[SCM] PostGIS branch master updated. 3.7.0beta1-225-g847b54bbb6
git at osgeo.org
git at osgeo.org
Tue Aug 4 11:25:58 PDT 2026
the project "PostGIS".
via 847b54bbb65052fc23909569ce4b29788317d3c0 (commit)
from dad477d05fb5a8a65284346f0ca41a764bd6e036 (commit)
revisions in full, below.
commit 847b54bbb65052fc23909569ce4b29788317d3c0
Author: Regina Obe <lr at pcorp.us>
Date: Tue Aug 4 14:24:11 2026 -0400
Revert #1705 constraint-based columns in views to register correctly
References #1705
References #6110
diff --git a/NEWS b/NEWS
index b51c441573..6f297904d6 100644
--- a/NEWS
+++ b/NEWS
@@ -39,7 +39,10 @@ These are only changes since 3.7.0beta1.
(Darafei Praliaskouski)
- #6109, Out-of-bounds heap read in BOX2D_out and BOX2D_expand
on 65-byte box2d under ASAN (Dennis Tighe, Google)
- - #6110, regression in speed with geometry_columns (Regina Obe)
+ - #6110, Fix regression in speed with geometry_columns (Regina Obe)
+ - Revert feature #1705 (constraint geometry column detection in views)
+ Added too much overhead to geometry_columns performance (Regina Obe)
- Schema qualify references to pg_catalog and postgis
in geometry_columns and geography_columns views (Regina Obe)
@@ -251,8 +254,6 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
PDF builds while keeping HTML images transparent (Darafei Praliaskouski)
- #2838, Emit valid X3D Coordinate nodes for 2D polygon output
- - #1705, Infer constraint metadata for direct view and materialized view
- geometry columns (Darafei Praliaskouski)
- GH-899, [raster] Honor PostgreSQL interrupts in long-running GDAL
progress callbacks (Darafei Praliaskouski)
- #6073, #6074, Stabilize geography LRS endpoint interpolation and pole
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index a20a04d183..277b644856 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -74,7 +74,6 @@
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5645">#5645</link>, Docs: keep code operators ("=>") intact in translated manuals by enforcing verbatim CSS (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/1408">#1408</link>, Docs: flatten transparent manual images onto white backgrounds for PDF builds while keeping HTML images transparent (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2838">#2838</link>, Emit valid X3D Coordinate nodes for 2D polygon output (Darafei Praliaskouski)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/1705">#1705</link>, Infer constraint metadata for direct view and materialized view geometry columns (Darafei Praliaskouski)</para>
<para><link xlink:href="https://github.com/postgis/postgis/pull/899">GH-899</link>, [raster] Honor PostgreSQL interrupts in long-running GDAL progress callbacks (Darafei Praliaskouski)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/2583">#2583</link>, Preserve Z/ZM dimensional qualifiers in ST_AsEWKT output for TIN (Darafei Praliaskouski)</para>
</simplesect>
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index 7b48ba5177..594fe0708f 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -1601,10 +1601,9 @@ ON my_special_pois USING gist(geom gist_geometry_ops_nd);</programlisting>
<para>To retain constraint-based definition behavior, such as for inherited tables where all children do not have the same type and SRID, set the optional <varname>use_typmod</varname> argument to false.</para>
<programlisting language="sql">SELECT Populate_Geometry_Columns('myschema.my_special_pois'::regclass, false);</programlisting>
-<para>Although the old constraint-based method is still supported, direct
-pass-through view columns register correctly in <varname>geometry_columns</varname>
-for both typmod-based and constraint-based source columns. In this example we
-define a column using typmod and another using constraints.</para>
+<para>Although the old-constraint based method is still supported, a constraint-based geometry column used directly
+in a view, will not register correctly in geometry_columns, as will a typmod one.
