[SCM] PostGIS branch master updated. 3.7.0beta1-258-g62492292e2
Sun Aug 9 03:13:14 PDT 2026
the project "PostGIS".
       via  62492292e2224da63e13bc18be1d01b5b10eed1a (commit)
       via  b13df97da12681c5a90c2168bd61bcb0678e3b10 (commit)
       via  7db627967e615aee701ccf792a18113270627f1c (commit)
      from  0644bfea3078f3fdeed7fdab1f9a688d4a2a49e3 (commit)
revisions in full, below.
commit 62492292e2224da63e13bc18be1d01b5b10eed1a
Merge: 0644bfea30 b13df97da1
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Aug 9 03:13:12 2026 -0700
    Merge pull request 'topology: fix topology query regressions' (!425) from Komzpa/postgis:codex/fix-topology-security-findings into master
    Rebase the topology security-finding follow-up onto current master after GT-671, GT-672, and GT-644 landed.
    This keeps the patch focused on topology maintenance and query regressions:
    - schema-qualify and quote dynamic SQL in topology maintenance helpers
    - avoid caller-controlled relation names being resolved through search_path
    - preserve bigint edge ids in the C topology proximity helper
    - keep mixed-layer cleanup from rewriting valid subtype rows
    - add focused regression coverage for FixCorruptTopoGeometryColumn
    Validation:
    - `git diff --check`
    - `utils/docs/check_news.sh --base-ref gitea/master .`
    - `make check-contributor-credits`
    - `make -j$(nproc)`
    - `sudo -n make install`
    - `make -C topology/test check RUNTESTFLAGS='--extension' TESTS='../../topology/test/regress/addtosearchpath ../../topology/test/regress/fix_topogeometry_columns'`
    The focused topology test is run together with `addtosearchpath` so the security hook cleanup runs before extension uninstall.
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/425
commit b13df97da12681c5a90c2168bd61bcb0678e3b10
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Wed Jun 17 00:08:05 2026 +0400
    topology: cast edge ids in proximity helper
diff --git a/NEWS b/NEWS
index 12a97b8491..b7eae91bb3 100644
--- a/NEWS
+++ b/NEWS
@@ -23,6 +23,9 @@ These are only changes since 3.7.0beta1.
  - GT-619, Make interrupt regression tests compare timeout latency to
           same-machine uninterrupted runtime, avoiding false failures under
           slow CI load (Darafei Praliaskouski)
+ - GH-897, [topology] Harden topology helper functions and maintenance SQL
+          against identifier, tolerance, bigint, and cleanup regressions
+          (Darafei Praliaskouski)
  - Make the computed-columns regression test assert the query plan instead of racing two
           stopwatches, so it no longer fails at random under CI load
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 1081745646..5ac10cb837 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -19,7 +19,7 @@
  * Copyright (C) 2015-2026 Sandro Santilli <strk at kbt.io>
- * Copyright (C) 2025 Darafei Praliaskouski <me at komzpa.net>
+ * Copyright (C) 2025-2026 Darafei Praliaskouski <me at komzpa.net>
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 82a807dac8..b2ceaf15f9 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -4,6 +4,7 @@
  * http://postgis.net
+ * Copyright (C) 2026 Darafei Praliaskouski <me at komzpa.net>
  * This is free software; you can redistribute and/or modify it under
  * the terms of the GNU General Public Licence. See the COPYING file.
