[SCM] PostGIS branch master updated. 3.7.0beta1-177-g07bdf384af
git at osgeo.org
git at osgeo.org
Sun Aug 2 12:20:25 PDT 2026
the project "PostGIS".
via 07bdf384af94565ac3e2ed5774afddea0f5ca548 (commit)
via 248b014b9805911792e2fcc097ce7c0cde422308 (commit)
from 08f9832fb36e066a57e53f285cf33914e9061aaf (commit)
revisions in full, below.
commit 07bdf384af94565ac3e2ed5774afddea0f5ca548
Merge: 08f9832fb3 248b014b98
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Aug 2 12:20:13 2026 -0700
Merge pull request 'Do not ANALYZE inside the extension upgrade transaction' (!650) from Komzpa/postgis:ci/no-analyze-in-extension-script-20260802 into master
`spatial_ref_sys.sql` ends with
ON CONFLICT (srid) DO NOTHING;
COMMIT;
ANALYZE "spatial_ref_sys";
The `ANALYZE` follows `COMMIT` on purpose: run standalone, it refreshes the statistics of a
table that has just gained thousands of rows, outside any transaction.
`extensions/postgis/Makefile.in` strips `BEGIN` and `COMMIT` — its own comment says why,
"these are not allowed in extensions" — and leaves the `ANALYZE`. So the statement written to
run *after* the transaction ends up *inside* the extension upgrade's transaction, takes
`ShareUpdateExclusiveLock` on `spatial_ref_sys`, and can deadlock against autovacuum analysing
the same table:
ERROR: deadlock detected
DETAIL: Process 8802 waits for ShareUpdateExclusiveLock on relation 52329 ...;
blocked by process 8803. Process 8803 waits for ShareLock on
transaction 9332; blocked by process 8802.
CONTEXT: SQL statement "ANALYZE "spatial_ref_sys""
extension script file "postgis--ANY--3.7.0dev.sql", near line 45810
**This is not only a CI problem.** `ALTER EXTENSION postgis UPDATE` runs this script on real
databases, where autovacuum is running by definition, so an upgrade on a busy installation can
simply abort.
It also explains real CI noise: three of the eleven most recent failed Woodpecker pipelines
died this way, in `regress/test-install` and `regress/test-upgrades`, on ordinary amd64 rows
rather than emulated ones. Pull request 626 addressed the same class on armhf by disabling
autovacuum in that workflow — a CI workaround that protects the fleet and leaves users exposed.
This strips the `ANALYZE` along with the transaction control it was written to follow. The
standalone `spatial_ref_sys.sql` keeps it; autovacuum analyses the table on its own schedule,
so the extension script does not need to.
Verified by generating the file both ways: the standalone script still ends with `COMMIT;` and
`ANALYZE "spatial_ref_sys";`, and the extension copy now ends at `ON CONFLICT (srid) DO NOTHING;`.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/650
commit 248b014b9805911792e2fcc097ce7c0cde422308
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Aug 2 20:03:01 2026 +0400
spatial_ref_sys.sql ends with
COMMIT;
The ANALYZE sits after COMMIT on purpose: run standalone it refreshes the
statistics of a table that just gained thousands of rows, outside any
transaction. The extension build strips BEGIN and COMMIT because those are
not allowed in extension scripts, and left the ANALYZE behind — so it ends up
*inside* the upgrade's transaction, takes ShareUpdateExclusiveLock on
spatial_ref_sys, and can deadlock against autovacuum analysing the same table:
DETAIL: Process A waits for ShareUpdateExclusiveLock on relation ...;
blocked by process B. Process B waits for ShareLock on
transaction ...; blocked by process A.
That aborts ALTER EXTENSION postgis UPDATE, so a user upgrading a busy
database can simply lose the upgrade. It also accounts for three of the
eleven most recent Woodpecker pipeline failures, in regress/test-install and
regress/test-upgrades, on ordinary amd64 rows rather than emulated ones.
Strip the ANALYZE along with the transaction control it was written to follow.
The standalone spatial_ref_sys.sql keeps it; autovacuum analyses the table on
its own schedule, so the extension script does not need to.
diff --git a/NEWS b/NEWS
index 08d1623765..d663d01851 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,8 @@ These are only changes since 3.7.0beta1.
* Bug Fixes *
+ - Stop the extension upgrade script running ANALYZE inside its transaction,
+ where it could deadlock with autovacuum (Darafei Praliaskouski)
- [liblwgeom] Reject malformed GSERIALIZED NURBS before curve
evaluation (Darafei Praliaskouski)
- GT-619, Make interrupt regression tests compare timeout latency to
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 88ef35afdf..fbf3bd09aa 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -104,9 +104,21 @@ sql/$(EXTENSION)--unpackaged.sql: Makefile | sql
sql:
mkdir -p $@
-#strip BEGIN/COMMIT since these are not allowed in extensions
+# Strip BEGIN/COMMIT since these are not allowed in extensions, and the trailing
+# ANALYZE with them. In spatial_ref_sys.sql that ANALYZE deliberately sits *after*
+# COMMIT, so run standalone it refreshes statistics outside any transaction. Removing
+# only the COMMIT moves it inside the extension's transaction, where it takes
+# ShareUpdateExclusiveLock on spatial_ref_sys and can deadlock against autovacuum
+# doing the same work:
+# ERROR: deadlock detected
+# CONTEXT: SQL statement "ANALYZE "spatial_ref_sys""
+# extension script file "postgis--ANY--<version>.sql"
+# That aborts ALTER EXTENSION postgis UPDATE on any busy database. Autovacuum will
+# analyse the table on its own schedule, so the extension script does not need to.
sql/spatial_ref_sys.sql: ../../spatial_ref_sys.sql | sql
- $(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
+ $(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g ; s/^ANALYZE "spatial_ref_sys";\s*$$//g' $< > $@
sql/spatial_ref_sys_config_dump.sql: ../../spatial_ref_sys.sql ../../utils/create_spatial_ref_sys_config_dump.pl | sql
$(PERL) @top_srcdir@/utils/create_spatial_ref_sys_config_dump.pl $< > $@
Summary of changes:
NEWS | 2 ++
extensions/postgis/Makefile.in | 16 ++++++++++++++--
2 files changed, 16 insertions(+), 2 deletions(-)
hooks/post-receive