+In this example we define a column using typmod and another using constraints.</para>
<programlisting language="sql">CREATE TABLE pois_ny(gid SERIAL PRIMARY KEY, poi_name text, cat text, geom geometry(POINT, 4326));
SELECT AddGeometryColumn('pois_ny', 'geom_2160', 2160, 'POINT', 2, false);</programlisting>
<para>If we run <command>\d pois_ny</command> in psql, we observe they are defined differently -- one is typmod, one is constraint.</para>
@@ -1642,21 +1641,20 @@ SELECT *
SELECT f_table_name, f_geometry_column, srid, type
FROM geometry_columns
WHERE f_table_name = 'vw_pois_ny_parks';</programlisting>
-<para>Both the typmod based geom view column and the direct constraint based
-view column register correctly.</para>
+<para>The typmod based geom view column registers correctly,
+but the constraint based one does not.</para>
<screen role="text-primary"> f_table_name | f_geometry_column | srid | type
vw_pois_ny_parks | geom | 4326 | POINT
- vw_pois_ny_parks | geom_2160 | 2160 | POINT</screen>
+ vw_pois_ny_parks | geom_2160 | 0 | GEOMETRY</screen>
-<para>If the view applies a spatial function to the geometry, such as
-<function>ST_Transform</function>, you still need to cast the transformed
-column explicitly so the view can expose the correct type and SRID:</para>
+<para>This may change in future versions of PostGIS, but for now
+to force the constraint-based view column to register correctly, you need to do this:</para>
<programlisting language="sql">DROP VIEW vw_pois_ny_parks;
CREATE VIEW vw_pois_ny_parks AS
SELECT gid, poi_name, cat,
geom,
- ST_Transform(geom, 2160)::geometry(POINT, 2160) As geom_2160
+ geom_2160::geometry(POINT,2160) As geom_2160
FROM pois_ny
WHERE cat = 'park';
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 1df0e2b0bf..cd8cc4cb8d 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6610,99 +6610,6 @@ LANGUAGE 'sql' STABLE STRICT PARALLEL SAFE _COST_MEDIUM;
-- Changed: 2.4.0 List also Parent partitioned tables
-- Changed: 2.5.2 replace use of pg_constraint.consrc with pg_get_constraintdef, consrc removed pg12
--- Extract base-column origin metadata only from a view rule's top-level target list.
--- pg_node_tree text also contains nested Query target lists for subqueries; treating
--- those as outer view columns would make expression outputs inherit constraints.
-CREATE OR REPLACE FUNCTION _postgis_geometry_columns_view_column_origin(
- view_rule pg_node_tree,
- view_attnum smallint)
-RETURNS TABLE(base_relid oid, base_attnum smallint)
-AS $$
-DECLARE
- rule_text text := view_rule::text;
- rule_len integer := length(rule_text);
- i integer := 1;
- token text := ':targetList (';
- token_len integer := length(':targetList (');
- ch text;
- prev_ch text;
- in_quote boolean := false;
- paren_depth integer := 0;
- brace_depth integer := 0;
- in_top_targetlist boolean := false;
- entry_start integer := 0;
- entry_text text;
- match text[];
-BEGIN
- WHILE i <= rule_len LOOP
- IF NOT in_quote AND NOT in_top_targetlist
- AND paren_depth = 1
- AND brace_depth = 1
- AND substr(rule_text, i, token_len) = token
- THEN
- in_top_targetlist := true;
- paren_depth := paren_depth + 1;
- i := i + token_len;
- CONTINUE;
- END IF;
- ch := substr(rule_text, i, 1);
- IF ch = '"' AND prev_ch IS DISTINCT FROM chr(92) THEN
- in_quote := NOT in_quote;
- ELSIF NOT in_quote THEN
- IF in_top_targetlist
- AND entry_start = 0
- AND paren_depth = 2
- AND substr(rule_text, i, 12) = '{TARGETENTRY'
- THEN
- entry_start := i;
- END IF;
- IF ch = '(' THEN
- ELSIF ch = ')' THEN
- paren_depth := paren_depth - 1;
- IF in_top_targetlist AND paren_depth = 1 THEN
- RETURN;
- END IF;
- ELSIF ch = '{' THEN
- brace_depth := brace_depth + 1;
- ELSIF ch = '}' THEN
- brace_depth := brace_depth - 1;
- AND entry_start > 0
- THEN
- entry_text := substr(rule_text, entry_start, i - entry_start + 1);
- entry_start := 0;
- match := regexp_match(
- entry_text,
- $re$^\{TARGETENTRY :expr \{VAR [^}]*\} :resno ([0-9]+) :resname [^:]+ :ressortgroupref [0-9]+ :resorigtbl ([0-9]+) :resorigcol ([0-9]+) :resjunk false\}$re$
- IF match IS NOT NULL
- AND match[1]::smallint = view_attnum
- AND match[2] <> '0'
- AND match[3] <> '0'
- THEN
- base_relid := match[2]::oid;
- base_attnum := match[3]::smallint;
- RETURN NEXT;
- RETURN;
- END IF;
- END IF;
- END IF;
- END IF;
- prev_ch := ch;
- i := i + 1;
- END LOOP;
-END
-LANGUAGE 'plpgsql' STABLE STRICT PARALLEL SAFE;
CREATE OR REPLACE VIEW geometry_columns AS
WITH constraint_defs AS NOT MATERIALIZED (
-- Trim trailing NOT VALID so metadata inference works before constraint validation (#4828).
