[SCM] PostGIS branch master updated. 3.7.0beta1-171-g7684171f72
Sun Aug 2 00:16:29 PDT 2026
the project "PostGIS".
       via  7684171f72b40191e6c7eea82a72a7aa0d83cbc2 (commit)
       via  c01ccdc82f1dde302aea7218587629dd3347c7b6 (commit)
      from  ad95178cf35dd18826561eb64a95a46b3b7ff5d7 (commit)
revisions in full, below.
commit 7684171f72b40191e6c7eea82a72a7aa0d83cbc2
Merge: ad95178cf3 c01ccdc82f
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Aug 2 00:16:28 2026 -0700
    Merge pull request 'Stop -Werror=stringop-overflow rejecting the malformed-NURBS unit test' (!642) from Komzpa/postgis:ci/fix-stringop-overflow-cunit-20260802 into master
    The `pg14-geos310-gdal33-proj71` matrix cell on GitHub Actions fails on **every** open pull
    request, and on none of their accounts — it fails on master:
        cu_gserialized2.c: In function 'test_gserialized2_malformed_nurbs_degree':
        cu_gserialized2.c:564:13: error: writing 4 bytes into a region of size 0 [-Werror=stringop-overflow=]
          564 |  payload[2] = 3; /* Three control points cannot support a degree-3 curve. */
        make: *** [GNUmakefile:37: check-unit] Error 1
    `test_gserialized2_malformed_nurbs_degree` deliberately corrupts a serialized NURBSCURVE's
    degree field to prove the parser rejects it, writing through the pointer
    `gserialized2_get_geometry_p` returns. GCC 10 sizes that region as zero, so an intentional,
    in-bounds write reads as an overflow and `-Werror` makes it fatal.
    Routing the pointer through a `noinline` helper leaves the object-size analysis nothing to
    conclude. This deliberately does **not** suppress the diagnostic for the file — the rest of
    `cu_gserialized2.c` keeps being checked — and does not change what the test asserts.
    Verified inside the failing image itself (`postgis/postgis-build-env:pg14-geos310-gdal33-proj71`,
    gcc 10.2.1): the error reproduces before the change, the compile exits 0 after it, and
    `make -C liblwgeom check-unit` runs 50 suites and 5775 assertions with none failing, the
    malformed-degree test among them.
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/642
commit c01ccdc82f1dde302aea7218587629dd3347c7b6
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Aug 2 03:11:58 2026 +0400
    Stop -Werror=stringop-overflow rejecting the malformed-NURBS test
    The pg14-geos310-gdal33-proj71 CI cell fails on every pull request, and has
    nothing to do with any of them.  test_gserialized2_malformed_nurbs_degree
    deliberately corrupts a serialized NURBSCURVE's degree field to prove the
    parser rejects it, writing through the pointer gserialized2_get_geometry_p
    returns.  GCC 10 sizes that region as zero and reports the write as an
    overflow:
    The write is in bounds; the diagnostic is a false positive from the declared
    shape of the trailing data member.  Route the pointer through a noinline
    helper so the object-size analysis has nothing to conclude, rather than
    silencing the warning for the file — the rest of it should keep checking.
    Reproduced and fixed inside the failing image itself
    (postgis/postgis-build-env:pg14-geos310-gdal33-proj71, gcc 10.2.1): the
    compile now exits 0, and check-unit runs 50 suites and 5775 assertions with
    none failing, the malformed-degree test among them.
diff --git a/liblwgeom/cunit/cu_gserialized2.c b/liblwgeom/cunit/cu_gserialized2.c
index c02c5b2f83..c60b0f56b8 100644
--- a/liblwgeom/cunit/cu_gserialized2.c
+++ b/liblwgeom/cunit/cu_gserialized2.c
@@ -529,6 +529,20 @@ gserialized2_from_hexbytes(const char *hex)
 static void assert_gserialized2_malformed_rejected(GSERIALIZED *g);
+#if defined(__GNUC__) || defined(__clang__)
+#define CUNIT_NOINLINE __attribute__((noinline))
+#else
+#endif
+static CUNIT_NOINLINE uint8_t *
+gserialized2_test_payload_p(GSERIALIZED *g)
+	return (uint8_t *)(void *)gserialized2_get_geometry_p(g);
+#undef CUNIT_NOINLINE
 static void
 test_gserialized2_malformed_collection_count(void)
@@ -552,16 +566,22 @@ test_gserialized2_malformed_nurbs_degree(void)
 	LWGEOM *lwgeom = lwgeom_from_wkt("NURBSCURVE(2, (0 0, 1 1, 2 0))", LW_PARSER_CHECK_NONE);
 	GSERIALIZED *g;
-	uint32_t *payload;
+	uint8_t *payload;
+	uint32_t type;
+	uint32_t npoints;
+	uint32_t degree = 3;
 	CU_ASSERT_PTR_NOT_NULL_FATAL(lwgeom);
 	g = gserialized2_from_lwgeom(lwgeom, NULL);
 	CU_ASSERT_PTR_NOT_NULL_FATAL(g);
-	payload = (uint32_t *)gserialized2_get_geometry_p(g);
-	CU_ASSERT_EQUAL(payload[0], NURBSCURVETYPE);
-	CU_ASSERT_EQUAL(payload[1], 3);
-	payload[2] = 3; /* Three control points cannot support a degree-3 curve. */
+	payload = gserialized2_test_payload_p(g);
+	memcpy(&type, payload, sizeof(type));
+	memcpy(&npoints, payload + sizeof(uint32_t), sizeof(npoints));
+	CU_ASSERT_EQUAL(type, NURBSCURVETYPE);
+	CU_ASSERT_EQUAL(npoints, 3);
+	/* Three control points cannot support a degree-3 curve. */
+	memcpy(payload + 2 * sizeof(uint32_t), &degree, sizeof(degree));
 	assert_gserialized2_malformed_rejected(g);
Summary of changes:
 liblwgeom/cunit/cu_gserialized2.c | 30 +++++++++++++++++++++++++-----
 1 file changed, 25 insertions(+), 5 deletions(-)
hooks/post-receive
