[SCM] PostGIS branch master updated. 3.7.0beta1-235-ga3695275a6
git at osgeo.org
git at osgeo.org
Thu Aug 6 03:39:16 PDT 2026
the project "PostGIS".
via a3695275a6d9a0a9de41638b6df7c5e919264e94 (commit)
from f0fcd768095538411a179d1f8bba115cd273366d (commit)
revisions in full, below.
commit a3695275a6d9a0a9de41638b6df7c5e919264e94
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Thu Aug 6 09:30:47 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 92.3% (5576 of 6037 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 8cd02e08b2..b5ace99414 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-08-04 15:37+0000\n"
-"PO-Revision-Date: 2026-08-06 08:39+0000\n"
+"PO-Revision-Date: 2026-08-06 10:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -26753,6 +26753,8 @@ msgid ""
"polygon. The constraint polygon boundary is included both as an obstacle and "
"as the constraint for the circle center."
msgstr ""
+"ポイント集合内でポリゴン内の制約が付いている最大空円。制約用ポリゴンの境界は"
+"障害物として、また円の中心として使われます。"
#. Tag: refpurpose
#, no-c-format
@@ -26818,6 +26820,8 @@ msgid ""
"Minimum bounding circle of a point and linestring, using 8 segments to "
"approximate a quarter circle."
msgstr ""
+"ポイントとラインストリングの最小バウンディング円で、四分円の近似に8辺を使って"
+"います。"
#. Tag: para
#, no-c-format
@@ -26887,7 +26891,7 @@ msgstr "GEOS 3.6.0以上が必要です。"
#. Tag: para
#, no-c-format
msgid "Oriented envelope of a Point and LineString."
-msgstr ""
+msgstr "POINT と LINESTRING の最小回転四角形。"
#. Tag: refpurpose
#, no-c-format
@@ -26985,17 +26989,17 @@ msgstr "Enhanced: 2.5 - GEOMETRYCOLLECTIONとULTILINESTRINGへの対応追加"
#. Tag: para
#, no-c-format
msgid "Compute an open buffer around roads."
-msgstr ""
+msgstr "道路回りに施した閉じていないバッファーを計算。"
#. Tag: para
#, no-c-format
msgid "Offset 15 units with <code>quad_segs=4 join=round</code>."
-msgstr ""
+msgstr "15単位ずらし、<code>quad_segs=4 join=round</code> を指定。"
#. Tag: para
#, no-c-format
msgid "Offset -15 units with <code>quad_segs=4 join=round</code>."
-msgstr ""
+msgstr "-15単位ずらし、<code>quad_segs=4 join=round</code> を指定。"
#. Tag: para
#, no-c-format
@@ -27003,23 +27007,25 @@ msgid ""
"Apply two negative offsets to obtain a smoother curve; the distances combine "
"to -45 units."
msgstr ""
+"二つの負の移動量を適用して、滑らかな曲線を得ます。距離は組み合わせて -45単位"
+"となります。"
#. Tag: para
#, no-c-format
msgid ""
"Collect the positive offset and the double-offset to produce parallel curves."
-msgstr ""
+msgstr "正の移動量と二倍の移動量とを合わせて平行曲線を作ります。"
#. Tag: para
#, no-c-format
msgid "Offset 15 units with a bevel join."
-msgstr ""
+msgstr "15単位移動かつ面取り結合。"
#. Tag: para
#, no-c-format
msgid ""
"Collect offsets on both sides using a mitre join and a mitre limit of 2.2."
-msgstr ""
+msgstr "正負両方の移動を合わせた平行曲線。マイター結合で、割合制限を 2.2にしている。"
#. Tag: refpurpose
#, no-c-format
@@ -27062,23 +27068,23 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "Point on surface of a MultiPoint."
-msgstr ""
+msgstr "MULTIPOINT で形成されるサーフェス上のポイント。"
#. Tag: para
#, no-c-format
msgid "Point on surface of a LineString."
-msgstr ""
+msgstr "LINERSTRING で形成されるサーフェス上のポイント。"
#. Tag: para
#, no-c-format
msgid "Point on surface of a Polygon."
-msgstr ""
+msgstr "POLYGON で形成されるサーフェス上のポイント。"
#. Tag: para
#, no-c-format
msgid ""
"Point on surface of the highest-dimension components of a GeometryCollection."
-msgstr ""
+msgstr "GEOMETRYCOLLECTION の最大次元要素で形成されるサーフェス上のポイント。"
#. Tag: para
#, no-c-format
@@ -27151,7 +27157,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "Polygonize a set of input lines."
-msgstr ""
+msgstr "入力ライン集合のポリゴン化。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 32 +++++++++++++++++++-------------
1 file changed, 19 insertions(+), 13 deletions(-)
hooks/post-receive
