[SCM] PostGIS branch master updated. 3.7.0beta1-190-g393c276ab5
git at osgeo.org
git at osgeo.org
Sun Aug 2 23:39:15 PDT 2026
the project "PostGIS".
via 393c276ab57fdebe12d8bc753346e219d4fa228a (commit)
from e1f0a0baa66f59f2e99dcf56c962d654b478a649 (commit)
revisions in full, below.
commit 393c276ab57fdebe12d8bc753346e219d4fa228a
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Mon Aug 3 05:03:57 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 89.1% (5332 of 5981 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index fc25b0b514..9c1b03a14a 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-07-20 08:06+0000\n"
-"PO-Revision-Date: 2026-08-03 03:39+0000\n"
+"PO-Revision-Date: 2026-08-03 06:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -14865,7 +14865,7 @@ msgstr ""
msgid ""
"A Polygon is converted to a single-element MultiPolygon. The coordinates are "
"unchanged."
-msgstr ""
+msgstr "一つのポリゴンを 1要素マルチポリゴンに変換します。座標値は変わりません。"
#. Tag: refpurpose
#, no-c-format
@@ -15289,17 +15289,19 @@ msgid ""
"The input polygon has 55 points. The result retains 15 points, while "
"rendering the same shape inside the view envelope."
msgstr ""
+"入力ポリゴンは 55ポイントです。結果では 15 ポイントを保持します。どちらも表示"
+"エンベロープ内の形状は同じです。"
#. Tag: para
#, no-c-format
msgid ""
"Only linework affecting the view is retained; existing vertices are reused."
-msgstr ""
+msgstr "表示範囲に影響が出るラインは保持されます。既存の頂点を再利用します。"
#. Tag: para
#, no-c-format
msgid "A line with no segment relevant to the view becomes empty."
-msgstr ""
+msgstr "表示範囲と関係する線分が無いラインは空になります。"
#. Tag: para
#, no-c-format
@@ -15307,6 +15309,8 @@ msgid ""
"Removing vertices without computing intersections can introduce self-"
"intersections in the result."
msgstr ""
+"インターセクトしている箇所を計算しないまま頂点を削除すると、結果に自己"
+"インターセクションが入ってくる可能性があります。"
#. Tag: para
#, no-c-format
@@ -15314,6 +15318,8 @@ msgid ""
"With the default <parameter>cartesian_hint</parameter>, the function removes "
"only points known to be irrelevant to the view."
msgstr ""
+"デフォルトの <parameter>cartesian_hint</parameter> を付けると、この関数は表示"
+"範囲と関係ないと分かるポイントだけを削除します。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 14 ++++++++++----
1 file changed, 10 insertions(+), 4 deletions(-)
hooks/post-receive