@@ -6723,17 +6630,6 @@ SELECT pg_catalog.current_database()::pg_catalog.varchar(256) AS f_table_catalog
JOIN pg_catalog.pg_attribute a ON a.attrelid OPERATOR(pg_catalog.=) c.oid AND NOT a.attisdropped
JOIN pg_catalog.pg_namespace n ON c.relnamespace OPERATOR(pg_catalog.=) n.oid
JOIN pg_catalog.pg_type t ON a.atttypid OPERATOR(pg_catalog.=) t.oid
- -- Direct view columns have rewrite-rule target entries with origin metadata.
- -- Use only top-level bare VAR target entries, so expressions keep needing explicit casts.
- LEFT JOIN LATERAL (
- SELECT origin.base_relid,
- origin.base_attnum
- FROM pg_catalog.pg_rewrite AS r
- CROSS JOIN LATERAL @extschema at ._postgis_geometry_columns_view_column_origin(r.ev_action, a.attnum) AS origin
- WHERE c.relkind OPERATOR(pg_catalog.=) ANY (ARRAY['v'::pg_catalog."char", 'm'::pg_catalog."char"])
- AND r.ev_class OPERATOR(pg_catalog.=) c.oid
- AND r.rulename OPERATOR(pg_catalog.=) '_RETURN'
- ) AS vco ON true
LEFT JOIN (
SELECT s.connamespace,
s.conrelid,
@@ -6741,7 +6637,7 @@ SELECT pg_catalog.current_database()::pg_catalog.varchar(256) AS f_table_catalog
(pg_catalog.regexp_match(s.consrc, $$geometrytype\(\w+\)\s*=\s*'(\w+)'$$, 'i'))[1]::pg_catalog.text AS type
FROM constraint_defs AS s
WHERE s.consrc OPERATOR(pg_catalog.~*) $$geometrytype\(\w+\)\s*=\s*'\w+'$$::pg_catalog.text
- ) st ON st.conrelid OPERATOR(pg_catalog.=) COALESCE(vco.base_relid, c.oid) AND (COALESCE(vco.base_attnum, a.attnum) OPERATOR(pg_catalog.=) ANY (st.conkey))
+ ) st ON st.conrelid OPERATOR(pg_catalog.=) c.oid AND (a.attnum OPERATOR(pg_catalog.=) ANY (st.conkey))
LEFT JOIN (
s.conrelid,
@@ -6749,7 +6645,7 @@ SELECT pg_catalog.current_database()::pg_catalog.varchar(256) AS f_table_catalog
(pg_catalog.regexp_match(s.consrc, $$ndims\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer AS ndims
WHERE s.consrc OPERATOR(pg_catalog.~*) $$ndims\(\w+\)\s*=\s*\d+$$::pg_catalog.text
- ) sn ON sn.conrelid OPERATOR(pg_catalog.=) COALESCE(vco.base_relid, c.oid) AND (COALESCE(vco.base_attnum, a.attnum) OPERATOR(pg_catalog.=) ANY (sn.conkey))
+ ) sn ON sn.conrelid OPERATOR(pg_catalog.=) c.oid AND (a.attnum OPERATOR(pg_catalog.=) ANY (sn.conkey))
LEFT JOIN (
s.conrelid,
@@ -6757,7 +6653,7 @@ SELECT pg_catalog.current_database()::pg_catalog.varchar(256) AS f_table_catalog
(pg_catalog.regexp_match(s.consrc, $$srid\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer As srid
WHERE s.consrc OPERATOR(pg_catalog.~*) $$srid\(\w+\)\s*=\s*\d+$$::pg_catalog.text