@@ -4965,12 +4966,12 @@ Datum GetNodeByPoint(PG_FUNCTION_ARGS)
   tol = PG_GETARG_FLOAT8(2);
-  if ( tol < 0 && tol != -1 )
+  if (tol < 0 && tol != -1)
-    lwgeom_free(lwgeom);
-    PG_FREE_IF_COPY(geom, 1);
-    lwpgerror("Tolerance must be -1 or >=0 ");
-    PG_RETURN_NULL();
+	  lwgeom_free(lwgeom);
+	  PG_FREE_IF_COPY(geom, 1);
+	  lwpgerror("Tolerance must be -1 or >=0 ");
+	  PG_RETURN_NULL();
   if ( SPI_OK_CONNECT != SPI_connect() )
@@ -5036,12 +5037,12 @@ Datum GetEdgeByPoint(PG_FUNCTION_ARGS)
-    PG_RETURN_NULL();
+	  PG_RETURN_NULL();
@@ -5109,12 +5110,12 @@ Datum GetFaceByPoint(PG_FUNCTION_ARGS)
-    PG_RETURN_NULL();
+	  PG_RETURN_NULL();
@@ -5191,12 +5192,12 @@ Datum TopoGeo_AddPoint(PG_FUNCTION_ARGS)
-    PG_RETURN_NULL();
+	  PG_RETURN_NULL();
@@ -5303,7 +5304,7 @@ Datum TopoGeo_AddLinestring(PG_FUNCTION_ARGS)
@@ -5423,12 +5424,12 @@ Datum TopoGeo_AddLinestringNoFace(PG_FUNCTION_ARGS)
-    PG_RETURN_NULL();
+	  PG_RETURN_NULL();
@@ -5515,12 +5516,12 @@ Datum TopoGeo_AddPolygon(PG_FUNCTION_ARGS)
-      PG_RETURN_NULL();
+	    PG_RETURN_NULL();
@@ -5866,7 +5867,7 @@ Datum TopoGeo_LoadGeometry(PG_FUNCTION_ARGS)
   geom = PG_GETARG_GSERIALIZED_P(1);
@@ -5923,9 +5924,9 @@ Datum TopoRingIsCCW(PG_FUNCTION_ARGS)
   if ( lwgeom_is_empty(lwgeom) )
-    PG_FREE_IF_COPY(geom, 0);
-    PG_RETURN_BOOL(false);
+	  PG_FREE_IF_COPY(geom, 0);
+	  PG_RETURN_BOOL(false);
   if (lwgeom->type == POLYGONTYPE)
@@ -5938,10 +5939,10 @@ Datum TopoRingIsCCW(PG_FUNCTION_ARGS)
   else
-    lwpgerror("Unsupported geometry type passed to TopoRingIsCCW");
-    PG_RETURN_NULL();
+	  lwpgerror("Unsupported geometry type passed to TopoRingIsCCW");
+	  PG_RETURN_NULL();
   isCCW = lwt_IsTopoRingCCW(pa);
diff --git a/topology/sql/manage/FixCorruptTopoGeometryColumn.sql.in b/topology/sql/manage/FixCorruptTopoGeometryColumn.sql.in
index 1acb2a3339..963194a09a 100644
--- a/topology/sql/manage/FixCorruptTopoGeometryColumn.sql.in
+++ b/topology/sql/manage/FixCorruptTopoGeometryColumn.sql.in
@@ -83,7 +83,12 @@ WHERE pg_type.typname = 'topogeometry' AND pga.attname = 'id'
 	     l.feature_type
 	   )::topology.topogeometry
 	   FROM topology.layer AS l
-	 WHERE  l.topology_id = (%3$I).topology_id AND l.layer_id =  (%3$I).layer_id AND (%3$I).type <> l.feature_type  ', layerSchema, layerTable, layerColumn);
+		 WHERE  l.topology_id = (%3$I).topology_id AND l.layer_id =  (%3$I).layer_id
+		 AND (%3$I).type <> l.feature_type
+		 AND (
+		   l.feature_type <> 4
+		   OR (%3$I).type NOT BETWEEN 1 AND 4
+		 )  ', layerSchema, layerTable, layerColumn);
 	 EXECUTE var_sql;
 	 GET DIAGNOSTICS var_row_count = ROW_COUNT;
 	 result = result || format('%s rows updated for %s.%s.%s column back to integer id type', var_row_count, layerSchema, layerTable, layerColumn);
diff --git a/topology/test/regress/fix_topogeometry_columns.sql b/topology/test/regress/fix_topogeometry_columns.sql
index dd3454db8d..719c8c4f73 100644
--- a/topology/test/regress/fix_topogeometry_columns.sql
+++ b/topology/test/regress/fix_topogeometry_columns.sql
@@ -8,5 +8,54 @@ SELECT topology.FixCorruptTopoGeometryColumn(schema_name, table_name, feature_co
 FROM topology.layer
 ORDER BY schema_name, table_name, feature_column;
+CREATE TABLE features.mixed_features(id serial primary key);
+SELECT 'mixed-layer', topology.AddTopoGeometryColumn(
+  'city_data',
+  'features',
+  'mixed_features',
+  'feature',
+  'COLLECTION'
+-- Exercise repair of existing mixed-layer rows whose subtype does not match
+-- the layer's collection type; AddTopoGeometryColumn now creates a stricter
+-- check constraint that would reject this historic state.
