+$$ LANGUAGE plpgsql;
+DO $$
+DECLARE i integer;
+BEGIN
+    FOR i IN 1..500 LOOP
+        EXECUTE format('CREATE TABLE test6110.typmod_%s (geom geometry(Point, 4326))', i);
+        EXECUTE format('CREATE TABLE test6110.constraint_%s (id integer)', i);
+        EXECUTE format('SELECT AddGeometryColumn(%L, %L, %L, 4326, %L, 2, false)',
+                       'test6110', 'constraint_' || i, 'geom', 'POINT');
+    END LOOP;
+END
+SELECT '#6110', test6110_check();
+DROP FUNCTION test6110_check();
+DROP SCHEMA test6110 CASCADE;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index f6b6ec305c..9cc8aefd9a 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -526,3 +526,4 @@ public|test5978|shape|2|4326|POINT
 1|01030000209713000000000000
 #5357|LINESTRING(38.903876 55.336448,38.903875 55.336448)
 makepolygon-null-holes|4
+#6110|PASS
Summary of changes:
 NEWS                          |  1 +
 regress/core/tickets.sql      | 53 +++++++++++++++++++++++++++++++++++++++++++
 regress/core/tickets_expected |  1 +
 3 files changed, 55 insertions(+)
hooks/post-receive