- ) sr ON sr.conrelid OPERATOR(pg_catalog.=) COALESCE(vco.base_relid, c.oid) AND (COALESCE(vco.base_attnum, a.attnum) OPERATOR(pg_catalog.=) ANY (sr.conkey))
+ ) sr ON sr.conrelid OPERATOR(pg_catalog.=) c.oid AND (a.attnum OPERATOR(pg_catalog.=) ANY (sr.conkey))
WHERE (c.relkind OPERATOR(pg_catalog.=) ANY (ARRAY['r'::pg_catalog."char", 'v'::pg_catalog."char", 'm'::pg_catalog."char", 'f'::pg_catalog."char", 'p'::pg_catalog."char"]))
AND NOT c.relname OPERATOR(pg_catalog.=) 'raster_columns'::pg_catalog.name AND t.typname OPERATOR(pg_catalog.=) 'geometry'::pg_catalog.name
AND NOT pg_catalog.pg_is_other_temp_schema(c.relnamespace)
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index fb5dd44d3d..80eb6d8b24 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1704,7 +1704,7 @@ SELECT f_table_schema, f_table_name, f_geometry_column, coord_dimension, srid, t
ORDER BY f_table_name, f_geometry_column;
DROP TABLE IF EXISTS test5829, test5978;
--- #1705, constraint-based geometry metadata for direct view columns
+-- #1705, view columns do not inherit constraint-based geometry metadata; only typmod-based view columns and constraint-based table columns register
CREATE TABLE test1705 (
gid integer,
geom geometry(Point, 4326),
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 9f864b1077..065f490c72 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -518,15 +518,15 @@ public|test5978|geometry|2|4326|POINT
public|test5978|shape|2|4326|POINT
#1705|public|test1705|geom|2|4326|POINT
#1705|public|test1705|geom_2160|2|2160|POINT
-#1705|public|test1705_alias_view|shape|2|2160|POINT
+#1705|public|test1705_alias_view|shape|2|0|GEOMETRY
#1705|public|test1705_buffer_view|geom_2160|2|0|GEOMETRY
-#1705|public|test1705_matview|geom_2160|2|2160|POINT
+#1705|public|test1705_matview|geom_2160|2|0|GEOMETRY
#1705|public|test1705_mixed_view|buffered|2|0|GEOMETRY
-#1705|public|test1705_mixed_view|geom_2160|2|2160|POINT
+#1705|public|test1705_mixed_view|geom_2160|2|0|GEOMETRY
#1705|public|test1705_nested_buffer_view|geom_2160|2|0|GEOMETRY
#1705|public|test1705_scalar_buffer_view|geom_2160|2|0|GEOMETRY
#1705|public|test1705_view|geom|2|4326|POINT
-#1705|public|test1705_view|geom_2160|2|2160|POINT
+#1705|public|test1705_view|geom_2160|2|0|GEOMETRY
#3103.1|4326
#3103.2|3857
#3103.3|test3103b|3857
Summary of changes:
NEWS | 7 +--
doc/release_notes.xml | 1 -
doc/using_postgis_dataman.xml | 20 ++++----
postgis/postgis.sql.in | 110 ++----------------------------------------
regress/core/tickets.sql | 2 +-
regress/core/tickets_expected | 8 +--
6 files changed, 21 insertions(+), 127 deletions(-)
hooks/post-receive