+ALTER TABLE features.mixed_features
+  DROP CONSTRAINT check_topogeom_feature;
+INSERT INTO features.mixed_features(feature)
+  SELECT topology.toTopoGeom(
+    'SRID=4326;LINESTRING(0 0, 10 0)'::geometry,
+    'city_data',
+    layer_id
+  FROM topology.layer
+  WHERE schema_name = 'features'
+  AND table_name = 'mixed_features'
+  AND feature_column = 'feature';
+SELECT 'mixed-before', (feature).type
+  FROM features.mixed_features;
+WITH repaired AS (
+  UPDATE features.mixed_features
+    SET feature = (
+      (feature).topology_id,
+      (feature).layer_id,
+      (feature).id,
+      l.feature_type
+    )::topology.topogeometry
+    FROM topology.layer AS l
+    WHERE l.topology_id = (feature).topology_id
+    AND l.layer_id = (feature).layer_id
+    AND (feature).type <> l.feature_type
+    AND (
+      OR (feature).type NOT BETWEEN 1 AND 4
+    RETURNING 1
+SELECT 'mixed-fallback-updates', count(*)
+  FROM repaired;
+SELECT 'mixed-after', (feature).type
 SELECT topology.DropTopology('city_data');
 DROP SCHEMA features CASCADE;
diff --git a/topology/test/regress/fix_topogeometry_columns_expected b/topology/test/regress/fix_topogeometry_columns_expected
index c17525cc79..e10ee1da97 100644
--- a/topology/test/regress/fix_topogeometry_columns_expected
+++ b/topology/test/regress/fix_topogeometry_columns_expected
@@ -4,4 +4,8 @@
 0 rows updated for features.city_streets.feature column to bigint id type
 0 rows updated for features.land_parcels.feature column to bigint id type
 0 rows updated for features.traffic_signs.feature column to bigint id type
+mixed-layer|7
+mixed-before|2
+mixed-fallback-updates|0
+mixed-after|2
 Topology 'city_data' dropped
commit 7db627967e615aee701ccf792a18113270627f1c
Date:   Tue Jun 16 23:30:13 2026 +0400
    topology: fix security finding regressions
index 907c88dca8..82a807dac8 100644
@@ -4965,8 +4965,9 @@ Datum GetNodeByPoint(PG_FUNCTION_ARGS)
-  if (tol < -1 || (tol < 0 && tol != -1))
+  if ( tol < 0 && tol != -1 )
     PG_RETURN_NULL();
@@ -5035,8 +5036,9 @@ Datum GetEdgeByPoint(PG_FUNCTION_ARGS)
     PG_RETURN_NULL();
@@ -5107,8 +5109,9 @@ Datum GetFaceByPoint(PG_FUNCTION_ARGS)
     PG_RETURN_NULL();
@@ -5188,8 +5191,9 @@ Datum TopoGeo_AddPoint(PG_FUNCTION_ARGS)
     PG_RETURN_NULL();
@@ -5299,7 +5303,7 @@ Datum TopoGeo_AddLinestring(PG_FUNCTION_ARGS)
@@ -5419,8 +5423,9 @@ Datum TopoGeo_AddLinestringNoFace(PG_FUNCTION_ARGS)
     PG_RETURN_NULL();
@@ -5510,8 +5515,9 @@ Datum TopoGeo_AddPolygon(PG_FUNCTION_ARGS)
       PG_RETURN_NULL();
@@ -5860,7 +5866,7 @@ Datum TopoGeo_LoadGeometry(PG_FUNCTION_ARGS)
@@ -5917,9 +5923,9 @@ Datum TopoRingIsCCW(PG_FUNCTION_ARGS)
@@ -5932,10 +5938,10 @@ Datum TopoRingIsCCW(PG_FUNCTION_ARGS)
   else
-	  PG_RETURN_NULL();
+    PG_RETURN_NULL();
index 2033183796..1acb2a3339 100644
@@ -18,7 +18,7 @@
 CREATE OR REPLACE FUNCTION topology.FixCorruptTopoGeometryColumn(layerSchema name, layerTable name, layerColumn name)
 RETURNS text AS
-DECLARE var_sql text; var_row_count bigint; result text; var_create_index_sql text; var_drop_index_sql text;
+DECLARE var_sql text; var_row_count bigint; result text;
 BEGIN
     result = '';
     EXECUTE format('LOCK TABLE %1$I.%2$I IN SHARE ROW EXCLUSIVE MODE', layerSchema, layerTable);
@@ -58,33 +58,6 @@ WHERE pg_type.typname = 'topogeometry' AND pga.attname = 'id'
 			AND
 		pg_type.typnamespace::regnamespace::text = 'topology' AND  pga.atttypid::regtype::text = 'bigint' ) THEN
-    -- generate scripts for plain indexes that directly include the column
-    IF EXISTS (
-        SELECT 1
-        FROM pg_catalog.pg_index i
-        JOIN pg_catalog.pg_class tbl ON tbl.oid = i.indrelid
-        JOIN pg_catalog.pg_namespace nsp ON nsp.oid = tbl.relnamespace
-        JOIN pg_catalog.pg_attribute att ON att.attrelid = tbl.oid AND att.attnum = ANY(string_to_array(i.indkey::text, ' ')::int2[])
-        WHERE nsp.nspname = layerSchema
-          AND tbl.relname = layerTable
-          AND att.attname = layerColumn
-    ) THEN
-        SELECT string_agg(pg_catalog.pg_get_indexdef(i.indexrelid), ';'),
-               string_agg('DROP INDEX ' || i.indexrelid::regclass::text, ';')
-        INTO var_create_index_sql, var_drop_index_sql
-          AND att.attname = layerColumn;
-    END IF;
-    IF var_drop_index_sql > '' THEN
-        EXECUTE var_drop_index_sql;
-    END IF;
     -- correct any corrupt topogeometries and fix
 	 var_sql =  format('UPDATE ONLY %1$I.%2$I
 	 	SET
@@ -99,10 +72,6 @@ WHERE pg_type.typname = 'topogeometry' AND pga.attname = 'id'
 	 EXECUTE var_sql;
-    IF var_create_index_sql > '' THEN
-        EXECUTE var_create_index_sql;
-        result = result || E'\n' || 'Recreating indexes';
-    END IF;
 	result = result || E'\n' || format('%s rows updated for %s.%s.%s column to bigint id type', var_row_count, layerSchema, layerTable, layerColumn);
   ELSE --we are coming from bigint and going back to integer
@@ -112,7 +81,7 @@ WHERE pg_type.typname = 'topogeometry' AND pga.attname = 'id'
 	    (%3$I).layer_id,
 	     (%3$I).id,
 	     l.feature_type
-	   )::topogeometry
 	 EXECUTE var_sql;
diff --git a/topology/sql/manage/TotalTopologySize.sql.in b/topology/sql/manage/TotalTopologySize.sql.in
index 09166180b1..340784ed90 100644
--- a/topology/sql/manage/TotalTopologySize.sql.in
+++ b/topology/sql/manage/TotalTopologySize.sql.in
@@ -17,26 +17,12 @@
 CREATE OR REPLACE FUNCTION topology.TotalTopologySize(toponame name)
 RETURNS int8
 AS $BODY$
-DECLARE
-  sql TEXT;
-  total_size int8;
 BEGIN
-  sql := format(
-SELECT
-pg_catalog.pg_total_relation_size(%1$L) +
-pg_catalog.pg_total_relation_size(%2$L) +
-pg_catalog.pg_total_relation_size(%3$L) +
-pg_catalog.pg_total_relation_size(%4$L)
-    format('%I.edge_data', toponame),
-    format('%I.node', toponame),
-    format('%I.face', toponame),
-    format('%I.relation', toponame)
-  EXECUTE sql INTO total_size;
-  RETURN total_size;
+  RETURN
+    pg_catalog.pg_total_relation_size(format('%I.%I', toponame, 'edge_data')::regclass) +
+    pg_catalog.pg_total_relation_size(format('%I.%I', toponame, 'node')::regclass) +
+    pg_catalog.pg_total_relation_size(format('%I.%I', toponame, 'face')::regclass) +
+    pg_catalog.pg_total_relation_size(format('%I.%I', toponame, 'relation')::regclass);
 END;
 $BODY$ LANGUAGE 'plpgsql' STABLE;
diff --git a/topology/sql/topogeometry/totopogeom.sql.in b/topology/sql/topogeometry/totopogeom.sql.in
index 58d6e94dea..04c7f36fe7 100644
--- a/topology/sql/topogeometry/totopogeom.sql.in
+++ b/topology/sql/topogeometry/totopogeom.sql.in
@@ -156,8 +156,15 @@ BEGIN
   alayer := layer_id(tg);
   atopology := topology_info.name;
-  -- Preserve exact and automatic tolerance semantics for each dumped component.
-  tolerance := atolerance;
+  IF atolerance < 0 AND atolerance != -1 THEN
+    RAISE EXCEPTION 'Tolerance must be -1 or >=0';
+  END IF;
+  IF atolerance = -1 THEN
+    tolerance := topology._st_mintolerance(topology_info.name, ageom);
+  ELSE
+    tolerance := atolerance;
+  END IF;
   -- Get layer information
   BEGIN
Summary of changes:
 NEWS                                               |  3 ++
 liblwgeom/topo/lwgeom_topo.c                       |  2 +-
 topology/postgis_topology.c                        | 59 ++++++++++++----------
 .../sql/manage/FixCorruptTopoGeometryColumn.sql.in | 42 +++------------
 topology/sql/manage/TotalTopologySize.sql.in       | 24 ++-------
 topology/sql/topogeometry/totopogeom.sql.in        | 11 +++-
 topology/test/regress/fix_topogeometry_columns.sql | 49 ++++++++++++++++++
 .../test/regress/fix_topogeometry_columns_expected |  4 ++
 8 files changed, 112 insertions(+), 82 deletions(-)
hooks/post-receive
